Know of any more tweaks to reduce input lag?(W10 and W7) - Overclock.net - An Overclocking Community
post #1 of 4 (permalink) Old 04-21-2019, 03:48 AM - Thread Starter
RamenRider's Avatar
Rep: 5 (Unique: 4)
As we all know W10 gimps gaming and system performance. However this was not always the case around 2015 the gaming performance of W10 as actually really good. But something changed around october 2016 that affected both nvidia and amd gpu's performance. They no longer push out frames as fast anymore, and the inclusion of "Fullscreen Optimization" also lowered app performance. However there are some tweaks out there that can revert some of the performance loss.
Things that affect input lag:
Your monitor settings.
Your monitor cable.
https://www.reddit.com/r/Amd/comment..._might_have_a/
Your OS settings/registry/ect. Process Lasso and Project Mercury might help especially for Ryzen CCX performance.
https://www.reddit.com/r/BattleRite/..._with_project/
Your application settings: disable fullscreen optimization or aero for win7.
I also just found this amazing reg mod that boosted my frame delivery performance by 25-50%. If you have AMD gpu I definitely recommend downloading Radeon Mod. It is akin to Nvidia Profile Inspector.
https://www.reddit.com/r/Amd/comments/92uqph/radeonmod/
"Here's the (ocasionally) updated pastebin version of all the tweaks i found that do something on AMD GPUs. AMD GPU Performance REG for 19.1.1+
I got banned from google+ for posting links to this as .reg files, which is ridiculous btw. It's ok, G+ is dead anyway.
(UPDATED 14/03/2019 for bugfixes. Should work now.)
I tested this with a RX 580 V1 MSI OCed to 1425core 2250mem 50% power limit and with disabling the 300mhz memory P0 state in overdriveNTool, great performance. I also added some DVRanalytics keys to disable in case you enabled AMD User Experience improvement program. Driver latest 19.3.2 tested on Windows 10 1809 October Update, AMD Ryzen 5 2600X, 16gb of RAM PC."
Theres also this other radeon reg file that you can try out as well. https://www.reddit.com/r/Amd/comment...m_medium=web2x
Does anyone know of any other REGEDIT optimization that I can possibly do? Especially on the MMCSS?
https://www.reddit.com/r/killerinsti...ur_windows_10/
Whenever someone is suggesting a change to \Games they always say: "In the same Registry hive as the above tweak, you can also change the priority of Games. To implement this tweak, go to HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Multimedia\SystemProfile\Tasks\G ames and change the following registry values:
“GPU Priority” change its values to 8 for gaming.
“Priority” set to 6 for gaming."
However on the microsoft website it says:
"Priority REG_DWORD The task priority. The range of values is 1 (low) to 8 (high).For tasks with a Scheduling Category of High, this value is always treated as 2."
https://docs.microsoft.com/en-us/win...eduler-service
>_>
Oh last but not least, MSI Utility. You can configure MSI line interupts manually but MSI utility just so much more convenient. https://forums.guru3d.com/threads/wi...rrupts.378044/
The utility was updated recently and now you can add priorities towards each device as well, however I just don't know which settings are the most beneficial yet.
Also there still seems to be some performance increase by disabling HPET for ryzen systems(in BIOS).
If you know any more performance tweaks please don't be shy. Especially registry tweaks.
Input-Lagpilled Current Rig FX-8320/50, MSI 390/XFX 270, Corsair Vengeance 16gb 2400mhz, EVGA BQ 750w. You'll find me on the OG input lag thread.https://www.overclock.net/forum/6-in...l#post28260384
Or at r/AMD https://community.amd.com/message/29...ZLWotL_8b8hvA8 or Twitch https://www.twitch.tv/ramenrider/
RamenRider is offline
post #2 of 4 (permalink) Old 04-21-2019, 04:07 AM
Nizzen's Avatar
Rep: 141 (Unique: 62)
The best tweak is to buy Intel cpu with 4000+mhz memory. Low latency is the main key Same with low inputlag monitor.
My opinion
CPU24/7) 7980xe - 7900xMOBO: ASUS Rampage Apex x299 / Asrock Taichi x299RAM: 4x 3600c15 / 4x4266c19/ 4x4000 c17 GPU: 2x MSI tri X 2080ti / 1060tiSTORAGE: Areca 1883i HDD R6 + Samsung 850PROs R0 - 3x SM961 nvme 1TB - 3x Intel Optane 900p 480GBCASE: LD cooling V8 R/B / ld cooling reverse R/BMonitor: Acer x34 /Asus 27 AQ 4k g-sync / Asrock x570 Taichi / 3900x
Nizzen is offline
post #3 of 4 (permalink) Old 04-24-2019, 06:08 AM - Thread Starter
RamenRider's Avatar
Rep: 5 (Unique: 4)
Ehh idk, Intel is iffy for me cause I understand the company as being used for nefarious purposes like the Israeli equivalent of Huawei. https://www.timesofisrael.com/israel...-in-amd-chips/
Spectre, Meltdown, and this new one Spoiler are all critical Intel vulnerabilities and patching them causes a bunch of performance loss. However I read there is a google developed patch that can fix them without much or any performance loss so we'll see where it goes. Also it's just because I prefer the price/performance aspects of buying AMD.
post #4 of 4 (permalink) Old 04-24-2019, 01:17 PM
Rep: 0
https://youtu.be/ZZ7H1WTqaeo
its worth noting when microsoft implemented those patches from google into there test branch a lot of useres reported serious prefromance issues on both AMD and intel and the patch shouldent have even been active on AMD
neptunia is offline
