Overclock.net - An Overclocking Community - View Single Post - [Official] NVIDIA RTX 2080 / SUPER Owner's Club
View Single Post
post #380 of (permalink) Old 05-05-2019, 06:44 AM
fleps
Overclock Enthusiast
fleps's Avatar
Rep: 5 (Unique: 5)
Quote: Originally Posted by R3van View Post
i didnt seen any 2080 with more than 1.068v, so this has simething to do with the card/bios.
it is a evga ftw3? which pl do you have on this card?
The FTW3 is a 338W card, but that's not the reason, usually cards wont use max voltage even with the slider maxed out if you just use + Mhz OC mode, that how Boost works.
In order to maximize OC since series 10, you need to use Curve mode as the tutorial explains. If I just use + Mhz mode it doesn't go past 1050mV and don't reach the same OC.
Serie 20 max vcore is 1093mV, but at 1093mV perfCap will stay locked on "voltage", which I personally don't like as I have a feeling it affects performance, so I use one step down, which is 1087mV.
I did the same thing on a 2080 Ventus OC, so nothing to do with the card.
Of course is possible that a simpler card will yell Power on perfCap at 1087mV depending on the application, the Ventus OC peaked it's TDP (250W) on a few games at max vcore.
» Intel i7 8700K 4.8Ghz | » EVGA CLC 280 watercooler | » Asus MAXIMUS X HERO | » AdataXPG Spectrix D80 4x8GB 4000Mhz CL17
» EVGA RTX 2080 FTW3 Ultra OC: 2175/8250 @ Kraken G12/x42 | » Dell S2716DG 27' 144Hz G-Sync (DP) + LG 49UJ6525 4K [email protected] (HDMI)
» Sentey 80 Plus Gold 1000W | » Thermaltake Core x71 TG | » Windows 10 Pro 1709 build 16299.1059
fleps is offline
