Overclock.net - An Overclocking Community - View Single Post - Sffpc build recommendation for rendering
View Single Post
post #7 of (permalink) Old 07-31-2019, 04:18 PM - Thread Starter
kevindd992002
kevindd992002's Avatar
Rep: 85 (Unique: 67)
Quote: Originally Posted by AlphaC View Post
If RTX 2070 and RTX 2060 Super are the same price go for RTX 2070 as the RTX 2060 Super is a cut down RTX 2070 (TU106 GPU die). Normally those are $400 though.
The lowest I'd go is with RTX 2060 non-Super which is $330-350ish these days , that has 192-bit memory bus and 6GB GDDR6 VRAM. I don't think you're going to find anything worthwhile in the long run at $300 , because on the gaming GPU side that's GTX 1660 Ti and on the professional side it's Quadro P1000 which is below GTX 1050 level (it's a GP107 with 640 CUDA). There might be lower Turing parts in the pipeline since on notebook/mobile there are RTX 3000 (TU106 die with 2304 CUDA similar to RTX 2070, 6GB GDDR6 on 192-bit memory bus), T2000 (TU117 die , 4GB GDDR5 VRAM so not worth it) and T1000 parts. Normally all Quadros are around 2x the gaming counterparts due to binning for significantly lower power.
(https://www.anandtech.com/show/14421...-for-notebooks)
If it's Autodesk with Revit architecture and rendering is involved the Ray tracing cores are going to accelerate the workflow so much that GTX 1660 Ti is pointless.
I see what you're saying. So in general the 2070 is still better than the 2060 Super?
Would I want a Quadro card for my sister's use case though? I have zero knowledge about Quadros, sorry.
Sent from my SM-G950F using Tapatalk
My Rig
(14 items)
Intel® Core™ i7-8700K
ASUS ROG MAXIMUS X CODE
EVGA GeForce GTX 1080 Ti FTW3 GAMING
G.SKILL F4-3200C14D-16GTZKW TridentZ Series
Samsung 970 EVO NVMe (OS Drive)
Samsung 850 EVO
SeaSonic Platinum-760 (SS-760XP) Power Supply
Custom Watercooling Loop
Phanteks Enthoo Evolv ATX Glass
Operating System
Microsoft Windows 10 Enterprise
Dell S2716DG Gaming Monitor
Keyboard
Ducky Shine 3
Mouse
Roccat Savu
Mousepad
Steelseries Qck
kevindd992002 is offline
