Overclock.net - An Overclocking Community - View Single Post - Laptop for gaming.
View Single Post
post #6 of (permalink) Old 02-08-2019, 09:32 PM
nora01
Rep: 0
Hey there i think your budget is little low i sugget you to increase your budget and one more thing i suggest you is you have to buy new laptop instead of second hand or used. Because second hand laptops did not work well. If you can increase your budget upto $500 than you have many options like Acer Aspire E 15, Core i3 8th gen, 6GB Dual Channel or Lenovo 330, Core i5 8th gen, 8GB DDR3 or ASUS VivoBook F510UA, Core i5 8th gen, 8GB DDR4 you can check other laptops on link below.
https://bestcartadvisor.com/best-gam...top-under-500/
nora01 is offline
