RELIDDING with thermal paste ? - Overclock.net - An Overclocking Community
post #1 of 12 (permalink) Old 06-09-2019, 02:32 PM - Thread Starter
Rep: 0
Hello,
Do you think thermal paste would be sticky enough to hold the IHS in place while handling the CPU ?
I'm thinking of using it instead of silicone or glue.
I've got TG Kryonaut which is not electrically conductive.
Thanks.
MilaweaX is offline
post #2 of 12 (permalink) Old 06-09-2019, 02:40 PM
9 Cans of Ravioli
The Pook's Avatar
Rep: 1408 (Unique: 724)
no.
Intel i9 9900K Coffee Lake @ X8 5309mhz (+47.5%)
AMD FX-8320 Vishera @ X4 5022mhz (+43.5%)
Intel i5 4690K Haswell @ X4 5013mhz (+43.2%)
AMD X4 960T Zosma @ X6 4870mhz (+62.3%)
Intel i7 6700 Skylake @ X4 4709mhz (+38.5%)
Intel i5 6400 Skylake @ X4 4588mhz (+69.9%)
2 OP pls nerf
(24 items)
NUC U
(10 items)
i9 9900K
AsRock Z390 Taichi
MSI GTX 1080 Ti
G.Skill DDR4 4133 32GB
XPG SX8200 Pro NVMe 2TB
HP EX950 NVMe 2TB
2x Samsung 860 1TB RAID 0
Toshiba X300 5TB
Western Digital EZRZ 3TB
Seasonic Focus Plus Gold 750w
Corsair H115i Pro
Raijintek Morpheus II
Fractal Design Meshify S2
Operating System
Windows 10 Education x64
Acer XF270HU 27" 1440p
LG 24UD58 24" 4K
Keyboard
CoolerMaster MK730 (MX Blue)
Mouse
Glorious Model D
Mousepad
X-Ray 27" x 14"
Audio
Klipsch PowerGate + Schiit Hel
Audio
Micca RB42
Audio
Philips Fidelio X2
Audio
Philips SHP9500S
Audio
Audio Technica ATH-M50X
i3 8109U
Intel NUC8i3BEH
Iris Plus 655
Kingston DDR4 2400 16GB
Mushkin Pilot NVMe 1TB
SanDisk Ultra II 480GB
Operating System
Windows 10 Professional
Operating System
MX Linux
Keyboard
Dierya DK63-BT 60% (Outemu Blue)
Mouse
Logitech G603 Wireless
The Pook is offline
post #3 of 12 (permalink) Old 06-09-2019, 02:47 PM
The last VRM burner
Rep: 45 (Unique: 27)
No and you don't delid a CPU only to put a grease back again on it.
PC for all
(21 items)
i7 5775c @4.2GHz/3.8GHz
Gigabyte Z97X Gaming 5
Iris Pro 6200
F3-2400C11D-16GAB Samsung Rev. Q
Corsair MP510
Samsung Evo 860
Seasonic Focus Plus 750W
Artcic Liquid Freezer II 360mm
Arctic P12 PWM x2
Arctic P14 x4
LianLi 330X
Operating System
Windows 10 64-bit Pro
Samsung C24FG73FQUX
Benq GL2250 80Hz
Keyboard
Corsair Strafe Red Silent + 1.6x6mm o-rings
Mouse
SteelSeries Rival 600
Mousepad
Artisan FX Raiden
Audio
Audio in Motion SC808 + MUSES8820 + 2x 2xLME49990
Audio
AKG M220
Other
NZXT Hue+
Other
Mayflash F300 Arcade Stick
BroadPwns is offline
post #4 of 12 (permalink) Old 06-09-2019, 02:52 PM - Thread Starter
Rep: 0
Not on the die, just on the edges of the IHS.
But ok, thanks.
MilaweaX is offline
post #5 of 12 (permalink) Old 06-09-2019, 02:56 PM
The last VRM burner
But ok, thanks.
Thermal paste is not a glue-like substantion and its surface tension is rather low too, come on .
PC for all
(21 items)
Iris Pro 6200
Corsair MP510
Samsung Evo 860
Arctic P12 PWM x2
Arctic P14 x4
LianLi 330X
Operating System
Samsung C24FG73FQUX
Benq GL2250 80Hz
Keyboard
Mouse
Mousepad
Artisan FX Raiden
Audio
Audio
AKG M220
Other
NZXT Hue+
Other
post #6 of 12 (permalink) Old 06-09-2019, 02:56 PM
Facepalm
Falkentyne's Avatar
Rep: 447 (Unique: 311)
Hello,
Thanks.
Just buy RTV Silicone and use that.
It's cheap on Amazon.
And apply four VERY TINY small dabs (this is extremely important) on each corner of the IHS when relidding. It also helps if you sand the edges of the IHS as well, just enough so the copper color appears.
The four tiny dab method not only keeps the IHS as close to the core as possible (RTV will expand when cured, that's why you need to use as little as possible), but it also makes future delids easy to do without even using a tool. (the hardest part then is just cleaning the residue off when applying more
Make sure you remove all of the original black Intel adhesive as well.
You can use Kryonaut between IHS and cpu core. Yes it DOES work better than the Dow corning stuff Intel uses, but it's not optimal. It still does work. Liquid metal is best however. Go ahead and use it until you get some actual liquid metal.
[email protected] ghz, RX Vega 64, 32GB DDR4, Gigabyte Aorus Master, Seasonic Platinum 1000W, Corsair 760T
Alt: MSI GT73VR Throttlebook with 7820HK @ 4.7 ghz, GTX 1070 MXM TDP mod to 230W, 32 GB RAM
Quote: Originally Posted by sakete View Post
Well, I want you to know I have an academic degree in speculation.
Falkentyne is online now
post #7 of 12 (permalink) Old 06-09-2019, 08:53 PM - Thread Starter
Rep: 0
Thank you for your exhaustive answer !
I've got liquid metal. Everything except silicone or glue..
But today's monday so I'll buy me some silicone
And yes I did a test with a little bit of thermal paste between plastic and metal. This thing is made not to dry, it doesn't hold, idk what I was thinking I was eager to delid that thing.
MilaweaX is offline
post #8 of 12 (permalink) Old 06-09-2019, 10:58 PM
High Clocker
bmgjet's Avatar
Rep: 191 (Unique: 165)
The liquid metal will hold it well enough if your just taking it from the delidding jig to putting it in the socket and clamping it down.
My 7900X only has liquid metal.
SLI Voodoo 2 - > GeForce4 MX 420 -> GF 6600GT -> GF 6800GT -> GF 8800Ultra -> AMD 4870 -> AMD 4890 -> CF AMD 5820 -> CF AMD 6850 -> CF AMD 7970 -> SLI GF 680 -> SLI GF 780 -> CF AMD 290X -> GF 980ti -> SLI GF 980ti -> GF 1080ti -> SLI GF 1080ti -> <- RTX 2080ti (DOA/Refunded)
AMD 8120
FX 8350
7970 CFX
680 SLI
bmgjet is offline
post #9 of 12 (permalink) Old 06-09-2019, 11:37 PM
Facepalm
Falkentyne's Avatar
True, but not gluing down the IHS with adhesive is really something only experts (or people are just lazy or in a hurry) should be doing. It's very careless to do things haphazardly.
Many people have had issues with the IHS shifting when applying the retention lever, disturbing the LM application and causing very high temps. Novices should not have to deal with the extra work and care (and complete messups--requiring yet another repaste) from trying to use a "floating IHS". Why not simply do things the right way the first time? Provided the original Intel silicone is completely removed, you will never have issues like this if you take the time to secure the IHS with four small dabs of RTV silicone on each corner of the IHS. Then you just clamp it with the relid kit and let it sit two to three hours (you "can" try one hour if you're in a hurry but i wouldn't recommend it).
Not only does the 4 dab method secure the IHS enough, it also makes delidding again possible -with your fingernails-, provided you used the minimum amount possible. Less is more.
post #10 of 12 (permalink) Old 06-10-2019, 08:58 PM
techjesse's Avatar
Rep: 17 (Unique: 13)
Or you can go DD....no need to glue...lol
Intel Core i7 5960X Haswell-E, Gigabyte LGA 2011-V3 GA-X99-SOC Champion, G.SKILL Ripjaws 4 16GB, PowerColor R9 280x TriFire, WD 1TB Black x3, Intel 180GB SSD, ASUS 24x DVD Burner, Win 7 Ult. 64bit, 28" I-Inc 1920x1200 Logitech G105 EVGA 1300watt PSU, CaseLabs ST10 biggrin.gif
post-flame-small.gif5 GHz Overclock Club post-flame-small.gifpost-flame-small.gif[Official] ASUS ROG Rampage IV X79 Owner's Club post-flame-small.gif
techjesse is offline
