How check if Overclock it's stable - Overclock.net - An Overclocking Community
post #1 of 2 (permalink) Old 05-19-2019, 07:24 PM - Thread Starter
El Media Vida's Avatar
Rep: 1 (Unique: 1)
Hi guys.
I wondering how is the correct way or correct method to test a CPU with OC and say "it's stable" or "now I can set as default" to use the computer normaly, like if you don't do OC. I mean, use the computer like stock clocks and do all your stuffs.
I read some people say that the OC it's stable when you run Prime95 on blend test, another says when you run Prime95 without running AVX, and another says when use OCCT, and another says don't use Prime95 or OCCT and only check if the games run normaly. Obviosly the problem came with the CTD or BSOD.
Cleary, when you ran the PC at stock values you can do all the mentionated things without problems.
So then, how I know when I do OC correctly?
El Media Vida is offline
post #2 of 2 (permalink) Old 05-19-2019, 07:41 PM
The last VRM burner
Rep: 21 (Unique: 13)
Just run OCCT for 24 hours, checking stability on games is a waste of time, it only works for dirty stability testing, nothing else. It also uses AVX instructions as well.
PC for all
(18 items)
i7 5775c @4.2GHz/3.8GHz
Gigabyte Z97X Gaming 5
Soon to be 2070 Super FE
KHX24C11T3K2/16X 11-12-12-32-1T-250
Corsair MP510
Samsung Evo 860
SeaSonic Focus Plus 750W
Raijintek Tisis lapped+ Thermal Grizzly Kryonaut
LianLi 330X
Operating System
Windows 10 64-bit Pro
Benq GL2250 80Hz
Keyboard
Corsair Strafe Red Silent
Mouse
SteelSeries Rival 310
Mousepad
Artisan FX Raiden
Audio
Audio in Motion SC808 + MUSES8820 + 2x 2xLME49990
Audio
AKG M220
Other
NZXT Hue+
Other
Mayflash F300 Arcade Stick
BroadPwns is offline
