First time build help please - Page 2 - Overclock.net - An Overclocking Community
post #11 of 22 (permalink) Old 01-05-2015, 04:51 PM
Rep: 375 (Unique: 249)
OP - original poster.
Download HWMonitor or some other program that checks temperatures, and see what it reports. Then fire up something like Prime95 or IBT and see what the temps are then. If the heatsink is on there wrong, you probably won't get a chance, though, because it will BSOD or spontaneously reboot in seconds.
If you pass everything, then move on to Memtest86+ and test the RAM.
jsc1973 is offline
post #12 of 22 (permalink) Old 01-08-2015, 12:19 AM - Thread Starter
nkirky77's Avatar
Rep: 0
Max temp was 33degrees max voltage 1.24
nkirky77 is offline
post #13 of 22 (permalink) Old 01-08-2015, 03:41 AM
daviejams's Avatar
Rep: 33 (Unique: 24)
that is idle temperature. Put the CPU under load using prime 95 and watch its temperature
daviejams is offline
post #14 of 22 (permalink) Old 01-08-2015, 03:45 AM - Thread Starter
nkirky77's Avatar
Rep: 0
It was under load with prime95 and intelburn never rose above 33degrees
nkirky77 is offline
post #15 of 22 (permalink) Old 01-08-2015, 03:54 AM
dynod123's Avatar
Rep: 0
It's not your CPU then. test your RAM and GPU. if you had spare RAM you could swap it out and see if that works.
dynod123 is offline
post #16 of 22 (permalink) Old 01-08-2015, 03:56 AM - Thread Starter
nkirky77's Avatar
Rep: 0
Tested ram on 8 passes on memtest86
nkirky77 is offline
post #17 of 22 (permalink) Old 01-08-2015, 04:39 AM
daviejams's Avatar
You've done something wrong. No CPU stays at 33 degrees when running prime95. Try it again
post #18 of 22 (permalink) Old 01-08-2015, 05:02 AM - Thread Starter
nkirky77's Avatar
Rep: 0
Im going to reseat cpu and maybe try stock fan instead of watercooled.
nkirky77 is offline
post #19 of 22 (permalink) Old 01-08-2015, 07:03 AM - Thread Starter
nkirky77's Avatar
Rep: 0
Im using antec liquid cooler would that be reason its low under stress
nkirky77 is offline
post #20 of 22 (permalink) Old 01-08-2015, 09:14 AM - Thread Starter
nkirky77's Avatar
Rep: 0
Ok so stock heatsink and fan back on running 4.2ghz. I just done intelburn and hetes results
nkirky77 is offline
