My pot so far... - Overclock.net - An Overclocking Community
My pot so far...
post #1 of 21 (permalink) Old 04-20-2009, 02:07 PM - Thread Starter
Old to Overclock.net
Rep: 123 (Unique: 105)
Ok so I wanted to start bench runs but I was a little iffy about the cost of a dice pot alone and if it would be worth it, so I decide to make one on the cheap. Here it is so far.
The dice pot, made with a copper pipe fixture and the base is copper sheet metal soldered to the base.
Extremely thin after 1500 grit lapping, like less than 1mm, it's a mirror shine but there was crap on it so it's not so nice.
Inside of the pot, not so nice. There were stampings on the sheet metal and black stuff left from the blow torch.
1500 Grit lapped Core 2 Duo CPU. (dice run on this)
Cost.
400 - 600 - 800 - 1000 - 1500 Girt Sand Paper: $5
Blow Torch w/ Gas: $10
Copper Pipe Fixture: $5
Copper Sheet Metal: $5
Insulation Foam: $5 (not shown because I don't have a big pipe to mount the base in yet)
Total Cost so far: $30 USD.
Things left to do: Make a mount and mount a funnel pipe in the base
For the mount im going to take a few metal rods lying around, a piece of wood and an old CPU cooler blackplate + some nuts & bolts.
Only thing I have a hard time deciding is what to make the funnel pipe out of. You know that big pipe that sticks out where you poor acetone in w/ dice. I was thinking of a small PVC pipe to fit nice and snug in the base but I have concerned that it might crack under the cool temperature of dice but I seen some pro made pots that have a nice copper base with a PVC funnel pipe.
Should I go with a simple PVC pipe or go out of my way again, buy a big (and probably expensive) copper pipe and have to solder it to the base?
362436
(15 items)
AMD Ryzen 5 1600
Asus Prime X370-A AMD Ryzen AM4 DDR4
Gigabyte GeForce GTX 950
2x Corsair Valueselect 8GB 288 Pin DDR4 SDRAM DDR4 @ 2133
Corsair Force LS 2.5" 120GB SATA III MLC SSD
Optical Drive
Lite-On 24X SATA DVD/RW Optical Drive
Corsair RM550x 550W 80 Plus Gold
Noctua NH-L9A-AM4 Low-Profile
Antec NSK4100 Steel ATX Mid Tower
Operating System
Mint 18.2 x64
HP 24" LCD/LED 1920x1080
Keyboard
IBM PC-AT
Mouse
Logitech G5
Audio
Sennheiser HD650
Audio
Asus Essence STX II
xJumper is offline
post #2 of 21 (permalink) Old 04-20-2009, 02:17 PM
coolwhip's Avatar
Rep: 47 (Unique: 46)
looks good man ;]
cant wait to see your runs.
coolwhip is offline
post #3 of 21 (permalink) Old 04-20-2009, 02:18 PM
spartacus's Avatar
Rep: 154 (Unique: 138)
* Haha, funny title, esp. with it being 4/20/09 and all.
Looks awesome!
steam: a4erik
sc: spartacus:835
spartacus is offline
post #4 of 21 (permalink) Old 04-20-2009, 02:19 PM
like30ninjas's Avatar
Rep: 128 (Unique: 93)
oh, that type of pot ..
like30ninjas is offline
post #5 of 21 (permalink) Old 04-20-2009, 02:21 PM
you know its not going to work well right, you dont want a thin base. when you mount it, its just going to bow from the pressure and not make contact with the CPU very well, you need a more think base so its rigid and not flimsy.
G|F.E.A.D|Killa is offline
post #6 of 21 (permalink) Old 04-20-2009, 02:30 PM - Thread Starter
Looks awesome!
lol with Bob Marley's death anniversary all the "Medical" marijuana clubs were packed today. (California here)
That's what I thought but this one does not "bow" its very tight and does not "cave in" in any way.
362436
(15 items)
AMD Ryzen 5 1600
Optical Drive
Operating System
Mint 18.2 x64
Keyboard
IBM PC-AT
Mouse
Logitech G5
Audio
Sennheiser HD650
Audio
Asus Essence STX II
xJumper is offline
post #7 of 21 (permalink) Old 04-20-2009, 02:30 PM
once it gets cold, it will contract and pull up on you. yes it will work, but you will not get what you should be getting if you had a thicker base.
post #8 of 21 (permalink) Old 04-20-2009, 02:34 PM - Thread Starter
I could always find a way to reinforce it if it gave way. Anyway anybody have recommendations about what I should use for the funnel pipe?
362436
(15 items)
AMD Ryzen 5 1600
Optical Drive
Operating System
Mint 18.2 x64
Keyboard
IBM PC-AT
Mouse
Logitech G5
Audio
Sennheiser HD650
Audio
Asus Essence STX II
xJumper is offline
post #9 of 21 (permalink) Old 04-20-2009, 07:07 PM
PR1M3R's Avatar
Rep: 244 (Unique: 187)
Well, for the base, it needs thickness for a couple reasons. 1) to keep from bowing and "pulling up" as G|F.E.A.D|Killa said. 2) The more mass you have there the better your temps will be.
So, a good suggestion that worked well for someone here was to put a small handfull of BB's (1\\2" at bottom of pot) and solder them in with a bunch of solder.
And as for a funnel pipe, I just use the top of a gatorade bottle
But I have also seen people make them from sheetmetal, or wide mouth metal funnel slightly modded.
negative thinking makes bad things happen dont let noobs get you down!
PR1M3R is offline
post #10 of 21 (permalink) Old 04-21-2009, 05:11 PM - Thread Starter
Is it safe to use any plastic though or would it crack and leak rubbing alcohol all over my mobo.
362436
(15 items)
AMD Ryzen 5 1600
Optical Drive
Operating System
Mint 18.2 x64
Keyboard
IBM PC-AT
Mouse
Logitech G5
Audio
Sennheiser HD650
Audio
Asus Essence STX II
xJumper is offline
