New build, hard freeze after left idle - Overclock.net - An Overclocking Community
post #1 of 29 (permalink) Old 04-03-2019, 09:06 AM - Thread Starter
Pochi_D's Avatar
Rep: 22 (Unique: 20)
I've been having problems on a recently built machine when if left idle, the PC wont respond from anything.
The screen is black and the keyboard doesn't respond either. Upon forcing a restart, the machine doesn't boot up multiple times until it finally goes through to POST then Windows (But this could be another problem?).
This has happened since I built the PC (around the end of March) after leaving it on for at least 6hrs, usually after rendering but sometimes just left idle. The rendering has finished successfully every time and I have had no freezes during any other rendering whatsoever.
It is more likely that it is having problems during idle then when under load.
The first thing I did was turn sleep off then I disabled the automatic power off for network adapters (under Device Manager) and such as I saw this fixed the problem for some but this hasn't worked.
I have also added to the registry 'System unattended sleep timeout' and set it to 0.
Going into Sleep mode and back causes no problems.
The system has passed Prime95 on stock settings, chkdsk, sfc, memtest, unigine and cinebench.
Temps are within good ranges. Drivers are all updated.
I also tried increased the load-line calibration in BIOS as I thought maybe the CPU wasn't receiving enough power during idle.
it's a work machine mainly used for CPU and some GPU render and AI stuff.
Specs are as follows:
CPU: Threadripper 2990wx
MB: x399 Taichi
RAM: 64GB
GPU: 2080ti
PSU: 850w Thermaltake
STORAGE: 500GB + 1000GB SSD
OS: Windows 10
Any help is appreciated!
Pochi_D is offline
post #2 of 29 (permalink) Old 04-03-2019, 03:08 PM
rdr09's Avatar
Rep: 863 (Unique: 631)
Check and make sure that Global C-State is in Auto. Can't think of any other cause.
[email protected] 6 http://valid.canardpc.com/show_oc.php?id=2211392 4.6 @ 4 http://valid.canardpc.com/show_oc.php?id=2216580
5.0 @ 8 http://valid.canardpc.com/show_oc.php?id=2511322
2nd AMD Build
(10 items)
2700
X470
290
3200 CL14
1000
700
Operating System
10/64
40 1080
Keyboard
M100
rdr09 is offline
post #3 of 29 (permalink) Old 04-03-2019, 07:59 PM - Thread Starter
Pochi_D's Avatar
It's set to Auto.
I have tried with default Bios settings.
Pochi_D is offline
post #4 of 29 (permalink) Old 04-03-2019, 11:11 PM
rdr09's Avatar
Quote: Originally Posted by Pochi_D View Post
It's set to Auto.
You may have to do a repair of Windows even if sfc does not catch anything. Or, if you have time and a spare drive, test the system by making a new windows installation on a separate drive.
You did check all the cables for the drive, right? Power and Sata. Maybe replace the Sata cable. One other troubleshooting you can do, if possible, is to use a different gpu.
Wish you luck.
2nd AMD Build
(10 items)
2700
X470
290
3200 CL14
1000
700
Operating System
10/64
40 1080
Keyboard
M100
rdr09 is offline
post #5 of 29 (permalink) Old 04-05-2019, 08:06 PM
Rep: 7 (Unique: 5)
Are you running a negative offset voltage on an overclock? The negative offset could cause the system to become unstable at idle when the cores power down.
Verify your idle voltage on the cpu is normal.
Core I9-9900k @ 5.1
Asus Maximus XI Gene
EVGA 2080TI XC Black Edition
CMK16GX4M2K4700C19
Samsung 970 Evo m.2 nvme
Silverstone SFX-L 800W
280mm Slim + 360MM Thick
Fractal Design Meshify S2
Operating System
Windows 10 64bit
Acer XB271HU
Audio
Sennheiser HD 800s + Questyle CMA600i
xSneak is offline
post #6 of 29 (permalink) Old 04-08-2019, 12:46 AM - Thread Starter
Pochi_D's Avatar
Wish you luck.
Thanks for the suggestions.
I have checked and replaced cables and such but the problem still occurs.
I haven't tried using a different GPU but I'll give that a go next.
I have not overclocked yet.
The voltages seem normal.
Pochi_D is offline
post #7 of 29 (permalink) Old 04-08-2019, 03:56 AM
Rep: 7 (Unique: 5)
Turn off aspm (active state power management) for pcie devices in your bios.
Core I9-9900k @ 5.1
CMK16GX4M2K4700C19
Operating System
Windows 10 64bit
Acer XB271HU
Audio
xSneak is offline
post #8 of 29 (permalink) Old 04-08-2019, 06:24 AM - Thread Starter
Pochi_D's Avatar
I cannot find an option in the BIOS to turn off ASPM.
Pochi_D is offline
post #9 of 29 (permalink) Old 04-08-2019, 06:26 AM
skupples's Avatar
Rep: 552 (Unique: 313)
do you really need sleep states? I've always disabled them.
skupples is offline
post #10 of 29 (permalink) Old 04-08-2019, 11:52 AM
Rep: 7 (Unique: 5)
Ok. Go to windows power options and disable it under pcie settings (link power state management).
Does it matter if your video output turns off or not (under powet settings)?
Try clean driver install for gpu, use a different port on the gpu or try another cable.
Are there any error under windows event viewer?
Core I9-9900k @ 5.1
CMK16GX4M2K4700C19
Operating System
Windows 10 64bit
Acer XB271HU
Audio
xSneak is offline
