Why not use regular ice instead of dry ice? - Overclock.net - An Overclocking Community
post #1 of 84 (permalink) Old 01-06-2009, 12:16 PM - Thread Starter
coolwhip's Avatar
Rep: 47 (Unique: 46)
okay my parents arent really too thrilled with the idea of using dry ice, but i was thinking if i cant convince them about dry ice[=/] maybe i could see wath i can do with just regular ice.
i know id have to put more ice in a lot, but would this work, i could use a pot just like for dice, and have a tube pump so taht i can just pump out the melted water into like a bucket or something?
coolwhip is offline
post #2 of 84 (permalink) Old 01-06-2009, 12:19 PM
Science
BLKKROW's Avatar
Rep: 260 (Unique: 181)
may i recommended if you are going to do this ice + water + salt
www.blackaero.com
Desktop
(12 items)
AMD 3900x
Aorus X570 Pro Wifi
Gigabyte 1660 Ti
G.Skill 3600mhz DDR4, 16GB
HP 920 NVME 1TB
Corsair AX850
Corsair Carbide 400C
Operating System
Windows 10
Dell S2417DG
Keyboard
Ducky OCN Custom Mechanical
Mouse
Steel Series Kinzu V2
Audio
Fiio DAC Amplifier
BLKKROW is offline
post #3 of 84 (permalink) Old 01-06-2009, 12:19 PM
Rep: 96 (Unique: 87)
well the point of using things like dry ice is to get sub zero temps
it will also be kinda hard to get the amount of pumping just right plus the ice will float on the water, you can always just through ice cubes in ur res or even put ur rad in ice water for some suicide runs,
but be careful of condensation!
Dual Loop:
custom pvc res=>DDC3.2w/xspc acrylic top=>DDC 3.2 w/xspc acrylic top=>Black Ice Extreme GTX 360(3xUK 3000's pulling)=>mcr 120=>Apogee GT (bowed)=>res
DDC Ultra w/xspc res-top=>RX360(3x pana Ultras pulling)=>enzotech nb block=>Dtek GFX 2=>res-top
thehighlander123 is offline
post #4 of 84 (permalink) Old 01-06-2009, 12:21 PM
Science
BLKKROW's Avatar
please use basic chemistry if you use ice+water+salt, salt helps lower the freezing point of water so by placing ice in all of this you will get a lot lower temps
www.blackaero.com
Desktop
(12 items)
AMD 3900x
Aorus X570 Pro Wifi
Gigabyte 1660 Ti
HP 920 NVME 1TB
Corsair AX850
Operating System
Windows 10
Dell S2417DG
Keyboard
Mouse
Audio
Fiio DAC Amplifier
BLKKROW is offline
post #5 of 84 (permalink) Old 01-06-2009, 12:22 PM - Thread Starter
coolwhip's Avatar
lol no
it will be ice and water[or some other liquid] in a pot like dry ice is, than ill have a pump on the ground with the inlet in the pot and the outlet going to a bucket. when the pot starts to get to full of water, ill hit the pump to get a little out, so i dont spill any on my mobo.
coolwhip is offline
post #6 of 84 (permalink) Old 01-06-2009, 12:28 PM
Science
BLKKROW's Avatar
please please please for better temps use salt
www.blackaero.com
Desktop
(12 items)
AMD 3900x
Aorus X570 Pro Wifi
Gigabyte 1660 Ti
HP 920 NVME 1TB
Corsair AX850
Operating System
Windows 10
Dell S2417DG
Keyboard
Mouse
Audio
Fiio DAC Amplifier
BLKKROW is offline
post #7 of 84 (permalink) Old 01-06-2009, 12:29 PM - Thread Starter
coolwhip's Avatar
lol i think salt lowers the freezing temperature of the water, right?
coolwhip is offline
post #8 of 84 (permalink) Old 01-06-2009, 12:31 PM
Rep: 398 (Unique: 317)
No. It raises the freezing temp of water. Why else would we put salt on an icy sidewalk? Certainly not to make it 'more' frozen lol.
I stand corrected.
Lowering the freezing temperature (below the freezing temp of the air) will cause the ice to melt.
Slider46 is offline
post #9 of 84 (permalink) Old 01-06-2009, 12:33 PM
meticadpa's Avatar
Rep: 1389 (Unique: 894)
Screw the parents, get the dry ice
meticadpa is offline
post #10 of 84 (permalink) Old 01-06-2009, 12:34 PM
Rep: 91 (Unique: 84)
Please please please stop repeating that. I think the OP got you the first time.
And yes, salt has a lower freezing point than water. As such, mixing the two will result in a saline solution with a lower freezing point.
Wow......Just....wow.
http://en.wikipedia.org/wiki/Deicing
http://en.wikipedia.org/wiki/Sodium_chloride
E6400 @ 4GHz
So either, A) Your network is 100 Mb/s (in which case it'll take around 40 minutes instead of 30) or B) Your router sucks worse then a two dollar prostitute.
foobar2000 ► Zero DAC ► Little Dot MK III ► DT 880 600 Ω
cuy50 is offline
