Help with new build. AMD or Ryzen 400-500$ - Overclock.net - An Overclocking Community
post #1 of 11 (permalink) Old 04-23-2019, 12:36 PM - Thread Starter
Bizong's Avatar
Rep: 42 (Unique: 41)
Hello fellow pc enthusiasts I'm looking to upgrade from my current i7 920 build and need help deciding what to go with.
I have a budget of around 400-500$ but I ONLY Need a Processor, Mobo, and Ram.
I've had trouble with deciding between AMD or Intel. I originally thought I would just go with a Ryzen 5 2600x but was told that it wouldn't totally be worth it without quad channel fast Ram. I had trouble getting that much ram and fitting into my budget. Is this true?
But these are the 2 builds I've come up with so far. https://pcpartpicker.com/user/Bizong/saved/#view=WT6hgs
I immensely appreciate any help deciding. Thank you!
Headphone Setup: Audio GD Dac 19 > Audio GD C-2 > Markl Modded D-5000's
Beast 3.0
(12 items)
Ryzen 5 3600x
MSI MPG X570 GAMING EDGE WIFI
GTX 970
CORSAIR VENGEANCE LPX
Samsung 970 EVO NVME
WD Black
Seasonic Focus Gold
Cooler Master HAF 932
Operating System
Windows 10
HP LP2475w 24"
Keyboard
Filco Majestouch 2
Mouse
Logitech G303
Bizong is offline
post #2 of 11 (permalink) Old 04-23-2019, 12:49 PM
I Love this Hobby!
Gunderman456's Avatar
Rep: 612 (Unique: 504)
You can go dual channel and buy two more sticks later.
Edit:
Guess that board is dual channel (as stated below), so buying two sticks now will not hamper things.
-Guide to 1st Case Modding for Better GPU(s) Performance/Cooling-
https://www.overclock.net/case-mod-wo...ing-guide
-Guide to 2nd Case Modding for Better GPU(s) Performance/Cooling-
https://www.overclock.net/case-mod-wo...e-fan-mod
Fast n' Cheap
(17 items)
Bit'O'Heaven
(16 items)
RYZEN 7 3700X
ASUS TUF GAMING X570-PLUS
MSI Radeon RX 5700 XT
G.SKILL Ripjaws V Series 32GB (2x16GB) DDR4 3600 16-19-19-39 CL 16 1.35V
Corsair Force Series Gen.4 PCIe MP600 500GB NVMe M.2 SSD
Seagate BarraCuda ST3000DM008 3TB 7200 RPM 64MB Cache SATA 6.0Gb/s 3.5" HDD
Optical Drive
LG 16X SATA Blu-Ray Internal Rewriter with 3D Playback and M-DISC Support BH16NS40
Fractal Design Ion+ 860P 80 PLUS Platinum Certified 860W Full Modular
Noctua NH-D15
Veddha GriderCase alpha V1
Operating System
Win 10 Pro 64bit
Nixeus EDG 27" IPS Freesync 1440p 144Hz
Keyboard
Redragon K589 SHRAPNEL RGB Mechanical Keyboard
Mouse
Logitech G502 Hero
Mousepad
ALLSOP Redmond Mouse Pad
Audio
Cambridge Soundworks 5.1
Other
PulseLabz Challenger Gaming Chair
Intel i7 4770k @ 4.5GHz
Asus Maximus VI Rog Gene
Gigabyte AMD R9 290 @ Core 1160MHz & Memory 1350MHz
G.SKILL Trident X DDR3 16GB 2400MHz
Samsung 840 PRO 256GB
Seagate Barracuda 7200.14 3TB
Optical Drive
Pioneer Black Blu-ray 16X BD-R 2X BD-RE
EVGA SuperNOVA G2 1300W 80PLUS Gold Fully Modular
Corsair H60 Push/Pull
PC-JMK5-Cool 5 Open Frame Case
Operating System
Win 7 Pro 64bit
Samsung 245BW 24" 1200p 60Hz
Keyboard
Logitech G15
Mouse
Logitech MX518
Mousepad
Corsair Vengeance MM200
Audio
Yamaha HTR-5830 Polk Audio 3.0
Intel Core i5-3570K @ 4.6GHz
ASRock Z77E-ITX mITX
Sapphire AMD HD 7990 @ Clock 900MHz & Memory 1100MHz
G.SKILL Ripjaws X DDR3 8GB 1600MHz @ 1866MHz
Crucial SSD CT128M4SSD3 128GB mSATA SATA III 6GB
Seagate Barracuda HDD 1TB
Optical Drive
LG DVD R/W
Corsair Professional Series Gold AX850 Fully Modular
Corsair Cooling Hydro Series H100
BitFenix Prodigy Mini-ATX Black Case
Operating System
Win 7 Pro 64bit
Samsung TV 52"
Keyboard
Logitech K330 Wireless
Mouse
Logitech M215 Wireless
Mousepad
Audio
Yamaha RX-V681 PSB/PolkAudio 5.1
Gunderman456 is offline
post #3 of 11 (permalink) Old 04-23-2019, 12:51 PM
rdr09's Avatar
Rep: 892 (Unique: 643)
If you're from MD, you might be close to a Micro Center. There are two of them.
https://www.microcenter.com/product/...erboard-bundle
or this, which comes with a decent cooler
For the RAM, i recommend this . . .
https://www.newegg.com/Product/Produ...-217-_-Product
Get some MX-4 Thermal paste to go along with the cooler.
The Ryzen 3000 7 nm CPU and X570/550 boards are coming in a few weeks.
EDIT: Dual channel is fine BUT make sure you use either 2 sticks of RAM or 4 sticks. One stick will be a bottleneck.
By Built-in Benchmark Queen:
My 2.5 years old delidded 7980xe @ 4600mhz all core with 49ns memorylatency (4000c16 twekaed) is faster than 3950x max overclocked on water in every scenario. Pretty good for a ancient cpu
In gaming it has no chance vs my new 10900k @ 5400mhz and 4600c16 tweaked memory. ~35ns memorylatency.
2nd AMD Build
(10 items)
2700
470
5700
3466/14
1000
700
Operating System
10/64
55/2160
Keyboard
M100
rdr09 is offline
post #4 of 11 (permalink) Old 04-23-2019, 01:08 PM
Overclocker
JackCY's Avatar
Rep: 362 (Unique: 259)
Mainstream platforms are dual channel. Only HEDT go to quad and beyond. Doesn't matter if it's AMD or Intel. RAM should be down in price now unlike year or two ago when they milked it by limiting supply.
You should wait for Zen2 unless you really need the hardware now, then Zen1.5 is fine.
JackCY is offline
post #5 of 11 (permalink) Old 04-23-2019, 01:12 PM
Senior OCN Member
shilka's Avatar
Rep: 2808 (Unique: 1658)
What brand and model is your old PSU? if its from 2009 you should not be re-using it with a brand new motherboard CPU and RAM
Quad channel RAM by the way is only found on X79/X99/X299/X399 so it does not matter if you pick Z390 X470 both use dual channel
And as JackCY said wait for Zen 2
Edit: and ditch the Cooler Master Hyper 212 Evo its overrated overhyped and overpriced and its not worth buying
https://www.overclock.net/forum/246-...ernatives.html
Dreissen
(27 items)
Seravee
(18 items)
Ryzen 3700x
Asrock x570 Taichi
MSI RTX 2070 Super Gaming X Trio
G Skill TridentZ
Corsair Force MP510 1,92 TB
Seagate IronWolf Pro ST14000NE0008
Seagate Ironwolf ST12000VN0007
Seagate IronWolf Pro ST12000NE0007
WD Ultrastar DC HC530 14 TB
Seagate IronWolf Pro ST16000NE000
Seasonic Prime Ultra Titanium 750 watt
Noctua NH-U12S Chromax
Phanteks Luxe 2
Operating System
Windows 10 Home 64 bit
Asus PG279Q
LG 55C8
Keyboard
Corsair Strafe RGB MK.2 with Cherry MX Silent
Mouse
Roccat Kone EMP
Mousepad
HyperX Fury S XL
Audio
Onkyo TX NR646
Audio
RHA L1 Dacamp
Audio
Sennheiser HD 599
Audio
Dali E 12 F
Audio
2x Dali Opticon 1
Audio
2x Dali Opticon 2
Audio
Dali Opticon Vokal
Other
Vegas MBA 60cm LED Strip
Intel Core I7 6850K
Gigabyte X99 Ultra Gaming
GTX 1060 3 GB wth blower style cooler
Kingston HyperX DDR4 Savage 3000 MHz
Samsung 840 Evo 500 GB
Samsung 860 Evo 1 TB
Optical Drive
LG CH12NS30
Seasonic Focus GX 650 watt
Noctua NH-D15S
Phanteks Enthoo Luxe Tempered Glass
Operating System
Windows 7 Ultimate 64 bit
Operating System
AOC 24G2U
Keyboard
Corsair Gaming STRAFE RGB Mechanical
Mouse
Roccat Kone EMP
Mousepad
Roccat Sense Metor
Audio
Sennheiser HD 598
Other
CableMod 30 CM Magnetic Red LED strip
LG 24MP59G-P
Mouse
Logitech MX518 Hero
Other
Delock PCI-E to M.2 NVME Adaptor Card
shilka is offline
post #6 of 11 (permalink) Old 04-23-2019, 01:35 PM - Thread Starter
Bizong's Avatar
Oh I have a new psu so no worries there.
Beast 3.0
(12 items)
Ryzen 5 3600x
GTX 970
WD Black
Seasonic Focus Gold
Operating System
Windows 10
HP LP2475w 24"
Keyboard
Filco Majestouch 2
Mouse
Logitech G303
Bizong is offline
post #7 of 11 (permalink) Old 04-23-2019, 01:56 PM
FX-5000
ShrimpBrime's Avatar
Rep: 67 (Unique: 48)
AMD RYZEN 7 2700X 8-Core 3.7 GHz (4.3 GHz Max Boost) Processor, ASUS ROG STRIX B450-F GAMING AM4 AMD B450 SATA 6Gb/s USB 3.1 HDMI ATX AMD Motherboard, CORSAIR Vengeance LPX 16GB (2 x 8GB) DDR4 3000 Memory
Newegg bundle. https://www.newegg.com/Product/Combo...2700x%20bundle
This is the route I went, but with the B450M-A board.
Go big or stay home.... or as suggested wait until 3rd gen ryzen is released and look into a 500 series chipset...
However, most AM4 boards will support 3rd Gen Ryzen cpus. So you could always upgrade that later... Really depends on Needs vs Wants IMO.
ShrimpBrime is offline
post #8 of 11 (permalink) Old 04-23-2019, 03:26 PM
Graphics Junkie
UltraMega's Avatar
Rep: 56 (Unique: 51)
The title to your thread seems to suggest you have already made up your mind..
4K Rig
(7 items)
Intel 7700k @4.2ghz
Zotec 1080 Ti
16GB 3200mhz DDR4
250GB nvme + 500GB SSD + 4TB HDD
Samsung 4K 65 inch TV
Pixio PX276 27inch 144Hz 1ms 1440p
Audio
Sound Blaster z
UltraMega is offline
post #9 of 11 (permalink) Old 04-24-2019, 02:12 PM - Thread Starter
Bizong's Avatar
LOL I totally meant AMD or Intel. Derp.
Beast 3.0
(12 items)
Ryzen 5 3600x
GTX 970
WD Black
Seasonic Focus Gold
Operating System
Windows 10
HP LP2475w 24"
Keyboard
Filco Majestouch 2
Mouse
Logitech G303
Bizong is offline
post #10 of 11 (permalink) Old 04-24-2019, 02:48 PM
Overclocker
JackCY's Avatar
Don't bother with Intel, they are still stuck with Skylake architecture, it will take them time before they make something substantially better and fixed of their endless issues. 6000-9000 Intel is all the same on Dekstop for the most part. Who knows when they will move away from the "Lakes" finally.
The price/performance for Intel parts is often abysmal when AMD has a competitive product as they do now. Easily pay +50% or more for +10% performance, so not worth it. At low end products can be more competitive but the high end from Intel is nuts price wise.
Zen2 3000 series is what I would get. If you can't wait till then, well 2700X is a beast.
JackCY is offline
