Looking for general build help - Page 6 - Overclock.net - An Overclocking Community
post #51 of 56 (permalink) Old 05-15-2019, 07:14 AM
Rep: 270 (Unique: 117)
Quote: Originally Posted by shilka View Post
Computex by the way starts on the 28th of may so thats a day less than two weeks away from today
Indeed. Was just mailed this link by AMD;
https://www.amd.com/en/events/computex
NightAntilli is offline
post #52 of 56 (permalink) Old 05-15-2019, 07:48 AM
OG AMD
Redwoodz's Avatar
Rep: 579 (Unique: 457)
Quote: Originally Posted by Belial View Post
So just as a refresher, all of those kits are the exact same RAM and the ones rated with a higher XMP profile of mhz and latencies are simply programmed that way by the manufacturer, and are supposed to be based on results from binning. And this binning process, is it accurate or indicative or OC results?
XMP is just a factory overclock really, isn't it? I got really crazy into ram overclocks, don't want to go down that rabbit hole again... would pass 24 hour stress tests and then flake on it 5 minutes in randomly another time.
No all of those kits use Samsung B-die RAM chips in varying configurations. They are binned. No one knows really how each module manufacturer binns their chips. For example people buying 3200 CL14 G.Skill RAM have had similar results with kits rated 3600+. Generally though the higher rated kits are binned higher. B-die's benefits lie in lower latency than any other IC. If you don't want to hassle with tweaking than use XMP. Really if you are not going to tweak them just grab a 3200 CL14 B-die set and call it a day.
https://valid.x86.fr/cache/banner/4d8m5e-6.png
AMD Athlon II 450 @4.74GHz http://valid.canardpc.com/show_oc.php?id=2204588
AMD MaxxMemm Rankings
960T @ 4.6GHz http://valid.canardpc.com/show_oc.php?id=2171450
RedwoodCustomPC
AM4
(4 items)
RCPC#1
(17 items)
Professional
Ryzen 2200G
ASRock X470 Taichi
MSI RX570 Armor MKII 8GB
GSKill Ripjaws PS850G
AMD Phenom II X6 960T
Asus M4A88T-VEVO
Asus Strix R7 370
SuperTalent Perfomance
GSkill Snipers
Monster Daytona
Seagate Barracuda 500GB 7,200 RPM 16Mb cache
Optical Drive
Memorex DVD/RW
Corsair GS500
Corsair H60
In Win H-Frame
Operating System
Windows 8N
IBM 9494 19" LCD
Keyboard
IBM
Mouse
OCZ Behemoth
Mouse
Wolfking
Audio
JBL Creature
Phenom II X6 1100t
MSI 890FX GD65
MSI Radeon HD5670
GSkill RipjawsX DDR3 PC3 12800 2x4GB CL8
WD Black 1TB SATA III
Optical Drive
Samsung BD
Kingwin Lazer Platinum 500w
Zalman 9900MAX
Fractal Design R3
Operating System
Windows 7 64 Professional
AOC 22" LED
Keyboard
Logitech
Other
Samsung 470 SSD 128GB
Redwoodz is offline
post #53 of 56 (permalink) Old 05-15-2019, 03:54 PM
Graphics Junkie
UltraMega's Avatar
Rep: 15 (Unique: 15)
You're upgrading for games that don't yet exist, and that's fine but its not an efficient way to upgrade economically, even if you plan to spend a lot.
Lets say you get a $3000 PC tomorrow. It's not really going to be all that much better for gaming than just getting a 4th gen i7 for any games out right now and any games that will come out before PS5. If you get a $3000 PC when PS5 comes out and when games come out that start to actually use more CPU power than a 4770k can deliver, then you will get a better PC in the end just because it will be a few generations newer. "future-proofing" your PC for gaming just means you either spend more or get less. Given that you buy a 4770K and sell your i5 and only spend about $80 in the end to get 95% of the experience a 9900K system would give you for games and then do a big upgrade later and have an even better PC when you actually need it, it seems like the smarter option.
Unless you want to play at 240hz or something, a 9900k is total overkill.
i7 7700kK @4.2ghz
16GB DDR4 3200mhz
GeForce 1080 Ti
UltraMega is offline
post #54 of 56 (permalink) Old 05-16-2019, 09:34 AM
OG AMD
Redwoodz's Avatar
He's upgrading because he wants to and he wants the top performing system now to use for several years. He wants to stream as well. 4770K is waaaay outdated in performance now.
RedwoodCustomPC
AM4
(4 items)
RCPC#1
(17 items)
Professional
Ryzen 2200G
ASRock X470 Taichi
Asus M4A88T-VEVO
Asus Strix R7 370
GSkill Snipers
Monster Daytona
Optical Drive
Memorex DVD/RW
Corsair GS500
Corsair H60
In Win H-Frame
Operating System
Windows 8N
IBM 9494 19" LCD
Keyboard
IBM
Mouse
OCZ Behemoth
Mouse
Wolfking
Audio
JBL Creature
Phenom II X6 1100t
MSI 890FX GD65
MSI Radeon HD5670
Optical Drive
Samsung BD
Zalman 9900MAX
Fractal Design R3
Operating System
AOC 22" LED
Keyboard
Logitech
Other
Redwoodz is offline
post #55 of 56 (permalink) Old 05-16-2019, 09:47 AM
Shawnb99's Avatar
Rep: 14 (Unique: 10)
Upgrading to top of the line is never economical. You can always find a reason to wait to upgrade.
My Rig
(21 items)
Intel Core i9-9900K
ASUS Maximus XI Formula
EVGA FTW3 Hydro Copper GeForce RTX 2080 Ti
G.SKILL TridentZ Series 16GB DDR4 3600 F4-3600C15D-16GTZ
Samsung 860 EVO 1TB
Samsung 850 EVO 1TB
Seasonic PRIME Ultra 1000 Titanium
Watercool HEATKILLER IV PRO
Swiftech MCP35X2 with MCP35X2 Heat Sink
2 x Hardware Labs Black Ice Nemesis 360GTR
2 x Hardware Labs Black Ice Nemesis 360GTS
Aquacomputer aqualis XT 450 ml with nano coating
9 x Noctua NF-S12A PWM
2 x Noctua NA-A15 PWM
24 x EK Vadar F4120ER
Case Labs Magnum M8 with Pedestal
Asus PG28Q
Keyboard
Das Keyboard 5Q
Mouse
Swiftpoint Z
Audio
Mr. Speakers Aeon Closed
Audio
Geek Pulse Inifnity DAC/AMP
Shawnb99 is offline
post #56 of 56 (permalink) Old 05-16-2019, 02:32 PM
Graphics Junkie
UltraMega's Avatar
Sure, but doing it a year or so before a new console has to be the absolute worst time to do a major upgrade like this. A time where no games that would take advantage of the newer hardware exist, and by the time they do, there will be better hardware for cheaper.
i7 7700kK @4.2ghz
16GB DDR4 3200mhz
GeForce 1080 Ti
