{Guide} Create a Gaming Virtual Machine - Page 57 - Overclock.net - An Overclocking Community
post #561 of 825 (permalink) Old 03-25-2013, 03:35 PM
powerhouse's Avatar
Rep: 22 (Unique: 13)
Originally Posted by lloyd mcclendon View Post
KVM currently 'sort-of' works with passthrough - it will assign and may even be picked up and work ok, but the code to 'reset' the card back to normal when the VM shuts off is currently not there. So if you shutdown your guest, your host will crash if you try to start the guest back up. I experienced this myself and there's plenty of other KVM users out there who have documented the same behavior, regardless of hardware selected. The card did actually work fine until I shut the guest off. I'd expect QEMU/KVM to have this code added in a year or two - I may switch back at that point, but lets see how XEN goes for a bit first.
Regarding NVIDIA, supposedly the 'quadro' series cards do support it, but whether or not anyone has gotten it to work is spotty at best. There are even some users out there who have used the 'nvflash' tool to hack in their custom built firmware updates with memory mappings built to support resetting the card. There's a neat pdf out there somewhere where the guy loosely outlines the steps to do this. I would never do this as it's a good way to brick your card ... say you type 0x00007A400000 instead of 0x0007A400000 rolleyes.gif
Also there are some blurbs out there that if you contact nvidia support they will send you patched firmware for the card, but when I called support they said this is misinformation and they have never offered said patches.
"nvidia has been the single worst company we've ever dealt with ... so nvidia, :bleep: you." -Linus
KVM: I've seen similar reports on the web (but have no hands-on experience).
Nvidia Quadro: I have the Quadro 2000 and it works great with VGA passthrough (as secondary GPU). Really easy! I had the Quadro 600 before and that one DOESN'T work! Nvidia has a line of professional cards that are specified "multi-OS" - just search for that and you'll get a list of all supported cards. They should work with VGA passthrough. That said, you would have to spend a LOT of money to get a Quadro card that's useful for gaming - most Quadro's aren't designed for that and deliver very mediocre benchmark results.
BUT, an hour ago I found this thread/post: http://www.eevblog.com/forum/projects/hacking-nvidia-cards-into-their-professional-counterparts/msg207550/#msg207550.
It turns out you can hardware modify consumer Nvidia cards to identify themselves as pro-cards, thus enabling the pro features as well as VGA passthrough. I really only read a few posts on that forum, but it looks very promising. Certainly this kind of hacking is for the adventurous among us.
Hardware:
Desktop: i7 3930K, Asus Sabertooth X79, 32GB Kingston 1600MHz RAM, PNY Quatro 2000 graphics adapter for Linux Mint host, Gigabyte GTX 970 graphics adapater for Windows 10 VM, Asus Xonar Essence sound card, Sandisk Extreme 120GB SSD for Linux, Samsung 850 EVO 250GB SSD for Windows, 4 hard drives for data, Corsair 500R chassis, Noctua CPU cooler, SeaSonic Gold PSU, NEC 2690WUXI2 screen, Linux Mint 18.2 Mate host OS, Windows 10 Pro in KVM VM, Logitech K780 multi-device wireless keyboard, Logitech MX Master multi-device mouse smile.gif
Notebook: Macbook 2010 edition with 8GB RAM
powerhouse is offline
post #562 of 825 (permalink) Old 03-25-2013, 03:40 PM
powerhouse's Avatar
Originally Posted by Virum View Post
Great answer. Im disappointed I did not get the 3770 instead of 3770k (Both are fantastic chips! But I didn't know I'd have this option of VM when i got it). Also there are a lot of con's I'm seeing in those nvidia articles.
Ill have to stick with Wine tweaking. Dual Booting for gaming is just too inconvenient. Every time i do it I find my self just defaulting to Windows despite my distaste of it.
CPU: Maybe you can exchange it with someone who has a 3770?
Nvidia: I just ran into this thread: http://www.eevblog.com/forum/projects/hacking-nvidia-cards-into-their-professional-counterparts/.
See also this post: http://www.eevblog.com/forum/projects/hacking-nvidia-cards-into-their-professional-counterparts/msg207550/#msg207550.
Haven't managed to read much, but this looks real cool.
Hardware:
post #563 of 825 (permalink) Old 03-26-2013, 04:25 AM
nbhusain's Avatar
Rep: 13 (Unique: 5)
No not really, like i mentioned in a previous post kvm will crash the host when doing vga passthrough if you dont bind your gpu to pci-stub before the radeon driver loads, i recently switched from arch + xen to opensuse + kvm because of xen poor power management options on my amd machine (suspend doesnt work, cool'n quiet crash my system, etc), and im passing though a radeon 6950 without issues, i can reboot or shutdown the vm as much as i want without a single crash, and it seems most of my performance issues in the past were related to ksm.
Here's how i bind my gpu:
First of all you need to build your kernel with pci-stub built-in or add the pci-stub module to your initrd, then you need to find out the ids of your card.
lspci
07:00.0 VGA compatible controller: Advanced Micro Devices [AMD] nee ATI Cayman PRO [Radeon HD 6950]
07:00.1 Audio device: Advanced Micro Devices [AMD] nee ATI Cayman/Antilles HDMI Audio [Radeon HD 6900 Series]
lspci -n
07:00.0 0300: 1002:6719
07:00.1 0403: 1002:aa80
So now you add this to your grub config file:
pci-stub.ids=1002:6719,1002:aa80
It will end up looking something like this:
linux   /vmlinuz-3.7.10-1.1-desktop root=/dev/mapper/system-root   resume=/dev/system/swap splash=silent quiet showopts iommu=1  pci-stub.ids=1002:6719,1002:aa80
dmesg | grep pci-stub
[    2.136667] pci-stub: add 1002:6719 sub=FFFFFFFF:FFFFFFFF cls=00000000/00000000
[    2.136674] pci-stub 0000:07:00.0: claimed by stub
[    2.136676] pci-stub: add 1002:AA80 sub=FFFFFFFF:FFFFFFFF cls=00000000/00000000
[    2.136682] pci-stub 0000:07:00.1: claimed by stub
Also there's some interesting development in the kvm + qemu camp using vfio-pci to get primary vga passthrough working on NVIDIA and AMD using secondary devices, here are the patches for qemu:
http://lists.gnu.org/archive/html/qemu-devel/2013-02/msg02758.html
http://lists.gnu.org/archive/html/qemu-devel/2013-02/msg02760.html
http://lists.gnu.org/archive/html/qemu-devel/2013-02/msg02759.html
nbhusain is offline
post #564 of 825 (permalink) Old 03-29-2013, 01:56 PM
powerhouse's Avatar
Hi guys (and gals). I just couldn't resist posting the Passmark results of my Windows 7 Pro 64 bit virtual machine running on the Xen hypervisor:
The only "weak" point is 3D graphics which is due to my graphics card, a Nvidia Quadro 2000. Actually, my 3D Graphics Mark (1,369) inside the VM is even better than the average performance for that card shown on Passmark (1,295) biggrin.gif - see http://www.videocardbenchmark.net/gpu.php?gpu=Quadro+2000.
Hardware:
post #565 of 825 (permalink) Old 04-06-2013, 05:40 AM
Dh0mp5eur's Avatar
Rep: 0
Hello
I use KVM on Debian Sid with a i7 3770 Asus P8Z77-M and HD7970 for the VM.
It works perfectly.
But I can't restart my VM.
I enable pci-stub in grub
GRUB_CMDLINE_LINUX="intel_iommu=on pci-stub.ids=1002:6798,1002:aaa0"
dmesg |grep pci-stub
[    0.000000] Command line: BOOT_IMAGE=/boot/vmlinuz-3.8-trunk-amd64 root=UUID=4e436466-36c9-45a9-a455-2ad879c7baaf ro intel_iommu=on pci-stub.ids=1002:6798,1002:aaa0 quiet
[    0.000000] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-3.8-trunk-amd64 root=UUID=4e436466-36c9-45a9-a455-2ad879c7baaf ro intel_iommu=on pci-stub.ids=1002:6798,1002:aaa0 quiet
kvm   1:1.1.2+dfsg-6
qemu-kvm     1.1.2+dfsg-6
Dh0mp5eur is offline
post #566 of 825 (permalink) Old 04-06-2013, 10:07 AM
nbhusain's Avatar
Rep: 13 (Unique: 5)
You need to have the pci-stub module compiled built-in in the kernel or inside your initramfs, you should see something like this:
[    0.000000] Command line: BOOT_IMAGE=/vmlinuz-linux-nb root=/dev/mapper/system-root ro iommu=1 pci-stub.ids=1002:4391,1002:6719,1002:aa80 acpi_sleep=s3_bios,s3_mode quiet
[    0.000000] Kernel command line: BOOT_IMAGE=/vmlinuz-linux-nb root=/dev/mapper/system-root ro iommu=1 pci-stub.ids=1002:4391,1002:6719,1002:aa80 acpi_sleep=s3_bios,s3_mode quiet
[    2.087342] pci-stub: add 1002:4391 sub=FFFFFFFF:FFFFFFFF cls=00000000/00000000
[    2.087350] pci-stub 0000:00:11.0: claimed by stub
[    2.087363] pci-stub: add 1002:6719 sub=FFFFFFFF:FFFFFFFF cls=00000000/00000000
[    2.087371] pci-stub 0000:07:00.0: claimed by stub
[    2.087375] pci-stub: add 1002:AA80 sub=FFFFFFFF:FFFFFFFF cls=00000000/00000000
pci-stub has to grab the card before the radeon module otherwise your system will crash
nbhusain is offline
post #567 of 825 (permalink) Old 04-06-2013, 12:57 PM
Dh0mp5eur's Avatar
Rep: 0
I loaded the pci-stub in the initramfs.
I blacklisted radeon module.
But I still can't restart my VM.
[    1.031665] pci-stub: add 1002:6798 sub=FFFFFFFF:FFFFFFFF cls=00000000/00000000
[    1.031671] pci-stub 0000:01:00.0: claimed by stub
[    1.031675] pci-stub: add 1002:AAA0 sub=FFFFFFFF:FFFFFFFF cls=00000000/00000000
[    1.031680] pci-stub 0000:01:00.1: claimed by stub
post #568 of 825 (permalink) Old 04-06-2013, 02:59 PM
nbhusain's Avatar
Rep: 13 (Unique: 5)
Does the host crash in your case?
nbhusain is offline
post #569 of 825 (permalink) Old 04-06-2013, 03:15 PM
myweb's Avatar
Rep: 0
Dear all,
I faced with passthrough issue of NVIDIA GT640 on the following configuration:
Intel(R) Core(TM) i5-3470
AsRock Z77 Pro4
Ubuntu Raring (Kubuntu 13.04 Beta 2)
xen-hypervisor-4.2.1
/etc/modprobe.d/xen-pciback.conf
blacklist nvidia
options xen-pciback hide=(0000:01:00.0)(0000:01:00.1)
/etc/modules
xen-pciback
dmesg | grep pcib
[    0.000000] Command line: placeholder root=UUID=cf9f10d5-40d6-41fe-8e10-b7801ef3b87e ro intel_iommu=on xen-pciback.passthrough=1 xen-pciback.hide=(0000:01:00.0)(0000:01:00.1) quiet splash
[    2.165897] Kernel command line: placeholder root=UUID=cf9f10d5-40d6-41fe-8e10-b7801ef3b87e ro intel_iommu=on xen-pciback.passthrough=1 xen-pciback.hide=(0000:01:00.0)(0000:01:00.1) quiet splash
[    5.444046] pciback 0000:01:00.0: seizing device
[    5.444055] pciback 0000:01:00.1: seizing device
[    5.444238] pciback 0000:01:00.0: enabling device (0000 -> 0003)
[    5.450089] xen-pciback: backend is passthrough
Guest OS is Windows 7. Win7 recognized videocard, Nvidia driver was installed, but device manager show Yellow Triangle with Exclamation Mark and Error Code 43.
Could you please clarify are there any chances to get working Nvidia gt640 under xen guest?
Also I am planing to use another Linux guest as movie player (HTPC) since Nvidia hardware acceleration is better than ATI, but right now Ubuntu guest with NVIDIA GT640 hang up during boot.
myweb is offline
post #570 of 825 (permalink) Old 04-06-2013, 03:35 PM
nbhusain's Avatar
Rep: 13 (Unique: 5)
You need need patches to get vga passthrough working with NVIDIA cards on xen or kvm, take a look at http://www.davidgis.fr/blog/index.php?2011/12/07/860-xen-42unstable-patches-for-vga-pass-through, u'll find patches to get nvidia cards working under xen, for kvm, there's some experimental patches on the qemu-devel mailing list from april 1.
nbhusain is offline
