i7 6950x overclock not applying - Overclock.net - An Overclocking Community
post #1 of 3 (permalink) Old 11-15-2018, 12:21 PM - Thread Starter
CryWolf's Avatar
Rep: 0
Hello guys.
Last year I have found the perfect overclock for me wich gave me performance and good temperatures for gaming and some hard work.
But this week I have noticed some performance down and for my surprise my overclock profile was not working right. I have set all cores for 4.2ghz with avx offset at auto but my computer is running at 3.5ghz on all cores and 4.0ghz on core 2, the one with the *. In the BIOS the overclock profile is set but when Windows is running it does not work.
I tried setting another profile, did not work. Tried to set BIOS to its default and set the desired profile again, did not work. Tried the CLEAN CMOS taking the CMOS battery out and changing the jumper for 30 seconds or more and overclocking it all again, did not work. The result is always the same, it seeems fine in the BIOS but in Windows it only runs at 3.5ghz at all cores and 4.0ghz in core 2*.
My computer setup is:
CPU: Intel i7-6950x 3.00GHz
GPU: ZOTAC GTX 1080 TI AMP EXTREME!
MOBO: ASUS Rog Strix X99 Gaming
Liquid Cooler: Corsair H115i
Memory: Corsair Vengeance LED (4x8GB) 3200Mhz DDR4
M.2 SSD: Samsung 970 EVO 2TB
SSD: Kingston UV400 480GB
SSHD: Seagate SATA III (2x2TB em RAID 0)
Power Supply: XFX 1250W
I will attach 23 images that wich is my overclock profile and BIOS setup.
Please guys, give me some guidance. I have no idea why this is happening.
Thank you.
CryWolf is offline
post #2 of 3 (permalink) Old 11-16-2018, 10:05 AM - Thread Starter
CryWolf's Avatar
Rep: 0
Found the problem
Ok guys, I found the problem and I will leave my solution here for others in need.
After a lot of research I found that some people were having the same issue after a windows update that updated the processor micro code and, for some reason, f*cked peoples OC. I'm running windows 10 version 1709 and the update that did this for me was the KB4090007. Just unnistall this update and be happy again with your OC.
And don't forget to block the update. I did it with WUMT Wrapper Script.
I hope this helps someone.
Quote: Originally Posted by CryWolf View Post
Hello guys.
Thank you.
CryWolf is offline
post #3 of 3 (permalink) Old 11-16-2018, 10:23 AM
Overclocker in training
ThrashZone's Avatar
Rep: 47 (Unique: 37)
Hi,
You could of read through the broadwell-e thread to get another way too
https://www.overclock.net/forum/5-in...l#post27694318
Vaper
(4 items)
i9-99400x With evo and koolance vrm water blocks
ASUS x299 TUF Mark 2
Samsung 850 Pro 256gb for os and 500gb evo for favorite games plus other wd hdd's for data and backup's
Optical Drive
LG Blu-Ray WH16NS40
evga 1200P2
Operating System
ASUS VG248QE 24" 144Hz
Keyboard
Logitech G910 Orion spectrum
Mouse
redragon
Audio
Insignia 2.0 soundbar HSB318
i7-5930k with evo and koolance vrm water blocks
X99 Sabertooth
EVGA 1000w P2
Operating System
AOC G2460PG 24"G-Sync 144Hz
Mouse
Red Dragon
Audio
eLeaf MELO-3 4ml
SMOK Alien 220w
Operating System
VapeWild RazzleBerry 50-50-3mg
ThrashZone is offline
Tags
asus rog strix x99 gaming , Cpu Overclocking , i7 6950x , Overclock , problem
