Looking for general build help - Overclock.net - An Overclocking Community
post #1 of 72 (permalink) Old 05-07-2019, 03:09 AM - Thread Starter
Belial's Avatar
Rep: 166 (Unique: 142)
So I used to be really big into building PCs, overclocking, etc, but life has happened and well now I don't do that so much anymore. However it's been a good 5+ years since I built my last pc so looking for a new one and everything is different now.
My needs aren't very demanding, just general gaming and I might stream or record stuff. I have plenty of funds so I'm not worried about spending too much. I will probably do a minor CPU overclock and maybe RAM but won't push it like I did in the past.
I was thinking about buying an Intel i9-9900k but not too sure on what else. Just a nice Gigabyte board (they've worked well in the past but don't know what's changed or if an Asus or something would be better). A nice SSD (just some samsung ssd I guess, I have an 860 evo I could use). I have no idea what RAM to get, probably 2x16gb. Not sure on a PSU, maybe some seasonic... A NZXT AIO 280mm cooler.
Not sure on case, I might even want to go with like a micro/mini ATX this time around. Just some single GPU...
Thanks.
Belial is offline
post #2 of 72 (permalink) Old 05-07-2019, 03:39 AM
Senior Overclocker
Cryptedvick's Avatar
Rep: 266 (Unique: 235)
If money is not an issue I would advise you to pick up the following:
9900k
Asus Maximus XI Hero/Z390 Aorus Xtreme/Z390 Taichi for ATX and Gene XI for mATX
16-32GB of 3200Mhz at CL14-CL15 to get Samsung B dies.
RTX2080Ti or RTX2080 of whichever preference.
Corsair RM750x PSU
Noctua NHD15/Dark Rock Pro 4 for cooling. Avoid CLC cooler such as the one you pointed out because they are not much better in terms of cooling, are much louder and you're also having to deal with potential leaks, pump failures, possible degrading performance, heating up the GPU if mounted in the front (which is where you'd want it for optimum cooling performance). Also, an air cooler will also provide some extra airflow to the VRMs of the motherboard. Mind you, these top end air coolers will not fit in a mATX build so if you really want to go that way, then the only option would be the best CLC you can find that would fit in whichever case you pick up.
As for the case, just get something you like but don't cheap out. Be sure to also pick up some good case fans as well.
An optimum solution would be a case with intake fans on the front panel, at least 2, one on the bottom pushing up inside the case, one on the side panel to take out hot air from the GPU and 2 more on the back and top to take out hot air from the CPU.
If you can find a case that would fit this profile and looks good for you, go for it.
C2D 6750 -> C2Q 6600 -> C2Q 9550 -> i7 2600k -> i7 8700k -> i9 9900k
8800GT -> 8800GTS 512 -> GTX285 -> GTX480 -> GTX580 -> GTX780ti -> GTX980ti -> GTX1080ti
R.I.P. Daniel Costin (Syrillian)
Animal Mother V3
(19 items)
i9 9900k R0 5Ghz 1.2v VROUT
Asrock Z390 Taichi
MSI GTX 1080Ti GamingX @ 2063Mhz/6000Mhz
32GB Corsair Vengeance 3200Mhz CL16
Patriot Viper VPN100 NVMe 512GB OS drive
Western Digital Blue 2x1TB 3D NAND SSDs in Raid 0
Western Digital Blue 1TB
Western Digital Red 2TB
Western Digital Green 2x3TB
WD Elements 2TB
Corsair TX750W V2
Noctua NH-D15 w/MX4
Cooler Master 690 II Advanced + 7 case fans
Operating System
Windows 10 x64
LG 29UM69G 2560x1080 @ 75Hz
Keyboard
Redragon Yama
Mouse
Redragon Titanoboa 2
Audio
Asus Xonar DX / Plantronics Gamecom 777 / Logitech Z506
Other
Oculus Rift S + T500RS wheel and TH8RS shifter
Cryptedvick is offline
post #3 of 72 (permalink) Old 05-07-2019, 04:16 AM
Senior OCN Member
shilka's Avatar
Rep: 2808 (Unique: 1658)
Dont get a CLC cooler they are overrated overhyped and overpriced
https://www.overclock.net/forum/61-w...lc-cooler.html
Air cooling is cheaper more quiet and more reliable
Dreissen
(27 items)
Seravee
(18 items)
Ryzen 3700x
Asrock x570 Taichi
MSI RTX 2070 Super Gaming X Trio
G Skill TridentZ
Corsair Force MP510 1,92 TB
Seagate IronWolf Pro ST14000NE0008
Seagate Ironwolf ST12000VN0007
Seagate IronWolf Pro ST12000NE0007
WD Ultrastar DC HC530 14 TB
Seagate IronWolf Pro ST16000NE000
Seasonic Prime Ultra Titanium 750 watt
Noctua NH-U12S Chromax
Phanteks Luxe 2
Operating System
Windows 10 Home 64 bit
Asus PG279Q
LG 55C8
Keyboard
Corsair Strafe RGB MK.2 with Cherry MX Silent
Mouse
Roccat Kone EMP
Mousepad
HyperX Fury S XL
Audio
Onkyo TX NR646
Audio
RHA L1 Dacamp
Audio
Sennheiser HD 599
Audio
Dali E 12 F
Audio
2x Dali Opticon 1
Audio
2x Dali Opticon 2
Audio
Dali Opticon Vokal
Other
Vegas MBA 60cm LED Strip
Intel Core I7 6850K
Gigabyte X99 Ultra Gaming
GTX 1060 3 GB wth blower style cooler
Kingston HyperX DDR4 Savage 3000 MHz
Samsung 840 Evo 500 GB
Samsung 860 Evo 1 TB
Optical Drive
LG CH12NS30
Seasonic Focus GX 650 watt
Noctua NH-D15S
Phanteks Enthoo Luxe Tempered Glass
Operating System
Windows 7 Ultimate 64 bit
Operating System
AOC 24G2U
Keyboard
Corsair Gaming STRAFE RGB Mechanical
Mouse
Roccat Kone EMP
Mousepad
Roccat Sense Metor
Audio
Sennheiser HD 598
Other
CableMod 30 CM Magnetic Red LED strip
LG 24MP59G-P
Mouse
Logitech MX518 Hero
Other
Delock PCI-E to M.2 NVME Adaptor Card
shilka is offline
post #4 of 72 (permalink) Old 05-07-2019, 10:53 PM - Thread Starter
Belial's Avatar
Asrock sucked back in my day with bad VRMs. Gigabyte is nice but never used asus, might try them out. Been having mobo issues with haswell anyways.
Exactly what I wanted to know, thanks. Any specific recs?
Corsair RM750x PSU
Aren't corsairs just a rebrand of something else?
Surprised for the hate on CLCs. 280mm CLC will definitely cool a few degrees better than a high end air cooler like NH-D15, I've owned D15s and done a lot of CLCs and have done a ton of testing with coolers (as linked in my signature).
Certain coolers are only louder based on the fans used and the speed used. You can also put 4x fans on a 280mm which can make your build significantly more quiet and cool better too.
Never had a CLC fail. Otherwise depends on the CLC in question for performance but 280mm CLCs will outperform any air cooler. CLCs are also better for a mobile set up.
Price is not a big concern for me, and a 9900K will definitely require more than high end air cooling (as opposed to say, maybe an i5).
Really I should be using custom water, but I'm lazy, and I am not a fan of complex builds anymore (my current build is ridiculously complex, ie I have an arduino plugged into 5VSB to open the side door like a lambo with a button push coded to not allow redundant pushes or an action to override a current action, a backup battery system, a custom water loop, a custom case I built, custom sleeving, etc).
Belial is offline
post #5 of 72 (permalink) Old 05-07-2019, 11:05 PM - Thread Starter
Belial is offline
post #6 of 72 (permalink) Old 05-07-2019, 11:21 PM
Graphics Junkie
UltraMega's Avatar
Rep: 57 (Unique: 52)
Really not much has changed in the last 5 years. Games still don't need more than 8 threads or more than 16Gbs of ram (8Gbs really)
Ram went from DDR3 to DDR4?
I have the 2500K I bought 8 years ago in my GFs PC and it holds up just fine.
Just get a decent CPU with a decent mobo (9900k is overkill)
16GBs DDR4 ram
500gb-1TB ssd + 2-4TB HDD for storage,
and spend the rest of your main budget on the best GPU you can afford.
4K Rig
(7 items)
Intel 7700k @4.2ghz
Zotec 1080 Ti
16GB 3200mhz DDR4
250GB nvme + 500GB SSD + 4TB HDD
Samsung 4K 65 inch TV
Pixio PX276 27inch 144Hz 1ms 1440p
Audio
Sound Blaster z
UltraMega is offline
post #7 of 72 (permalink) Old 05-08-2019, 12:21 AM
Senior OCN Member
shilka's Avatar
Almost everything other than FSP Seasonic HighPower and a few others are rebrands of something else
http://www.realhardtechx.com/index_a...wDatabase.html
Dreissen
(27 items)
Seravee
(18 items)
Ryzen 3700x
Asrock x570 Taichi
G Skill TridentZ
Phanteks Luxe 2
Operating System
Asus PG279Q
LG 55C8
Keyboard
Mouse
Roccat Kone EMP
Mousepad
HyperX Fury S XL
Audio
Onkyo TX NR646
Audio
RHA L1 Dacamp
Audio
Sennheiser HD 599
Audio
Dali E 12 F
Audio
2x Dali Opticon 1
Audio
2x Dali Opticon 2
Audio
Dali Opticon Vokal
Other
Intel Core I7 6850K
Optical Drive
LG CH12NS30
Noctua NH-D15S
Operating System
Operating System
AOC 24G2U
Keyboard
Mouse
Roccat Kone EMP
Mousepad
Roccat Sense Metor
Audio
Sennheiser HD 598
Other
LG 24MP59G-P
Mouse
Logitech MX518 Hero
Other
shilka is offline
post #8 of 72 (permalink) Old 05-08-2019, 02:00 AM
Senior Overclocker
Asrock has changed quite a bit in the past years, producing very good motherboards with very good VRMs, especially on Z370 and Z390.
The Taichi mobos are among the best price/performance you can get, next to the K6. Personally I have the Z370 Taichi and coming from Gigabyte only mobos in the past, their UDx series, I must say that I am pleasantly surprised by its performance and many reviews out there confirm their quality, which is why I went with one.
Regarding rams, there is no definitive list of B dies rams but you can spot them by their specs. Mostly, 3200 14.14.14, 3600 16.16.16 and 4000+ Mhz 2x8GB kits will be Samsung B dies. So take your pick from Corsair vengeance LPX and RGB, Gskill tridentZ and others with these specs.
https://www.reddit.com/r/Amd/comment...nfusion_eg_on/
This is an incomplete list of B dies that I found on reddit, which might help you.
Animal Mother V3
(19 items)
Asrock Z390 Taichi
WD Elements 2TB
Corsair TX750W V2
Noctua NH-D15 w/MX4
Operating System
Windows 10 x64
Keyboard
Redragon Yama
Mouse
Audio
Other
post #9 of 72 (permalink) Old 05-09-2019, 03:14 AM - Thread Starter
Belial's Avatar
16GBs DDR4 ram
Back in my day it was 2 cores, and maybe 4 cores for AAA titles. i7s were reserved for streaming, back when justin.tv was around and twitch wasn't even a thing. My i5 4560k build is more than powerful enough still, I'm just running into some really weird issues that I can't explain and it's time enough to build a new pc anyways (computer wasn't posting or booting, literally replaced every single component and the issue still occurred, and then it stopped, but that's a whole other issue).
I can afford a 9900K. I used to have the 4770k and that was perfect, but the i5 is lacking for when I want to stream or record stuff.
16GB probably isn't enough, I feel like I come close to using that up. 32GB please.
I might do that fancy 1tb plugin drive. Samsung 970 Pro 1TB. I never use much storage space up (although I did eventually after 5 years start filling up my 250gb samsung 830 and that got a bit annoying).
I'll go with the Asus maximus board. Maybe the wifi because why not although I always use wired... maybe when im on the road or something the wireless would be nice. whatever.
Honestly don't need a great GPU. That's an easy swap out anytime I want. I play mostly CPU driven games when I do game.
Probably just get some Seasonic PSU. I'm not sure which one though, power consumption has grown these days it seems. PSU is a big deal to me, I've had quite a few PSU's die on me because I have a lot of dog hair get sucked up by them (it's not that much but after some years I guess it acculumates even with regular cleaning). I'd probably need modular because of the inevitable PSU death. Honestly I prefer non-modular for looks but my last PC build was SO complex that I'm really looking for an extremely easy computer. Something that if things fail in the future, they're easy to swap out. I pretty much had to gut my current build just to replace the most basic of components for troubleshooting.
Literally had to remove massive custom plexiglass panels I put around the PSU and around wiring. They looked sexy as hell but having to remove multiple layers of plexiglass and paneling. Ugh. Not fun. My fault.
Not sure on cases. What's a cool case. Maybe the nzxt 500 series?
Belial is offline
post #10 of 72 (permalink) Old 05-09-2019, 03:37 AM
Senior OCN Member
shilka's Avatar
If you plan on using an NVME drive (such as the 970 Evo and Pro) for gaming dont bother its only a second faster at most due to software limitations so there is no point and you might as well stick with using a drive using the older AHCI protocole its not much slower and often much cheaper
Dreissen
(27 items)
Seravee
(18 items)
Ryzen 3700x
Asrock x570 Taichi
G Skill TridentZ
Phanteks Luxe 2
Operating System
Asus PG279Q
LG 55C8
Keyboard
Mouse
Roccat Kone EMP
Mousepad
HyperX Fury S XL
Audio
Onkyo TX NR646
Audio
RHA L1 Dacamp
Audio
Sennheiser HD 599
Audio
Dali E 12 F
Audio
2x Dali Opticon 1
Audio
2x Dali Opticon 2
Audio
Dali Opticon Vokal
Other
Intel Core I7 6850K
Optical Drive
LG CH12NS30
Noctua NH-D15S
Operating System
Operating System
AOC 24G2U
Keyboard
Mouse
Roccat Kone EMP
Mousepad
Roccat Sense Metor
Audio
Sennheiser HD 598
Other
LG 24MP59G-P
Mouse
Logitech MX518 Hero
Other
shilka is offline
