VERY VERY Strange mem usage problem, PLEASE help!! - Overclock.net - An Overclocking Community
post #1 of 16 (permalink) Old 11-01-2018, 10:25 AM - Thread Starter
newls1's Avatar
Rep: 46 (Unique: 34)
i just got finished installing a clean install of win10. Loaded all drivers, and necessary programs. After all was done (just like the 56473 times in the past after doing this) sitting at the desktop NOTHING running in background mem usage is 2.1gb.. Completely NORMAL. First program I loaded was ADIA64 to check memory stability just to make sure mem is stable at XMP settings, system loaded all 32gb (as it has 57465 times in the past) all was stable after 30mins testing, I hit "Stop" and exiting program, and for whatever reason I looked at mem usage again in task mrg and it is dead set on 5gb... Thought that was weird, so i rebooted, once back into windows, i went back into task manager and still reading 5gb sitting at an idle desktop, NOTHING RUNNING IN BACKGROUND.. I have tweaked my background tasks to have only important stuff going (Like ive done 5765 times in the past) FOr some reason something is doubling my normal mem usage at idle and cant figure it out! HELP ME PLEASE!!! Anything I can do to flush/purge mem while at desktop?? Clueless here as ive never had this happen before.
OS is CLEAN AND FRESH and all windows updates auto loaded. Win is version 1803.
Please, any help you can provide would be greatly appreciated
EDIT** No matter how many times i restart or shut off pc completely, as soon as win10 boots back to desktop, its dead set @ 5gb mem usage sitting idle on desktop
**Intel System** Asus Z390E Strix / 8700k @ 4.85Ghz / 32GB BDie @ 3200 CL14 / PowerColor 5700XT / eVGA 850w PSU / Sammy 960 EVO m.2 / MX500 250gb games SSD / 49" Samsung UltraWide 144Hz
**Games Only** Asus Maximus Formula XII / i9 10900k @ 5.3GHz / 32gb 4x8GB Patriot Viper DDR4 4400 @ 4133 / 2080Ti / Everything watercooled using Dual Loops and many 420mm rads
newls1 is offline
post #2 of 16 (permalink) Old 11-01-2018, 10:36 AM
Amiga 500
mAs81's Avatar
Rep: 151 (Unique: 112)
See if this works;
Type regedit in search,then go to
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Contro l\Session Manager\Memory Management
double click on ClearPageFileAtShutDown and change the value to 1
reboot
Enthoo Evolv
(21 items)
Air 240
(16 items)
Transformer Book
(10 items)
i7 4790K
Asus Gryphon Z97 Armor Edition
msi 1070 Ti Gaming
Hyper X Savage
Samsung 840 Pro
Samsung 840 Pro
WD Red
WD Black
Cooler Master V850
Corsair H75
Phanteks Enthoo Evolv mATX TG
Operating System
Windows 10 Pro
Dell U2713HM
Samsung Syncmaster P2470HD TV monitor
Keyboard
Magicforce 68 - Gateron Red Switches
Mouse
Logitech G502 Proteus Core
Mousepad
Corsair Vengeance MM200 Extended
Audio
Creative Gigaworks T40 SeriesII
Audio
FiiO Olympus 2 E10K
Audio
Beyerdynamic DT 990
Other
Phankteks Halos and RGB strip 40cm
i5-4670
ASRock z97m Pro4
SAPPHIRE R9 290 Vapor-X OC 4Gb
Corsair Vengeance Pro
Mushkin Triactor 120gb SSD
HGST Travelstar 7k1000 1Tb
Corsair HX620W
Cryorig C7
Corsair SP120 Purple LED X4
Corsair Carbide Air 240 White edition
Operating System
Windows 10 Pro
Samsung UE46D6500 46" 3D LED smart TV
Keyboard
Anne Pro-Gateron Blues
Mouse
Connect IT Ci-156
Audio
Sony DAV-DZ860W Home Theater
Other
BitFenix Alchemy 2.0 60cm RGB Magnetic LEDs
Intel Atom Quad Core Z3740 (1.33-1.86GHz)
Intel HD Graphics(Ivy Bridge)
2 GB DDR3
32 GB eMMC
OCZ Vertex 4 128gb
Kingston 16Gb Micro SD
iPearl mCover Hard Shell Case - Blue
Operating System
Windows 10 Home 32-bit
10.1" IPS (1368 x 768)
Mouse
Logitech M560
mAs81 is offline
post #3 of 16 (permalink) Old 11-01-2018, 11:03 AM
deepor's Avatar
Rep: 485 (Unique: 330)
If you can't see any process using this in the task manager, go to the "performance" tab and click on "open resource manager" at the bottom of the window. That "resource manager" tool might show more about what's using memory.
Could you share screenshots?
deepor is online now
post #4 of 16 (permalink) Old 11-01-2018, 03:16 PM - Thread Starter
newls1's Avatar
Quote: Originally Posted by mAs81 View Post
See if this works;
reboot
i did what you said, and it took longer then normal to reboot, then once back in windows, same mem usage... This is a side effect from a update from windows. I just "RE" Formatted again, and after i did the updates, that is when the mem usage got doubled... damn it ms, ***. I tried to remove the updates, but it wont let me remove 2 out of the 5 it downloaded, and im sure its one of those 2 that is the issue that I cant remove.
newls1 is offline
post #5 of 16 (permalink) Old 11-01-2018, 03:18 PM - Thread Starter
newls1's Avatar
i looked all around in here and couldnt figure it out.. thanks tho
newls1 is offline
post #6 of 16 (permalink) Old 11-01-2018, 03:21 PM
Linux Noob
Beagle Box's Avatar
Rep: 41 (Unique: 37)
Get a copy of the Microsoft Utility autoruns and see what's being loaded up on startup.
https://docs.microsoft.com/en-us/sys...loads/autoruns
I did Latty's Linux Challenge and I now run Linux!
The Beagle Box
(12 items)
Intel Core i7 8086K
MSI Z370 Gaming M5
MSI GeForce GTX 1080 Gaming X 8GB
G.Skill Flare X 16GB 2 x 8GB DDR4-3200 PC4-25600 CL14 Dual Channel
Samsung 960 EVO 500GB MLC V-NAND PCIe Gen 3 x4 NVMe M.2 2280 Internal SSD
Samsung 970 Pro 512GB MLC NAND M.2 2280 PCIe NVMe 3.0 x4 Internal Solid State Drive
EVGA SuperNOVA 1000P2 1000 Watt 80 Plus Platinum Modular ATX Power Supply
Swiftech 220X2
Corsair ML120 Pro White LED Magnetic Levitation 120mm Case Fan
Corsair ML120 Magnetic Levitation 120mm Case Fan
Corsair Vengeance C70
Operating System
Linux Mint Cinnamon 19.0
Beagle Box is offline
post #7 of 16 (permalink) Old 11-01-2018, 03:28 PM - Thread Starter
newls1's Avatar
thank you! I will try it out
newls1 is offline
post #8 of 16 (permalink) Old 11-01-2018, 03:30 PM
farmdve's Avatar
Rep: 22 (Unique: 22)
And I suggest using this Microsoft utility https://docs.microsoft.com/en-us/sys...ownloads/vmmap AND https://docs.microsoft.com/en-us/sys...wnloads/rammap
It shows very intimate information about the Virtual Memory usage.
Current
(5 items)
i7-8700k
ASRock Z370 Extreme4
GTX 1070
Corsair
Fractal XL R2
farmdve is offline
post #9 of 16 (permalink) Old 11-01-2018, 03:47 PM
porksmuggler's Avatar
Rep: 1 (Unique: 1)
Also, maybe on a hunch, after you shut down, switch off the power supply or disconnect from power completely for a bit before restarting. Curious to see if that changes the memory usage immediately after startup. Even without any hib/standby/etc, as you may know Windows 10 has powered down functionality.
porksmuggler is offline
post #10 of 16 (permalink) Old 11-01-2018, 03:50 PM
farmdve's Avatar
Another thing could be pre-fetching e.g the Superfetch service.
Current
(5 items)
i7-8700k
GTX 1070
Corsair
Fractal XL R2
farmdve is offline
