Maximum safe voltage for i7-3770K - Page 2 - Overclock.net - An Overclocking Community
post #11 of 20 (permalink) Old 07-08-2016, 07:49 PM
More Vcore
The EX1's Avatar
Rep: 107 (Unique: 99)
Max safe voltage is always an ongoing argument. For what it is worth, I have been running my 4770k at 1.425v for 2 years and it has never had a problem. Still passes stress tests at the same speed and voltage it always has. I do run a custom loop however and the CPU rarely sees above 60c. It usually stays in the low 50s while gaming.
IMO 1.4v is a good stopping point for the i7s and i5s with nice cold water flowing over them.
Test Bench
(14 items)
1920X Threadripper
ASUS ROG Zenith Extreme
ASUS RX 560 Strix
ASUS RX 560 Strix
ASUS RX 560 Strix
G.Skill Tridentz DDR4
Western Digital Blue M.2
EVGA 1600 G2
Noctua NH-U12S TR4-SP3
Corsair SP120s
Corsair AF140
Corsair 780T White
Operating System
UNRAID
ASUS VG245H
ASUS VG245H
ASUS VG245H
Keyboard
RAZER Black Widow Ultimate
Keyboard
RAZER Black Widow Ultimate Overwatch Edition
Keyboard
Logitech G15
Mouse
Razer Naga
Mouse
Steelseries Warcraft MMO Mouse
Mouse
Logitech G502
Audio
Razer Kraken 7.1
Other
USB Hubs/extensions/cables
Intel Core i7 6950X
ASUS ROG Rampage V Edition 10
nVidia Titan Xp Collector's Edition Galatic Empire
Corsair Special Edition Blackout Dominator DDR4
Samsung 960 EVO M.2 NVM.e
Crucial MX300 SSD
OCZ SSD
Corsair HX1000i Platinum
Custom red sleeved cables
EK RGB Monoblock
Alphacool Monsta 360mm Radiator-White
Hadwarelabs NEMESIS GTX 560mm Radiator
Noiseblocker 120mm PWM fans-White
Noiseblocker eLoop 120mm fan-Red
Noctua Industrial 140mm fans
Phobya Slim 180mm fans
Swiftech D5 Pump
Bitspower D5 pump top
Bitspower D5 pump mod kit
Singularity Computers Ethereal Dual Reservoir mounts
Monsoon Free Center compression fittings
Bitspower Deluxe White fittings
Primochill Grillz Hex radiator grill
Primochill Advanced LRT Tubing
Koolance in-line filter
XSPC G 1/4 temperature sensor
Silverstone PWM fan hub
EK M.2 Heatsink - Nickle
FrozenQ LFX Reservoirs - White
FrozenQ LFX Aluminum Reservoir collars
Silverstone TJ11
Custom acrylic panels
Operating System
Windows 10
Alienware AW3418DW Ultrawide
Keyboard
GALAX HOF
Mouse
Razer Starcraft II Edition Mouse
Mousepad
GALAX RGB Mousepad
Audio
ASUS Supreme FX Hi-Fi DAC
Audio
Sennheiser Game Zero - White
Other
NZXT USB 2.0 internal hub
Other
NZXT Hue+
Other
Darkside LEDs and extensions
Ryzen R7 1800X
ASUS ROG Crosshair VI
Powercolor RX Vega 64 Red Devil
RX Vega 64 Limited Edition
GALAX HOF Limited Edition DDR4
Western Digital Black
Optical Drive
ASUS Blu-Ray/DVD-RW
EVGA 750 GQ
EVGA 750 GQ
Deepcool Captain 240mm
Primochill Praxis Wet Bench
Operating System
Windows 10
The EX1 is offline
post #12 of 20 (permalink) Old 07-09-2016, 06:07 PM
Rep: 24 (Unique: 23)
try get more out of your ram
going up from 1600c9 could get you much more in games than another 300mhz higher cpu oc if you get far enough
http://forums.anandtech.com/showthread.php?t=2455994
im running my 3770k at 4.5ghz 1.375v on a custom loop at sub 60c
before deliding with vise\hairdryer method it was at 4.2ghz 1.3v 85c
4.8ghz wouldnt boot at 1.5v
4.7ghz ran 3dmark at 1.425v
Dasa is offline
post #13 of 20 (permalink) Old 08-19-2016, 12:57 PM
7ha7a5ian's Avatar
Rep: 0
Whispers I'm currently running mine at 1.45v at 4.78 Ghz.... For the past 6 months..... Benchmarking both GPUs and CPUs.... One a custom loop of course. All depends. At this point what I'm doing is out of curiosity. My temps range from 30c idle to 100c for benchmarks like Intel burn in test or Prime95 or Cinebench and Asus ROG Benchmark program. Vasrious results and still pushing to see about hitting that 5Ghz range. I was running this at 4.5Ghz at 1.4v ever since this chip was released.
7ha7a5ian is offline
post #14 of 20 (permalink) Old 02-08-2018, 01:19 PM
Rep: 0
This is an old thread but I wanted to chime in too. I need 1.43v just to hit 4.5Ghz stable overclock on my 3770K. But I've been running it like that for years, 24/7. I use an AIO liquid cooler too but it has a 280mm radiator so it has no issues keeping it under 80C. I definitely didn't hit the lottery on my chip, but to this day, with DDR3 2400 CL 10, and a GTX 1080ti this thing still runs screaming fast when gaming at 4K. I'm still tempted everyday by the new 8700K, but screw RAM pricing right now!!
Autonomic Archer is offline
post #15 of 20 (permalink) Old 04-05-2018, 05:15 PM
gabeomatic's Avatar
Rep: 1 (Unique: 1)
This really makes me think, like how did people really hit 5ghz with these chips at under 1.5v? After upgrading to the h80v2 and delidding the chip, I was always running my 3770k at 4.7ghz @ 1.35v, but the bump up to 4.8 requires 1.44v. The law of diminishing returns really applies here. Fortnite, CSGO and a few other games push one of my cores to 72C which is honestly fine imo..repeated cinebench runs get the chip to 74C. I am not pushing this chip hard for hours on end so I'm not too worried.
Using a Maximus V Formula. (I also lowered my PPL voltage to 1.55v and it helped a bit with temps as well.)
My old vengeance 1600mz ram seems slow now, anyone have any oc tips? Haven't really fiddled with memory speeds and timings yet. (2x16gb C9)
gabeomatic is offline
post #16 of 20 (permalink) Old 12-03-2018, 03:20 AM
Rep: 0
Well Im currently running my 3770k at 4.7ghz @ 1.24v so I guess it's just silicon lottery. (Checked CPU-Z and it reads 1.27v though I have the voltage set to 1.24v. Turns out this was a problem with software OC and now that I set OC in bios its running at a stable 1.24v)
webguy2003 is offline
post #17 of 20 (permalink) Old 05-22-2019, 02:45 PM
somethingbrite's Avatar
Rep: 0
Silicon lottery - I have a 3770k which will do 4.9 at 1.265v and the temps peak at 61c (hottest core) under Prime95 load and 5.0Ghz at 1.330v - but that reaches 66c
De-lidding, lapping the IHS and using liquid metal between die and IHS have all helped with the temps but I also got very lucky with the silicon lottery with that chip.
Sent from my ONEPLUS A6013 using Tapatalk
Monolith is turning into the PC which spends most of its life never being built!
somethingbrite is offline
post #18 of 20 (permalink) Old 06-02-2019, 06:49 PM
Kamikazi's Avatar
Rep: 2 (Unique: 2)
Not sure if it was totally dubbed but he said safe max is 1.45 vcore. Of course its not written in stone. Here's the thing if you have LLC on ultra high or god forbid Extreme then it will spike over that setting in bios. Ok say 4.50v set in the bios, but the LLC will spike it over when required (to prevent vdroop) to usually about 1.448v so bear that in mind. I have had 3 3770k's, all oc'd. The 1st was a 5.0Ghz job, vcore was 1.455 but I ran it a year like that. The next chip would not go beyond 4.9Ghz no matter what I threw at it voltage wise but it still was prime 12 stable at 1.385v a good chip. 3rd was already 6 years old by then and best I could manage was 4.8 @ 1.365 a decent chip but 4.9 was still crashing even at 1.440v. I'm giving it one more shot, this time at 1.445 which is right at the limit and prob 1.448 with LLC. CPU current capability is 140% and LLC is ultra high to hopefully manage the v-droop. Last attempt tonight, will update.
Here's a goodie, I have windows desktop gadgets installed on my desktop, these are like the 'Canary in the coal mine' if you see them freeze or disappear you can bet a fail is close at hand, even priming the margins show no errors or workers stopped but those little gadgets are sensitive enough to alert you of any instability. Keep an eye on them, if they act weird forget what you have in bios and add voltage before an imminent crash.
Kamikazi is offline
post #19 of 20 (permalink) Old 06-02-2019, 06:51 PM
Kamikazi's Avatar
Rep: 2 (Unique: 2)
Not sure if it was totally dubbed but he said safe max is 1.45 vcore. Of course its not written in stone. Here's the thing if you have LLC on ultra high or god forbid Extreme then it will spike over that setting in bios. Ok say 4.50v set in the bios, but the LLC will spike it over when required (to prevent vdroop) to usually about 1.448v so bear that in mind. I have had 3 3770k's, all oc'd. The 1st was a 5.0Ghz job, vcore was 1.455 but I ran it a year like that. The next chip would not go beyond 4.9Ghz no matter what I threw at it voltage wise but it still was prime 12 stable at 1.385v a good chip. 3rd was already 6 years old by then and best I could manage was 4.8 @ 1.365 a decent chip, but 4.9 was still crashing even at 1.440v.
Kamikazi is offline
post #20 of 20 (permalink) Old 08-02-2019, 06:28 AM
b0uncyfr0's Avatar
Rep: 2 (Unique: 2)
Im just about to delid mine and i'm sitting at 4.6Ghz at 1.24v so i think i have some headroom. 4.8 at 1.35v would be really awesome.
b0uncyfr0 is offline
