Overclock.net - An Overclocking Community - View Single Post - Car ac radiator and extreme over clocking question
View Single Post
post #11 of (permalink) Old 03-23-2019, 12:47 PM
white owl
white owl's Avatar
Rep: 136 (Unique: 103)
At the very least I'd get a cheapo block from aliexpress or similar. Something actually made to be fit to a CPU would be ideal and wouldn't cost much more. There is little performance difference between cheap chinese CPU blocks and expensive ones but make sure you get one with some sort of channels over the CPU.
Quote: Originally Posted by SpeedyVT
If you're not doing extreme things to parts for the sake of extreme things regardless of the part you're not a real overclocker.
Quote: Originally Posted by doyll View Post
The key is generally not which brands are good but which specific products are. Motherboards and GPUs are perfect examples of companies having everything from golden to garbage function/quality.
Hot n Bothered
(12 items)
4790k 4.7Ghz
Asus Sabertooth Z97 MkII 2
EVGA GTX 1080 SC
16gb G.Skill Sniper 2400Mhz
2x Kingston v300 120gb RAID 0
WD Blue
Seasonic 620w M12 II EVO
Cooler Master 212 Evo
Corsair 450D
Operating System
Windows 10
Nixeus EDG27
Other
I have pretty lights.
white owl is offline
