Triple Screen Issue - Overclock.net - An Overclocking Community
Triple Screen Issue
post #1 of 14 (permalink) Old 04-07-2020, 09:31 AM - Thread Starter
RBorowik's Avatar
Rep: 3 (Unique: 3)
Triple Screen Issue
I have been running triple screens for a few years without issue, today I have been experiencing an issue that I can't find the source of it. Could anyone help?
I have a RX 580 graphics card with three monitors running from it, two on HDMI and one on DVI. Any combination of two monitors will work fine but not three, they just flicker to a black screen, make the connected / disconnected sounds and repeat before I can look at display settings.
I have reinstalled the graphics card drivers, tried every combination of monitor and cable and couldnt find an issue with any of them.
Any ideas?
RBorowik is offline
post #2 of 14 (permalink) Old 04-07-2020, 10:02 AM
Back at it again.
Avacado's Avatar
Rep: 100 (Unique: 75)
Ditch the DVI for a DP?
22643 Time Spy https://www.3dmark.com/3dm/46344026?
https://folding.extremeoverclocking....e.php?u=207393
White Lightning
(12 items)
i7 9700k @ 5.1GHz 1.385v
ASUS Prime Z390-A
Evga 2080 Ti Black Gamer
32GB GSkill TridentZ DDR4 3600
2 x 1 TB Samsung EVO 970 Raid 0
EVGA 1000w
Corsair H150i Pro
CORSAIR Crystal 570X White Mid Tower
Operating System
Windows 10 Home
Alienware 1900R 34.1" @ 120Hz
Keyboard
Loigitech G910
Mouse
Logitech G700s
Avacado is offline
post #3 of 14 (permalink) Old 04-07-2020, 10:05 AM
Food Editor
skupples's Avatar
Rep: 720 (Unique: 378)
GURU3D DISPLAY DRIVER UNINSTALLER from safe mode. then GURU3D Clean Drivers (if they do it for AMD too?)
then at that point, start troubleshooting physically (wires) s
Add me on Steam, same name
Best R0ach Quote of all time : TLDR: Haswell might be the last legit gaming platform unless mice get their own non-USB interface on some newer architecture.
skupples is offline
post #4 of 14 (permalink) Old 04-07-2020, 10:12 AM - Thread Starter
RBorowik's Avatar
Rep: 3 (Unique: 3)
I have already uninstalled the driver, rebooted the pc, confirmed it was back on the crappy windows included driver and then downloaded and installed the driver again.
I have swapped cables, all work desperately and together but when all are plugged in together its like they fight to be the primary monitor or something.
RBorowik is offline
post #5 of 14 (permalink) Old 04-07-2020, 10:13 AM - Thread Starter
RBorowik's Avatar
Rep: 3 (Unique: 3)
I don't have a display port on the other monitor and up until this afternoon it was working fine in this configuration for nearly three years.
RBorowik is offline
post #6 of 14 (permalink) Old 04-07-2020, 10:14 AM
Bench, Dead, Squat
Bad5ector's Avatar
Rep: 23 (Unique: 16)
What are your display options saying? Do you see one showing as disabled?
ShadowMoses
(21 items)
i7 7700K
ASUS ROG Maximus IX Formula LGA1151
EVGA GeForce GTX 1080 Ti Founders Edition
Corsair Vengenace Lpx 32GB DDR4 3200MHZ
Seagate ST1000DX001 SSHD 1TB 3.5in SATA3 64MB Cache Internal Solid State Hybrid Drive
Kingston HyperX Predator 240GB
EVGA SuperNOVA 1000 G1 80 Plus Gold Certified 1000W Fully Modular
RAD - EK-CoolStream XE 360
CPU Block - EK-Supremacy EVO - Nickel
GPU Block - EK-FC Titan X Pascal - Nickel
Pump / Res - EK-XRES 140 Revo D5 PWM (incl. sleeved pump)
Fans - 3 x EK-Vardar F4-120ER (2200rpm)
Coolant - EK-Ekoolant Pastel BLUE (concentrate 250mL)
Tubing - EK-DuraClear 11,1/15,9mm
Thermaltake Core P3 SE Snow Edition
Operating System
Microsoft Windows 10 Pro 64Bit
BenQ XL2720Z 27in LED 144HZ 1ms GTG FPS Gaming Monitor
42" LG TV
Keyboard
Corsair Gaming K65 Lux RGB Compact Mechanical Keyboard
Mouse
Corsair Gaming M65 Pro RGB Optical Gaming Mouse
Mouse
Corsair Gaming MM300
Bad5ector is offline
post #7 of 14 (permalink) Old 04-07-2020, 10:16 AM
Food Editor
skupples's Avatar
do you have a restore point?
skupples is offline
post #8 of 14 (permalink) Old 04-07-2020, 10:20 AM
Back at it again.
Avacado's Avatar
Second this. Also, I have had different ports on a GPU "Go Bad"
Maybe an adapter? is 10$ worth the try?
https://www.amazon.com/DisplayPort-A...xpY2s9dHJ1ZQ==
White Lightning
(12 items)
ASUS Prime Z390-A
EVGA 1000w
Corsair H150i Pro
Operating System
Windows 10 Home
Keyboard
Loigitech G910
Mouse
Logitech G700s
Avacado is offline
post #9 of 14 (permalink) Old 04-07-2020, 10:21 AM
Food Editor
skupples's Avatar
always good to start at ground level.
skupples is offline
post #10 of 14 (permalink) Old 04-07-2020, 10:28 AM - Thread Starter
RBorowik's Avatar
Rep: 3 (Unique: 3)
With two monitors connected everything in there looks fine, once the third is plugged in I dont get a chance to look as the screens flicker between the settings of connected and not so quickly that its not possible.
RBorowik is offline
