Maximum safe voltage for i7-3770K - Overclock.net - An Overclocking Community
post #1 of 20 (permalink) Old 06-28-2016, 04:00 PM - Thread Starter
SauronTheGreat's Avatar
Rep: 5 (Unique: 5)
I am running my i7-3770k @ 4.5Ghz , 1.31V and i also have a corsair h115i AIO cpu cooler. i want to take my cpu to 4.7 just want to know the maximum safest voltage.
Corsair Obsidian 900D
ROG Maximus XI Core
Intel i9 - 9900k
Gigabyte RTX 2080 Aorus Xtreme
ROG Swift PG27AQ 4K G - Sync / Samsung s27d590
G.Skill Trident Z RGB 32GB 3200Mhz
Corsair AX1200i
SauronTheGreat is offline
post #2 of 20 (permalink) Old 06-28-2016, 04:04 PM
Iwamotto Tetsuz's Avatar
Rep: 76 (Unique: 52)
Temps are more important than voltages. Making sure that your cpu, motherboard nb,sb and vrms are kept cool
Overcloking is about the passion, not about how much you clock
Overclocking is not about the pefromance gains, it is about the passion
Overclocking is about the Fun, Enjoyment and Passion
Pushing Voltages And Lower Tempertures Makes You The Overclocking Champion
Iwamotto Tetsuz is offline
post #3 of 20 (permalink) Old 06-28-2016, 04:07 PM
165 Hz
Cyclops's Avatar
Rep: 682 (Unique: 476)
Actually, voltage is far more important than temperature. You can degrade a CPU within minutes with high enough voltage even if you're using LN2.
For ivy bridge, you want to keep it bellow 1.35V. 1.38V should be the cut off, with anything over 1.4V bringing degradation in a few months depending on usage.
No Bottlenecks
(22 items)
LAN Rig Revision 4
(21 items)
File Server
(10 items)
6700K @ 4.7 GHz
Gigabyte Z170X Gaming 7
MSI GTX 1080 TI Sea Hawk EK X @ 2.1 / 12 GHz
32GB G.SKILL Ripjaws 3333 MHz 15-14-14-34-2T
Samsung 960 Pro 1TB
WD Red 8TB NAS
Optical Drive
Go away
Raidmax RX-700AT 80+ Titanium
EK-FB GA Z170X Monoblock
EK/MSI Waterblock/Backplate
2 * Dazmode Darkside LP360
MCP355 DDC @ 7V
9 * Noctua NF-P12
Fractal Design Define S
Operating System
8.1 Pro
ASUS ROG Swift PG279Q
2 * BenQ GW2765HT
LG 34UM58-P
Keyboard
Corsair Vengeance K60
Mouse
Logitech G502 Proteus Core
Mouse
HyperX Fury S Pro XL
Audio
Asus Xonar DSX
4770K @ 4.5 GHz 1.3V
Maximus VI Gene
ASUS GTX 1080 Reference
16GB G.Skill Sniper 2600 MHz 11-14-14-14-2T 1.65V
Intel 750 400GB PCIe
Seagate Barracuda 8TB
Optical Drive
I will end you
EVGA SuperNova 750 G2
Dazmode Darkside Maple Leaf Special Edition
EK GTX 1080 Reference Block
Feser TFC Admiral 240
Black Ice GTX Xtreme M92
6 * Silverstone SST-FN121-P
2 * Noctua NF-B9 Redux
NZXT Vulcan (With Attached Handle)
Operating System
8.1 Pro
Dell S2417DG YNY1D
Samsung U28D590D
Keyboard
Mouse
Logitech G500
Mouse
XTRAC PADS Ripper XXL
E5-2670
Supermicro X9SRA
64GB Samsung ECC 1333 MHz
Mushkin Ventura Pro 32GB (Boot)
10 * 6TB HGST Deskstar NAS (RAID Z2)
Optical Drive
I will harm you
Corsair RM650 (Passive)
Corsair H60
Fractal Design Define R5
Operating System
FreeNAS 9.10
Cyclops is online now
post #4 of 20 (permalink) Old 06-28-2016, 04:10 PM
Jen-Hsun Huang fanboy
Lex Luger's Avatar
Rep: 72 (Unique: 64)
You should be able to run 4.6 safely. I dont know about 4.7 though which will probably require close to 1.4+.
Lex Luger is offline
post #5 of 20 (permalink) Old 06-28-2016, 04:24 PM - Thread Starter
Rep: 5 (Unique: 5)
what did you mean when you said 1.38V should be the cut off ?
ROG Maximus XI Core
Intel i9 - 9900k
Corsair AX1200i
post #6 of 20 (permalink) Old 06-28-2016, 04:34 PM
Lex Luger's Avatar
Just keep in under 1.4 volts and don't stress test with something like Intel Burn Test.
Use Asus Real Bench for 2 hours and you should be set if it passes.
I learned the hard way with IBT. It will definitely shorten the life of your CPU at higher voltages.
post #7 of 20 (permalink) Old 06-28-2016, 04:36 PM - Thread Starter
Rep: 5 (Unique: 5)
i have been stress testing with Prime95 blend tests , i have reached 1.38V but prime95 shuts down which is a sign of in stability frown.gif
ROG Maximus XI Core
Intel i9 - 9900k
Corsair AX1200i
post #8 of 20 (permalink) Old 06-28-2016, 04:49 PM
Marc79's Avatar
Rep: 107 (Unique: 90)
With Ivy I wouldn't go above 1.35 vcore under load, Haswell 1.3v with sandy and the new skylake stay at or below 1.4v under load.
Marc79 is offline
post #9 of 20 (permalink) Old 07-08-2016, 02:05 PM
CravinR1's Avatar
Rep: 983 (Unique: 749)
When I was researching the 3770k overclocking it seems they said less than 1.3v for 24/7
R7 [email protected] EVGA GTX1070ti https://valid.x86.fr/tim79f
R7 [email protected] 290 reference (soon to be MSI 980ti) https://valid.x86.fr/f8vusi
R7 [email protected] Gigabyte RX480 8gb https://valid.x86.fr/r5kdfu
R5 [email protected] XFX RX570 4gb https://valid.x86.fr/hqatp1
Asus G75vw
(9 items)
Finally Ivy
(16 items)
3700x
MSI X470 Gaming Plus
EVGA 1070ti 8gb
G.Skill 16gb FlareX 3200mhz
Samsung 1tb m..2
Samsung 860 EVO 500
WD 3tb
Seasonic 1050x
Gammax 400
Coolermaster Masterbox
i7-3610QM
Asus Laptop
Nvidia GTX 660m 2gb
16 gb 1600mhz (4x4gb)
Samsung 850 EVO 500 gb
Seagate 750gb 7200rpm
Optical Drive
Asus DVDRW
Operating System
Windows 7 x64
17.3" 1080P
Intel 3770K 4.5 ghz 1.29v
Gigabyte GA-Z77X-UD3H
Sapphire Tri-X 290
G.Skill SNiper Gaming Series 16 gb (2x8gb) 1866mhz
G.skill Ares 8 gb (2x4gb) 2400mhz
Samsung 840 EVO 250
Toshiba 3tb x2 (6tb)
Optical Drive
LIte-On 20X DVDRW
Seasonic X-1050
Corsair H90
Cooler Master HAF 912
Operating System
Windows 7 Pro x64
HP w237ld 23" 1080P
Viewsonic VG2230wm 22"
Keyboard
SK-1788
Mouse
Logitech G400
CravinR1 is offline
post #10 of 20 (permalink) Old 07-08-2016, 02:24 PM
Slink3Slyde's Avatar
Rep: 154 (Unique: 124)
Been running my 3570k at 1.328 ish volts under max load most of the time since 2012. Even Folded on the CPU for a year or so, as well as a fair amount of gaming.
Id be happy with around 1.35v if temps are in check. Some people have even push closer to 1.4 24/7, but that depends on how easy it is for you to replace it if it or the motherboard does pop.
4.6 at 1.31 is good, if you cant get 4.7 for 1.35ish Id just stick with that, its not a difference you would notice IMO.
In the future everyone will be Ozymandias for 15 minutes. Or something.
Unrelated to other Slinkies.
Slink3Slyde is offline
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
