New build, hard freeze after left idle - Page 3 - Overclock.net - An Overclocking Community
post #21 of 29 (permalink) Old 04-13-2019, 06:13 AM
Senior OCN Member
shilka's Avatar
Rep: 2808 (Unique: 1658)
Quote: Originally Posted by Pochi_D View Post
Thermaltake TOUGHPOWER GRAND RGB -850W -NON DPS- 80+GOLD
I went with this one solely from the amount of positive reviews for it.
Unless its broken thats not the problem then as its actually not a bad model
Dreissen
(27 items)
Seravee
(18 items)
Ryzen 3700x
Asrock x570 Taichi
MSI RTX 2070 Super Gaming X Trio
G Skill TridentZ
Corsair Force MP510 1,92 TB
Seagate IronWolf Pro ST14000NE0008
Seagate Ironwolf ST12000VN0007
Seagate IronWolf Pro ST12000NE0007
WD Ultrastar DC HC530 14 TB
Seagate IronWolf Pro ST16000NE000
Seasonic Prime Ultra Titanium 750 watt
Noctua NH-U12S Chromax
Phanteks Luxe 2
Operating System
Windows 10 Home 64 bit
Asus PG279Q
LG 55C8
Keyboard
Corsair Strafe RGB MK.2 with Cherry MX Silent
Mouse
Roccat Kone EMP
Mousepad
HyperX Fury S XL
Audio
Onkyo TX NR646
Audio
RHA L1 Dacamp
Audio
Sennheiser HD 599
Audio
Dali E 12 F
Audio
2x Dali Opticon 1
Audio
2x Dali Opticon 2
Audio
Dali Opticon Vokal
Other
Vegas MBA 60cm LED Strip
Intel Core I7 6850K
Gigabyte X99 Ultra Gaming
GTX 1060 3 GB wth blower style cooler
Kingston HyperX DDR4 Savage 3000 MHz
Samsung 840 Evo 500 GB
Samsung 860 Evo 1 TB
Optical Drive
LG CH12NS30
Seasonic Focus GX 650 watt
Noctua NH-D15S
Phanteks Enthoo Luxe Tempered Glass
Operating System
Windows 7 Ultimate 64 bit
Operating System
AOC 24G2U
Keyboard
Corsair Gaming STRAFE RGB Mechanical
Mouse
Roccat Kone EMP
Mousepad
Roccat Sense Metor
Audio
Sennheiser HD 598
Other
CableMod 30 CM Magnetic Red LED strip
LG 24MP59G-P
Mouse
Logitech MX518 Hero
Other
Delock PCI-E to M.2 NVME Adaptor Card
shilka is offline
post #22 of 29 (permalink) Old 04-13-2019, 01:04 PM
Rep: 7 (Unique: 5)
Can you disable c state c6 in your bios? If you want to make sure its not idle power savings, disable all of the c states and manually set your vcore to prevent it from idling down. You can just do this as a test.
Does any of this apply to your system? I'm not familiar with threadripper.
http://forum.asrock.com/forum_posts....freezing-issue
"None of the above made any difference. So, in conclusion, the only thing that helped was to set the "Power Supply Idle Control" to "Typical Current Idle". Haven't had a single freeze since then.
The only drawback is that the VCore doesn't drop to 0.4 volts anymore, but stays at 0.8 minimum. I can live with that - haven't seen the temps raise at all.
I'm still very much confused about the purpose of that option. Modern power supply units should all be perfectly capable of handling low currents, or at least since "Haswell" came out - there were some notable problems with its C6/C7 states.
If you're having similar freezes at idle, check if your BIOS has this option and try to set it. It might help you.
PS: None of this applies if you have overclocked your system or disabled Cool'n'Quiet. At that point it's pretty much granted that you have set your VCore manually."
Core I9-9900k @ 5.0
Asus Maximus XI Gene
EVGA 2080TI XC Black Edition
CMK16GX4M2K4700C19
Intel 905p 960GB
HP EX950 2TB m.2
Seasonic Prime Ultra Titanium 1KW
280mm Slim + 360MM Thick
Fractal Design Meshify S2
Operating System
Windows 10 64bit
HP Omen x27 240hz
Audio
Sennheiser HD 800s + Questyle CMA600i
xSneak is offline
post #23 of 29 (permalink) Old 04-14-2019, 05:27 AM - Thread Starter
Pochi_D's Avatar
Rep: 22 (Unique: 20)
Tried newest OS, no dice.
Yep, this looks like the exact same problem.
This has got to be it. I will give some of these settings a go.
Thanks a heap.
Pochi_D is offline
post #24 of 29 (permalink) Old 04-14-2019, 06:45 PM - Thread Starter
Pochi_D's Avatar
This might be the first time the PC hasn't frozen overnight.
I switched the "Power Supply Idle Control" to "Typical Current Idle".
Will give an update after a day or two.
I appreciate all the help.
Pochi_D is offline
post #25 of 29 (permalink) Old 04-16-2019, 01:07 AM - Thread Starter
Pochi_D's Avatar
PC froze again last night.
I will now try disabling CStates. I don't think is a specific option for C6 but there is one for Cstates in general.
Pochi_D is offline
post #26 of 29 (permalink) Old 04-16-2019, 01:41 AM
rdr09's Avatar
Rep: 892 (Unique: 643)
The screen went black again? It could be that other peripherals are working except the monitor. Have you tried a different monitor? Even a tv will work.
By Built-in Benchmark Queen:
My 2.5 years old delidded 7980xe @ 4600mhz all core with 49ns memorylatency (4000c16 twekaed) is faster than 3950x max overclocked on water in every scenario. Pretty good for a ancient cpu
In gaming it has no chance vs my new 10900k @ 5400mhz and 4600c16 tweaked memory. ~35ns memorylatency.
2nd AMD Build
(10 items)
2700
470
5700
3466/14
1000
700
Operating System
10/64
55/2160
Keyboard
M100
rdr09 is offline
post #27 of 29 (permalink) Old 04-16-2019, 02:17 AM - Thread Starter
Pochi_D's Avatar
I initially had the monitor go to sleep after a while which mean't it froze on the black screen, but now without sleep on it locks on the last thing that was displayed.
The PC is most definitely frozen in this state without any response to input.
Pochi_D is offline
post #28 of 29 (permalink) Old 04-19-2019, 02:00 AM - Thread Starter
Pochi_D's Avatar
No freezes since disabling cstates.
It could be because I'm leaving Remote Desktop or some applications on to keep the CPU from idling, but I'll test without when I can.
Pochi_D is offline
post #29 of 29 (permalink) Old 04-21-2019, 08:01 AM - Thread Starter
Pochi_D's Avatar
No freezes still. So it seems that disabling Cstates has done the trick.
The PC still has trouble during restarts, but it isn't anything critical (I hope).
Thanks for everyones suggestions.
Pochi_D is offline
