Getting ready for first DICE/LN2.. - Overclock.net - An Overclocking Community
post #1 of 4 (permalink) Old 08-10-2017, 10:50 PM - Thread Starter
kava2126's Avatar
Rep: 1 (Unique: 1)
I have a delidded 6700k that I will do eventually but I'm getting a cheap setup first to get the feel of it. First of all, will the ASUS M5A99X EVO work well enough to help me get the feel of it? I plan on using FX-8320. If not what combo of CPU/Mobo would be best for a first timer?
kava2126 is offline
post #2 of 4 (permalink) Old 08-11-2017, 08:18 AM
BenchZowner's Avatar
Rep: 79 (Unique: 58)
Since you'll end up doing Intel on LN2, I'd pick an old but nice for testing & learning how to do LN2 OC CPU, like the 2500K or the 2600K.
They have coldbug, so you'll get to learn how to control the temperature during benchmark runs, and it's also a very tweakable platform, so you'll get to learn and get accustomed to all the voltages, clock skews, and the idiosyncrasies of the Intel Core iX platform under LN2.
Plus, it's a very potent CPU, and you'll be able to have fun in both 2D & 3D benchmarks.
If you plan on doing it occasionally you should read and find out about the ideal operating system & tweaks for each benchmark if you want to have comparable scores.
Especially with SuperPi, PiFast, wPrime, 3D Mark2001SE, 3D Mark03 and Aquamark3, bad software tweaking and choices will severely harm your scores and will leave you thinking "why is this guy with lower clocks 3000 points ahead of me ?".
BenchZowner is offline
post #3 of 4 (permalink) Old 08-11-2017, 01:36 PM - Thread Starter
kava2126's Avatar
Rep: 1 (Unique: 1)
Thank you for your advise. Makes total sense. Only reason I was going to do AMD was because it's cheaper. Is there a cheaper alternative to the 2500k? If not, what mobo do you recommend? Trying to keep it cheap as possible in case I ruin it.
kava2126 is offline
post #4 of 4 (permalink) Old 08-11-2017, 02:32 PM
You could always opt for an even older, yet very interesting setup. For example a Core 2 Duo E8600 + Asus Rampage Extreme ( X48 ).
8600s should go for as low as $15 on ebay nowadays.
Don't know how easy it will be however to locate and grab a good mobo for it for LN2.
In order of preference you should go to:
Asus Rampage Extreme > Asus P5E64 WS Evolution > Gigabyte GA-EX48DQ6T = Asus P5K3 Deluxe
Very fun setup!
