RELIDDING with thermal paste ? - Page 2 - Overclock.net - An Overclocking Community
post #11 of 12 (permalink) Old 06-10-2019, 09:04 PM
sudo apt install sl
Rep: 188 (Unique: 130)
Quote: Originally Posted by Falkentyne View Post
True, but not gluing down the IHS with adhesive is really something only experts (or people are just lazy or in a hurry) should be doing. It's very careless to do things haphazardly.
Many people have had issues with the IHS shifting when applying the retention lever, disturbing the LM application and causing very high temps. Novices should not have to deal with the extra work and care (and complete messups--requiring yet another repaste) from trying to use a "floating IHS". Why not simply do things the right way the first time? Provided the original Intel silicone is completely removed, you will never have issues like this if you take the time to secure the IHS with four small dabs of RTV silicone on each corner of the IHS. Then you just clamp it with the relid kit and let it sit two to three hours (you "can" try one hour if you're in a hurry but i wouldn't recommend it).
Not only does the 4 dab method secure the IHS enough, it also makes delidding again possible -with your fingernails-, provided you used the minimum amount possible. Less is more.
Much easier to just sit the delidded CPU into the socket. Apply liquid metal and then sit the IHS onto the CPU and lower the lever. Don't have to worry about having to re-lid if they add too much silicone.
Quote: Originally Posted by techjesse View Post
Or you can go DD....no need to glue...lol
Yup, DD is the way to go! I went DD with my 9900k I modded. (I cleaned up the board around the socket dw)
Silent
(20 items)
Core i9 9900K... CoffeeTime! @ 5.1Ghz w/ 1.36v
Maximus VIII Formula
Titan RTX @ 2100Mhz/2075Mhz
TeamGroup Xtreem 32GB 3200Mhz CL15
HP EX950 2TB
Samsung 850 Evo 1TB
Samsung 850 Evo 1TB
EVGA SuperNova 1200w P2
EK Supremacy Full Copper Clean
XSPC D5 Photon v2
Black Ice Gen 2 GTX360 x2
EK-Vector Radeon VII - Copper + Plexi
Thermaltake Core X5 Tempered Glass Edition
Operating System
Clear Linux
Acer XF270HUA
Keyboard
Cherry MX Board 6.0
Mouse
Logitech G600
Mouse
Alugraphics GamerArt
Audio
Definitive Technology Incline
Audio
SMSL M8A
WannaBeOCer is offline
post #12 of 12 (permalink) Old 06-10-2019, 10:01 PM
Robotic Chemist
Asmodian's Avatar
Rep: 193 (Unique: 130)
Quote: Originally Posted by bmgjet View Post
The liquid metal will hold it well enough if your just taking it from the delidding jig to putting it in the socket and clamping it down.
My 7900X only has liquid metal.
I second this! No need for any adhesive, just carefully put it in the socket and clamp it down.
...Or DD of course, DD is always better.
Asmodian is offline
