DICE/LN2 pot for a 3770k - Page 2 - Overclock.net - An Overclocking Community
post #11 of 23 (permalink) Old 06-11-2013, 02:17 AM - Thread Starter
Fulvin's Avatar
Rep: 54 (Unique: 45)
Express Mail Service
I need more sleep, lol
Fulvin is offline
post #12 of 23 (permalink) Old 06-11-2013, 02:35 AM
stubass's Avatar
Rep: 2658 (Unique: 1360)
lol, dont we all biggrin.gif you will probably have yours before i have my setup to even start using mine lol redface.gif . 2D sck775 for me and just waiting for a x48 REX to arrive from the US.. also i had to jump through a loty of hoops here trying to find Ln2 which to no avail yet, so DICE for me to begin with. whistle.gif
stubass is offline
post #13 of 23 (permalink) Old 06-18-2013, 02:22 AM - Thread Starter
Fulvin's Avatar
The box was properly manhandled, luckily the contents are far from fragile. It's solid and weighs a ton.
I was hoping for it to come with neoprene or armaflex, but I'm not sure if the foam is simply for shipping protection or whether I can use it for insulation. Only 2 pieces of the foam are close cell foam, the rest are soft.
Next step is to get some proper closed cell foam and grease, and finally go hunt some DICE.
Fulvin is offline
post #14 of 23 (permalink) Old 06-18-2013, 02:36 AM
stubass's Avatar
the close cell stuff is fine for insulation as vince said nowadays he is including some insulation.
for grease, bassplayer put me onto this
http://www.ebay.com/itm/GELID-GC-EXTREME-10g-Big-Thermal-Paste-Compound-Grease-CPU-GPU-Chipset-Heatsink-/150854612713?pt=US_Thermal_Compounds_Supplies&hash=item231fa2b6e9#ht_3808wt_1399
or you can use cremique as both wont crack under the cold
http://kingpincooling.com/forum/showthread.php?t=1994
stubass is offline
post #15 of 23 (permalink) Old 06-18-2013, 02:46 AM - Thread Starter
Fulvin's Avatar
Looking back at your venom thread, you received a proper armaflex tube with yours, while mine looks simply more like packaging material.
Oh, and by grease I meant the stuff for mobo insulation, but thanks for the tip.
Fulvin is offline
post #16 of 23 (permalink) Old 06-18-2013, 02:53 AM
stubass's Avatar
Let or dragon skin is what you want for grease... i am stuck with eraser and vasaline since nobody here can understand what LET is at the 8 or so stores i went too lol
stubass is offline
post #17 of 23 (permalink) Old 06-18-2013, 03:02 AM - Thread Starter
Fulvin's Avatar
What is dragon skin, exactly? Google didn't help, but I'm guessing it's silicon grease or something? I'll probably go with vaseline or dielectric silicone grease instead of eraser. It might be messier, but it's better to play it safe.
Fulvin is offline
post #18 of 23 (permalink) Old 06-18-2013, 03:04 AM
driftingforlife's Avatar
Rep: 267 (Unique: 206)
I just started using LET (Liquid Electrical Tape), great stuff, I really recommend it. Also doesn't dragon skin crack past -100?
Car: 2007 Fiesta ST - Many many mods, to have ITB's at some point.
driftingforlife is offline
post #19 of 23 (permalink) Old 06-18-2013, 03:10 AM
stubass's Avatar
i think it is something around that range for dragon skin tho with DICE that wont be a problem.
stubass is offline
post #20 of 23 (permalink) Old 06-18-2013, 03:12 AM
Retired Staff
SmokinWaffle's Avatar
Rep: 435 (Unique: 316)
I'd just use eraser to be honest, just because it's so easy to remove and relatively easy to apply. Just make sure you get a good seal and it's easy once you get the hang of it. smile.gif
SmokinWaffle is offline
