First time build help please - Overclock.net - An Overclocking Community
post #1 of 22 (permalink) Old 01-04-2015, 05:03 PM - Thread Starter
nkirky77's Avatar
Rep: 0
So i will start with a hello and just let you allknow im a complete noob. But i have done my first build and my pc keeps rebooting after 10mins of gaming and im confused as to why. My rig is
Amd fx 4300 3.8ghz
Msi gtx 770 twin frozr
Antec water cooler
Gigabyte 970a-ds3p mobo
8gb 1600mhz crucial ballistic ddr3
Corsair cx600 PSU
is the psu the problem here ? Causing the freezing and reboots ?
Thanks in advance
nkirky77 is offline
post #2 of 22 (permalink) Old 01-04-2015, 05:17 PM
Mirotvorez113's Avatar
Rep: 23 (Unique: 21)
First thing to check are the temperatures, especially on the CPU. Download HWmonitor and let us know what are the temps on everything.
http://www.cpuid.com/softwares/hwmonitor.html
Mirotvorez113 is offline
post #3 of 22 (permalink) Old 01-04-2015, 05:25 PM - Thread Starter
nkirky77's Avatar
Rep: 0
The cpu has cooler which changes colour when hot which it never has got really but i can check them in morning. Why wats your thoughts ? Thanks for reply
P.s is the psu worthy of running it all ??
nkirky77 is offline
post #4 of 22 (permalink) Old 01-04-2015, 06:13 PM
PSU is good, but it could have issues anyways. Could also be faulty ram. It is not just the cpu that can be overheating, gpu also and possibly the motherboard itself. Just check the temps and if thats all normal, than try a different psu if you have one available.
Also, what hdd/ssd you got?
post #5 of 22 (permalink) Old 01-04-2015, 06:23 PM
hammong's Avatar
Rep: 447 (Unique: 349)
Definitely need to test the RAM with Memtest86+ (test it overnight, should have NO errors in the morning).
Next, test the CPU with something like prime95, or you could set up [email protected] and let it run for a few hours at full-speed to see if you have any basic CPU issues. Keep a close eye on CPU core temps with HWINFO64 or CORETEMP while you do this.
If the RAM and CPU test ok OUT, then you're looking at GPU issues. Try installing EVGA PrecisionX and set up a FAN profile at 80% and play your games. It's going to be loud (the GPU fan, that is) - but it will keep your GPU temp pretty low. If stable, then you might need to check the thermal paste on the GPU/Heatsink.
Finally, while it's unlikely, it could be a PSU issue. A lot of people poo-poo on the Corsair CX series, but personally I haven't had any issues with them. There's always a bad apple in every basket though.
Greg
hammong is offline
post #6 of 22 (permalink) Old 01-04-2015, 10:18 PM - Thread Starter
nkirky77's Avatar
Rep: 0
What temps do i class as normal when im testing ? Thanks for your replies
nkirky77 is offline
post #7 of 22 (permalink) Old 01-05-2015, 12:23 AM - Thread Starter
nkirky77's Avatar
Rep: 0
500gb sata seagate i think it is
nkirky77 is offline
post #8 of 22 (permalink) Old 01-05-2015, 01:11 AM - Thread Starter
nkirky77's Avatar
Rep: 0
Yea s
Originally Posted by bigdonkeydik View Post
It all bout da pus. Ya get me fam. Tha blud claat keep overloadin an protek itself from danger. Bit like da donkeydik wearin a condom. Ya get me bredrin.
yea sorry chipolata dont talk grime
nkirky77 is offline
post #9 of 22 (permalink) Old 01-05-2015, 10:18 AM
daviejams's Avatar
Rep: 33 (Unique: 24)
I bet the OP has not put the cooler on the CPU properly , it's getting too hot and rebooting to protect itself
daviejams is offline
post #10 of 22 (permalink) Old 01-05-2015, 04:25 PM - Thread Starter
nkirky77's Avatar
Rep: 0
Forgive me im new to all this. What is OP ? And there spring type screws on there so shouldnt it give equal tension ? Thanks for replies
nkirky77 is offline
