Help: Computer shuts off randomly and restarts. - Overclock.net - An Overclocking Community
post #1 of 4 (permalink) Old 11-16-2018, 01:16 AM - Thread Starter
A.K.A. Droptimus
iPDrop's Avatar
Rep: 36 (Unique: 30)
It is very rare but it's happened twice now in the past two weeks in the middle of a game. I don't know why I'm thinking maybe my cpu got too hot the first time so I lowered the clocks from 5ghz to 4.8ghz but it happened again with the lower clocks. is there a way to find out what made it shut off?
my specs are:
8700k @ 4.8ghz & +90 offset voltage
asrock z370 extreme4
16gb PNY anarchy x ram 3200mhz
gigabyte windforce oc rtx 2080 ti (stock clocks)
corsair h115i pro
seasonic focus plus 750w
samsung 970 evo m.2 boot drive
Intel Core i9-9900K
ASRock Z370 Extreme4
GIGABYTE RTX 2080 TI WindForce OC 11GB
PNY Anarchy X 16GB 3200MHz
Samsung 970 EVO NVMe M.2 1TB
Samsung 850 EVO SATA 256GB
Seagate IronWolf NAS 4TB
Seasonic FOCUS Plus Series SSR-750FX
Corsair Hydro H115i Pro
NZXT S340VR Elite
Operating System
Windows 10
Acer Predator X27
ASUS VP28UQG
Keyboard
CORSAIR - K68
Mouse
Corsair Harpoon
Mousepad
Razer Goliathus Speed Cosmic
Audio
Razer Tiamat
Other
Arozzi Arena Gaming Desk - Pure Black
Other
OFM Gaming Chair
iPDrop is offline
post #2 of 4 (permalink) Old 11-16-2018, 02:01 AM
Senior OCN Member
shilka's Avatar
Rep: 2728 (Unique: 1621)
Is the pump on the CLC cooler running?
Also which games does the PC crash in?
And last dont know if you have heard or not but some of the early RTX 2080 Ti cards are having tons of problems
https://www.techpowerup.com/249603/n...graphics-cards
Seravee
(29 items)
Intel Core I7 6850K
Gigabyte X99 Ultra Gaming
EVGA GTX 1080 FTW2
Kingston HyperX DDR4 Savage 3000 MHz
Samsung 840 Evo 500 GB
Samsung 860 Evo 1 TB
Seagate Ironwolf Pro 8 TB
Seagate Ironwolf 12 TB
WD Ultrastar DC HC530 14 TB
Seagate Ironwolf Pro 12 TB
Optical Drive
LG CH12NS30
EVGA SuperNova G2 750 watt
Noctua NH-D15S
Phanteks Enthoo Luxe Tempered Glass
Operating System
Windows 7 Ultimate 64 bit
Operating System
Windows 10 Home 64 bit
Asus PG279Q
LG 55C8 OLED TV
Keyboard
Corsair Strafe RGB MK.2 with Cherry MX Silent
Mouse
Roccat Kone EMP
Mouse
HyperX Fury S XL
Audio
Sennheiser HD 598
Audio
Onkyo TX NR646
Audio
Dali Opticon Vokal
Audio
x2 Dali Opticon 2
Audio
x2 Dali Opticon 1
Audio
Dali E12 F Subwoofer
Audio
Sennheiser HD-599
Other
CableMod E series PSU cable set
shilka is offline
post #3 of 4 (permalink) Old 11-16-2018, 02:21 AM - Thread Starter
A.K.A. Droptimus
iPDrop's Avatar
yes I've heard but my card is doing just fine unless it's what caused the two restarts...
The pump should be running as my temps seem reasonable considering the voltage... I'm not sure what game was running the first time it happened but today it was Starcraft II
Intel Core i9-9900K
NZXT S340VR Elite
Operating System
Windows 10
Acer Predator X27
ASUS VP28UQG
Keyboard
CORSAIR - K68
Mouse
Corsair Harpoon
Mousepad
Audio
Razer Tiamat
Other
Other
OFM Gaming Chair
iPDrop is offline
post #4 of 4 (permalink) Old 11-16-2018, 04:07 AM
Dillmiester's Avatar
Rep: 85 (Unique: 76)
This is one of the most hard to track down problems Ive ever had to deal with, I had a freinds PC doing this that literally took me days to try to figure out. A while back like 2 years ago it did it but was alleviated by changing graphics drivers. I think the underlying issue was there just took time to get worse.
We replaced the cheap Thermaltake PSU with a Seasonic 650 Platinum, that didnt cure the problem, tried different sticks of ram, that didnt fix it, changed bios settings, changed drivers, reinstalled Windows, took his graphics card to a family members that was fine, ran it without the gpu, same, tried a different motherboard, did the same thing, tried unplugging everything but the minimum like drives, no change.
I was about ready to pull my hair out.
All in all never really completely pinned it down but what else could it be besides the CPU? (3570k)
Bringing the OC and voltage way down would alleviate the problem until one day a couple weeks ago he called me to say the computer wouldnt boot, tried everything to get it to boot, my freind ended up saying lets just rebuild and he upgraded to a 9600k with Maximus XI Hero, everything has been fine since.
I guess the only thing left to do is drop my family members 2500k in his board and see if it boots again then we will know for sure.
One thing I found interesting when rebuilding was the Thermalright Le Grand Macho comes with a plastic insert spacer that goes around the pcb of the cpu that is specifically for LGA 1151 socket, this is what they say,
http://thermalright.com/product/1151...upport-spacer/
"After seeing the photos and reports of Skylake PCB deformation on internet, Thermalright decided to address the issue. It appears the LGA1151 may have some potential problems dealing with the mounting pressure and / or weight of heavier aftermarket coolers (over 500g as specified in intel LGA1150 socket Application Guide). In our endeavour for excellence Thermalright is trying to lower the possibility of this happening by developing a spacer to fill the open area between the load plate and PCB to hold it tightly in place. The spacer fits onto CPU with a 0.5mm raised surface around the IHS fitting snugly on CPU PCB when load plate is latched down."
The 9600k doesnt have room for this spacer, one thing I noticed is that one day during my diagnosis when I pressed down on the Hyper 212 the computer immediately shut down was this coincidence? Maybe these cpu's that aren't soldered the IHS is digging into the substrate or pressing on the core too hard, I dont know.
Dillmiester is offline
