Temps not cold enough? - Overclock.net - An Overclocking Community
post #1 of 11 (permalink) Old 03-30-2010, 12:32 PM - Thread Starter
87dtna's Avatar
Rep: 63 (Unique: 52)
Hey guys, this is my first crack at some dry ice action.
So I got a custom pot from Bartx, this one here-
http://www.xtremesystems.org/forums/...9&postcount=26
Got some ceramique, all the insulation blah blah etc. Filled the pot about 1/2 full with acetone, slowly added crush dry ice, bubbled a ton at first but then it calmed down so I added more and more until it was about 1'' from the top bubbling. Fired up the rig, did a few trial and error runs until I finally got 5.6ghz stable at 1.70 Vcore on my I3 540.
Now, my question is, why is my temps only showing -15c? I thought dry ice got you down to -60 to -70c easy. So why is it not getting that cold? Not even close!
87dtna is offline
post #2 of 11 (permalink) Old 03-30-2010, 12:35 PM
fshizl's Avatar
Rep: 142 (Unique: 113)
fshizl is offline
post #3 of 11 (permalink) Old 03-30-2010, 12:40 PM - Thread Starter
87dtna's Avatar
Originally Posted by fshizl View Post
possibly your mobo sensor...
have you tried using an actual temp gun?
I don't have one...
in the bios it says -25c for some reason
87dtna is offline
post #4 of 11 (permalink) Old 03-31-2010, 09:59 PM
kow_ciller's Avatar
Rep: 149 (Unique: 127)
Are you using pellets or are you smashing it up into almost powder-like?
Moar volts = moar megahurtz
Thermal Paste roundup
YAY HWBOT!
kow_ciller is offline
post #5 of 11 (permalink) Old 03-31-2010, 11:09 PM
NCspecV81's Avatar
remember to keep the pot stirred. However, once you go below 0 most software/cpu registers won't read it correctly and it will be dependent upon the cpu or the board where your temps will bottom out. Use a digital thermometer on the base of the pot for a better reflection of your actual temperatures.
NCspecV81 is offline
post #6 of 11 (permalink) Old 03-31-2010, 11:16 PM
nicko42004200's Avatar
Rep: 52 (Unique: 44)
yea the sensor will be inacurate below 0, a temp gum or a good wafer semsor calibrated under 0 is the only way i no of to get accurate temps below 0
nicko42004200 is offline
post #7 of 11 (permalink) Old 03-31-2010, 11:29 PM
voklskier4452's Avatar
Rep: 20 (Unique: 19)
as ncspec said a good digital thermometer with a ktype probe will be the best way to measure temps. Depending on the brand you go with it could either be very cheap or very expensive. Personally i went with the middle ground and picked up a UEI DT301 single input digital thermometer
voklskier4452 is offline
post #8 of 11 (permalink) Old 04-01-2010, 05:09 AM - Thread Starter
87dtna's Avatar
Yeah thats what I'm finding out.
I will invest in a thermometer with a type K thermocouple then.
Thanks guys. Will give rep to those who were actually helpful!
87dtna is offline
post #9 of 11 (permalink) Old 04-02-2010, 03:37 PM
Only use ~ 1/2" of acetone in the bottom of your POT... otherwise your just burning through DICE at record speed.... You want enough liquid to cover the entire internal base +a little bit more... but thats it, the more liquid, the harder it will be to keep it at a constant temp...requiring more DICE for the same CPU temp...
Took me a little while to get the hang of how much DICE/Acetone to use...but once you have got it figured out, your temps will improve, and your DICE will last much longer
CL3P20 is offline
post #10 of 11 (permalink) Old 04-02-2010, 07:24 PM - Thread Starter
87dtna's Avatar
Thanks! Plus, I found when using less acetone not as much gargles out when the DICE is first introduced!
87dtna is offline
