DICE/LN2 Cooling - Where do i start? - Overclock.net - An Overclocking Community
Closed Thread
post #1 of 30 (permalink) Old 04-18-2012, 07:42 AM - Thread Starter
Hazzeedayz's Avatar
Rep: 66 (Unique: 55)
I am building an Intel rig pretty soon here and i was thinking of attempting DICE or LN2 on my AMD rig (the one in my sig)
My question is....
Where do i start?
All i know is that i have to insulate MoBo and get dielectric grease for PINs to prevent rust out.
I was reading around but i find it much easier for me to understand things when i actually am apart of the conversation instead of just reading through threads.
Some of my Questions/Concerns:
- how do i handle the LN2 (what precautions should i take)?
- which pot to start with?
- what is the best thing to use to insulate the MoBo?
- what is the best dielectric grease for pins?
- do i need special ventilation in the room (it's a small room)?
- what hardware generally fails at sub-zero temps?
- how can i keep this at a decently low budget? (i'm supporting two people redface.gif)
There are more questions i have but i just can't think of them now.
but my biggest one is:
WHERE do i start???
should i just go balls out, buy a pot, throw some LN2 in it and give it a go or what??
Goals
Learn!!!!
Short Term - Create a functioning sub-zero rig
I'd like say thank you in advance for any information/recommendations/advice you guys can provide me.
i appreciate it
Gaming (Click to show)
Xbox Live: Hazzeedayzz
Steam: Hazzeedayz
Origin: Smokadaweed
Hazzeedayz is offline
post #2 of 30 (permalink) Old 04-18-2012, 08:53 AM
Rep: 266 (Unique: 196)
Here is a great thread to help start you out.  It walks you through practically everything that you need to know.
https://www.overclock.net/t/1087013/start-subzero-cooling-for-under-200/0_50
As for your questions:
1) If you want to use LN2, then you're going to need a dewar.  You can either buy one (expensive), or you can rent one when you buy the LN2.  You're also going to need some thermoses (stainless steel with a vacuum chamber is preferable).  Other than that, just don't spill on yourself.  Oh, and I would recommend not using gloves, because if you do spill on them it will hold the cold against your hand and freeze you badly.
2) If you plan on using LN2 any time in the future I would buy a LN2 pot right from the very begining.  I made the mistake of buying a dice pot at first, and now I regret that I didn't get a better pot from the start.  I would recommend an OCN Marksman pot, or a Kingpin F1.  For a cheaper alternative, look for a used Koolance V2 pot.
3) Everyone has different preferences on how they like to insulate.  My insulation goes Mobo --> Liquid Electrical Tape --> Art Eraser (to seal in the CPU --> Blue Shop Towels --> Neoprene Gasket.  I really don't like using dielectric grease or vaseline because it's extremely messy.  And just a tip, never use vaseline and art eraser together, it'll create a mess.
4) For ventilation you don't need anything special, just keep the door to the room open.
5) With AMD, everything is usually pretty good at all temperatures, but with intel you can expect to run into a cold bug.  The cold bug will vary greatly from cpu to cpu.  Also, you might notice that your ram slots freeze up on you and stop working during a long benching session.
6) To keep it at a low budget, buy a used CPU pot.
HobieCat is offline
post #3 of 30 (permalink) Old 04-18-2012, 09:29 AM - Thread Starter
Hazzeedayz's Avatar
wow man thanks for the info
currently im having an issue finding the LN2...i may have found some from a welding supply shop but i haven't gotten a response from them yet
do you have any recommendations as far as this is concerned?
i live right outside of philly (Media, PA)
i prolly wont be using my intel rig for the build
i've had the 965 for a long time now and figured i was due for an upgrade so why not LN2 to sucker and have some fun while i destroy it biggrin.gif
seriously though, thanks for the info...this helps a lot.
im a little disappointed though...looks like FrozenCPU and Koolance both stopped selling LN2 pots frown.gif
Steam: Hazzeedayz
Origin: Smokadaweed
post #4 of 30 (permalink) Old 04-18-2012, 10:19 AM
just_nuke_em's Avatar
Rep: 228 (Unique: 198)
There are a couple places where you can get pots. On the more expensive side (but very nice pots) are the Infection Point, k|ngp|n pots, Marksman. All are around $300
It looks like de8aur just started large scale production of his pots http://www.der8auer.de/
Dimastech sells a pot that looks like the older k|ngp|n Dragon Evo pots, so it might be good for DICE. It is cheap though compared to the others http://www.dimastech.com/EN/c/dimastech-eco-pot-v20/
Duniek also sells pots, but I'm not sure what his prices are. You can ask him though https://www.overclock.net/u/82598/duniek
Also look here for some other manufactures http://hwbot.org/forum/showthread.php?t=29726
Guys, this is OCN. Aka, the "pursuit of performance". wink.gif I see no reason why the OP should be bashed simply because he wants to push his hardware as hard as he can.
just_nuke_em is offline
post #5 of 30 (permalink) Old 04-19-2012, 08:52 AM - Thread Starter
Hazzeedayz's Avatar
thanks a lot man
those links are a huge help
i've decided to start with DICE and move up once i learn some more about what im doing
i'll definitely be taking Cat's advice and will grab a LN2 pot and just use DICE in it until i upgrade
Steam: Hazzeedayz
Origin: Smokadaweed
post #6 of 30 (permalink) Old 04-19-2012, 11:13 AM
Originally Posted by Hazzeedayz View Post
thanks a lot man
If you're looking for a decent LN2 pot, there is a guy selling one in the marketplace right here: https://www.overclock.net/t/1238977/koolance-ln2-v2-liquid-nitrogen-pot-for-only-145-including-2-3-day-shipping-to-us48/0_50
HobieCat is offline
post #7 of 30 (permalink) Old 04-19-2012, 04:35 PM
335is
NoGuru's Avatar
Rep: 769 (Unique: 312)
I have the same Koolance Pot that Hobie pointed out and it will be great for both DICE and LN2 especially for AMD cause it is fast at dropping temps.
I never use any Dialectic in the socket because I don't bench for longer then 6-8 hours Tops and humidity is not bad in Michigan.
Some eraser and paper towel can be all you need if done right.
NoGuru is offline
post #8 of 30 (permalink) Old 04-19-2012, 05:32 PM
micul's Avatar
Rep: 41 (Unique: 31)
Like other said just look for a used pot . if you don't find one try Piotres to. If you don't have money for a Dewar just start with Dry Ice.
Buy some older hardware to get used to it and learn .
micul is offline
post #9 of 30 (permalink) Old 04-20-2012, 02:52 AM
Retired Staff
el gappo's Avatar
Rep: 389 (Unique: 261)
Definitely a good idea, can be difficult benching with the wrong pot for the job especially when managing cb/cbb's. The right pot will give you an edge on both dice and ln2 redface.gif https://www.overclock.net/t/1171484/ocn-marksman-v1-cpu-pot/80#post_16007112
In regards to learning, can you get yourself to the toronto event? I think we are going to try and do some ln2 lessons like we did at the Cambridge event if possible ( which as a learning experience was brilliant ). There really is no substitute for learning some of the ins and outs from experienced benchers there and then. Never seen so many people going from not knowing a thing about ln2 benching to benching cpu and gpu cold in a weekend. redface.gif
Twitter @el_gappo @Overclocknet
Redhat: "The datasheet is clear so its pretty hard to read without an overhead projector"
el gappo is offline
post #10 of 30 (permalink) Old 04-20-2012, 06:38 AM
335is
NoGuru's Avatar
Good idea Gapp. I just checked his route and it would be about a 8-9 hour drive. Would be a lot of fun though wink.gif
NoGuru is offline
Closed Thread
