New build, hard freeze after left idle - Page 2 - Overclock.net - An Overclocking Community
post #11 of 29 (permalink) Old 04-09-2019, 12:21 AM - Thread Starter
Pochi_D's Avatar
Rep: 22 (Unique: 20)
Quote: Originally Posted by xSneak View Post
Ok. Go to windows power options and disable it under pcie settings (link power state management).
Does it matter if your video output turns off or not (under powet settings)?
Try clean driver install for gpu, use a different port on the gpu or try another cable.
Are there any error under windows event viewer?
Thanks for the help.
I actually completely forgot about that setting. I'll give that a try.
There are no errors under windows event viewer, only non-critical or unrelated logs about 30mins after the system is mostly idle (eg. after rendering).
Pochi_D is offline
post #12 of 29 (permalink) Old 04-09-2019, 08:43 PM - Thread Starter
Pochi_D's Avatar
I've tried every suggestion but unfortunately I have the same freeze everyday and restarts sometimes go through 4-8 boot loops until it goes into windows..
I also have occasional hard freezes when doing something minimal - the screen artifacts and gets stuck like that.
Really don't know what to do,
any help would be appreciated.
Pochi_D is offline
post #13 of 29 (permalink) Old 04-09-2019, 09:25 PM
I Love this Hobby!
Gunderman456's Avatar
Rep: 612 (Unique: 504)
Maybe defective RAM. Test your RAM with Memtest or use one stick for a day or two then the other one. Also try different slots as it maybe the mobo.
Also check in Bios if the mobo set the right specs (XMP Clocks/Timings/Volts) for your RAM.
-Guide to 1st Case Modding for Better GPU(s) Performance/Cooling-
https://www.overclock.net/case-mod-wo...ing-guide
-Guide to 2nd Case Modding for Better GPU(s) Performance/Cooling-
https://www.overclock.net/case-mod-wo...e-fan-mod
Fast n' Cheap
(17 items)
Bit'O'Heaven
(16 items)
RYZEN 7 3700X
ASUS TUF GAMING X570-PLUS
MSI Radeon RX 5700 XT
G.SKILL Ripjaws V Series 32GB (2x16GB) DDR4 3600 16-19-19-39 CL 16 1.35V
Corsair Force Series Gen.4 PCIe MP600 500GB NVMe M.2 SSD
Seagate BarraCuda ST3000DM008 3TB 7200 RPM 64MB Cache SATA 6.0Gb/s 3.5" HDD
Optical Drive
LG 16X SATA Blu-Ray Internal Rewriter with 3D Playback and M-DISC Support BH16NS40
Fractal Design Ion+ 860P 80 PLUS Platinum Certified 860W Full Modular
Noctua NH-D15
Veddha GriderCase alpha V1
Operating System
Win 10 Pro 64bit
Nixeus EDG 27" IPS Freesync 1440p 144Hz
Keyboard
Redragon K589 SHRAPNEL RGB Mechanical Keyboard
Mouse
Logitech G502 Hero
Mousepad
ALLSOP Redmond Mouse Pad
Audio
Cambridge Soundworks 5.1
Other
PulseLabz Challenger Gaming Chair
Intel i7 4770k @ 4.5GHz
Asus Maximus VI Rog Gene
Gigabyte AMD R9 290 @ Core 1160MHz & Memory 1350MHz
G.SKILL Trident X DDR3 16GB 2400MHz
Samsung 840 PRO 256GB
Seagate Barracuda 7200.14 3TB
Optical Drive
Pioneer Black Blu-ray 16X BD-R 2X BD-RE
EVGA SuperNOVA G2 1300W 80PLUS Gold Fully Modular
Corsair H60 Push/Pull
PC-JMK5-Cool 5 Open Frame Case
Operating System
Win 7 Pro 64bit
Samsung 245BW 24" 1200p 60Hz
Keyboard
Logitech G15
Mouse
Logitech MX518
Mousepad
Corsair Vengeance MM200
Audio
Yamaha HTR-5830 Polk Audio 3.0
Intel Core i5-3570K @ 4.6GHz
ASRock Z77E-ITX mITX
Sapphire AMD HD 7990 @ Clock 900MHz & Memory 1100MHz
G.SKILL Ripjaws X DDR3 8GB 1600MHz @ 1866MHz
Crucial SSD CT128M4SSD3 128GB mSATA SATA III 6GB
Seagate Barracuda HDD 1TB
Optical Drive
LG DVD R/W
Corsair Professional Series Gold AX850 Fully Modular
Corsair Cooling Hydro Series H100
BitFenix Prodigy Mini-ATX Black Case
Operating System
Win 7 Pro 64bit
Samsung TV 52"
Keyboard
Logitech K330 Wireless
Mouse
Logitech M215 Wireless
Mousepad
Audio
Yamaha RX-V681 PSB/PolkAudio 5.1
Gunderman456 is offline
post #14 of 29 (permalink) Old 04-10-2019, 11:36 PM - Thread Starter
Pochi_D's Avatar
I have tested each ram separately with no fails in memtest but only in one slot so far. I will give it a shot when I can.
Beginning to think it is the motherboard. Right now I'm in the middle of a long-term project so it is a little hard to debug thus I've come up with a temporary solution of leaving chrome remote desktop open while I'm away from the PC and not rendering. This seems to keep the PC from freezing, so it is likely that it's having trouble during idle.
Thanks for the suggestions.
Pochi_D is offline
post #15 of 29 (permalink) Old 04-11-2019, 01:00 AM
Rep: 7 (Unique: 5)
Have you tried playing any games or ran through unigine heaven/unigine to see if there are any artifacts? Does it give you any errors at all when it freezes? Like bsod or it just wont respond?
Are you on the latest bios for your motherboard?
Core I9-9900k @ 5.0
Asus Maximus XI Gene
EVGA 2080TI XC Black Edition
CMK16GX4M2K4700C19
Intel 905p 960GB
HP EX950 2TB m.2
Seasonic Prime Ultra Titanium 1KW
280mm Slim + 360MM Thick
Fractal Design Meshify S2
Operating System
Windows 10 64bit
HP Omen x27 240hz
Audio
Sennheiser HD 800s + Questyle CMA600i
xSneak is offline
post #16 of 29 (permalink) Old 04-13-2019, 01:37 AM - Thread Starter
Pochi_D's Avatar
I've just run it through unigine heaven with no visible problems. There are no errors or logs left when it freezes. The screens will be black and no keyboard input will do anything. The fans are also always venting warm air from the cpu fan.
I have not updated to the latest BIOS, but I am on the second most recent one. I will try a BIOS update now.
Pochi_D is offline
post #17 of 29 (permalink) Old 04-13-2019, 02:37 AM
Senior OCN Member
shilka's Avatar
Rep: 2808 (Unique: 1658)
What model is the Thermaltake 850 watt you have? they have more than a dozen 850 watt units and many of them are not very good
Dreissen
(27 items)
Seravee
(18 items)
Ryzen 3700x
Asrock x570 Taichi
MSI RTX 2070 Super Gaming X Trio
G Skill TridentZ
Corsair Force MP510 1,92 TB
Seagate IronWolf Pro ST14000NE0008
Seagate Ironwolf ST12000VN0007
Seagate IronWolf Pro ST12000NE0007
WD Ultrastar DC HC530 14 TB
Seagate IronWolf Pro ST16000NE000
Seasonic Prime Ultra Titanium 750 watt
Noctua NH-U12S Chromax
Phanteks Luxe 2
Operating System
Windows 10 Home 64 bit
Asus PG279Q
LG 55C8
Keyboard
Corsair Strafe RGB MK.2 with Cherry MX Silent
Mouse
Roccat Kone EMP
Mousepad
HyperX Fury S XL
Audio
Onkyo TX NR646
Audio
RHA L1 Dacamp
Audio
Sennheiser HD 599
Audio
Dali E 12 F
Audio
2x Dali Opticon 1
Audio
2x Dali Opticon 2
Audio
Dali Opticon Vokal
Other
Vegas MBA 60cm LED Strip
Intel Core I7 6850K
Gigabyte X99 Ultra Gaming
GTX 1060 3 GB wth blower style cooler
Kingston HyperX DDR4 Savage 3000 MHz
Samsung 840 Evo 500 GB
Samsung 860 Evo 1 TB
Optical Drive
LG CH12NS30
Seasonic Focus GX 650 watt
Noctua NH-D15S
Phanteks Enthoo Luxe Tempered Glass
Operating System
Windows 7 Ultimate 64 bit
Operating System
AOC 24G2U
Keyboard
Corsair Gaming STRAFE RGB Mechanical
Mouse
Roccat Kone EMP
Mousepad
Roccat Sense Metor
Audio
Sennheiser HD 598
Other
CableMod 30 CM Magnetic Red LED strip
LG 24MP59G-P
Mouse
Logitech MX518 Hero
Other
Delock PCI-E to M.2 NVME Adaptor Card
shilka is offline
post #18 of 29 (permalink) Old 04-13-2019, 02:57 AM - Thread Starter
Pochi_D's Avatar
Thermaltake TOUGHPOWER GRAND RGB -850W -NON DPS- 80+GOLD
I went with this one solely from the amount of positive reviews for it.
Pochi_D is offline
post #19 of 29 (permalink) Old 04-13-2019, 04:03 AM
Hardware Princess
Hydroplane's Avatar
Rep: 38 (Unique: 30)
I would second the bios update suggestion
CHILLER DESTRUCTION
Build Log - White Voodoo
basic linux pc
(15 items)
Z390 Station
(11 items)
7980XE @ 4.3 GHz 1.10v
Asus Rampage VI Apex
2 x Aorus Waterforce WB 1080 Ti @ 2037/6318
Trident Z 16gb 3200c14 @ 3800c16 1.50V (the other two sticks were sacrificed)
960 Evo 1TB
EVGA 1600 T2
HWLabs GTR 420+280 Rads
7 x Noctua Industrial 140mm 3000 RPM Fans
EK D5 Pump/Res (with RGB!)
LD Cooling PC-V7
Operating System
Linux Mint 19.6
NEC PA271W
Keyboard
Razer Blackwidow Chroma V2
Mouse
Logitech M510
Mousepad
anime tiddy mousepad
9900K @ 5.4 1.50v
EVGA Z390 Dark
Titan RTX 2085/8500
Trident Z 3200c14 @ 4600c20 1.5v
970 Evo Plus 250gb
silverstone 1200 from 2008 (other one exploded)
HWLabs GTX 360 Rad (in RED)
3x EK Vader 120mm 2200rpm Fans
Dimastech Test Bench
AOC Agon AG251FZ 240Hz
Audio
Built-in Monitor Speakers (3 watt)
Dual Intel Xeon L5520 2.26 GHz
48 GB Samsung DDR3-1066
120 GB Samsung 750 Evo SSD
2 TB Western Digital Green
2 TB Hitachi 7200 RPM
650W Delta PSU
1U Rackmount
Operating System
Ubuntu Server 16.04
Hydroplane is offline
post #20 of 29 (permalink) Old 04-13-2019, 04:09 AM - Thread Starter
Pochi_D's Avatar
It's updated now, will see how it goes.
Pochi_D is offline
