9900k / 2080 TI seems a bit choppy - Page 2 - Overclock.net - An Overclocking Community
post #11 of 23 (permalink) Old 06-23-2019, 05:29 PM - Thread Starter
overvolted's Avatar
Rep: 33 (Unique: 32)
Thanks for all the replies this helps quite a bit.
For the CPU and Power Supply, those components in general either work or they don't, right?
But for the motherboard, isn't there a lot more wiggle room for error?
overvolted is offline
post #12 of 23 (permalink) Old 06-23-2019, 07:19 PM
wirefox's Avatar
Rep: 30 (Unique: 28)
firstly...I'd suggest that you run ddu in safe mode, to remove the video driver and install the most updated one. I think that will help.
https://www.wagnardsoft.com/forums/
I'd also have you updated the bios and chipset, I/O etc? check here
https://www.aorus.com/Z390-AORUS-MAS...10#pd_download
other thoughts... you could be pushing the PCEi lanes. with 16x gpu, and two m.2 not sure how many lanes they take but someone here might ...(I'd research this to know for sure) the z390 has limited lanes. Maybe test with only one (your o/s) versus both...
also the aorus mobo's tend to load slower for me I have the z390 xtreme.... I'm on a sata 850 pro... but the bios itself seems to take time to load vrs my other msi or asus builds.
lastly. are you overclocking cpu or gpu? ... your psu should be enough, unless it's very old or you are overclocking a ton. the 2080ti can be a hog depending on your volts.
wirefox
wirefox is offline
post #13 of 23 (permalink) Old 06-23-2019, 08:24 PM - Thread Starter
overvolted's Avatar
wirefox
Yes I have latest bios, chipset drivers and such. That's a good idea and shows how stupid I am, didn't think to remove one of the M.2 drives. Only one of them is really necessary so I'll give that a shot. I'll also try removing the Soundblaster AE-5 and trying each ram stick one at a time.
My PSU is about 6 years old, so I'm not sure if that's pushing it on age. I had to clean it out the other day when rebuilding my PC cause it has tons of dust caked up on the fans / insides of it. At one point I thought I may of been a little rough trying to open up the unit, but ultimately didn't think it was that bad. I may just say to hell with it and go for a 1200W if some of these other tests don't move the ball forward, and if that doens't cut it then I'll likely take the mobo back for a different brand. I'm used to the Asus ROG Maximus series having used it for my last build, will probably go with that one.
post #14 of 23 (permalink) Old 06-24-2019, 02:53 AM - Thread Starter
overvolted's Avatar
Couple more things I've noticed.. Overwatch which never dropped below 144fps on my old rig with the 1080 Ti now occasionally hits low 130's and stutters once in a blue moon on the 2080Ti. Also my start menu is looking a bit strange. There's a green pattern overlaying part of the menu. This is on a fresh install:
https://i.imgur.com/rTZecCC.jpg
https://i.imgur.com/7sut01O.jpg
post #15 of 23 (permalink) Old 06-24-2019, 06:59 PM
wirefox's Avatar
wierd, what sort of monitor do you have e/g 4k or like a 1080p? maybe try another cable and check that they are secure. I have a 34" 120hz curved ips predator and play on med-low and get 240-300 on overwatch...
Also I'd really suggest again updating your gpu driver in safemode...
lastly, you might want to re-install windows.. I know it's a pain.
wirefox
wirefox is offline
post #16 of 23 (permalink) Old 06-25-2019, 03:16 PM
munternet's Avatar
Rep: 5 (Unique: 4)
I use a chopped down version of windows from teamos to replace my ligit version and get a much better windows and maybe gaming experience
Battle PC
(15 items)
8700k @ 5.2ghZ
Maximus X Hero
EVGA 1080 Ti Superclock 2 Black
32GB 1xF4-4400C19D-16GTZSW & 1xF4-4400C19D-16GTZKK
Sansung M.2 1TB 970 EVO
Corsair HX1200i
EK 140D5 Pump, waterblocked CPU, Ram, GPU with 2x 360mm Radiators and Vardar Fans
ThermalTake V51
Operating System
Windows 10 Lite
Dell Computer DELL U3415W 34.1 inches 3440 x 1440 pixels @ 48-85 Hz
Keyboard
Corsair K95 RGB Platinum
Mouse
Asus Spatha Wireless Gaming
Mouse
Ligitech G602 wireless
Mousepad
1000mm x 500mm
Audio
Steelseries Siberia800 wireless Headset
munternet is offline
post #17 of 23 (permalink) Old 06-25-2019, 06:07 PM
Mongo's Avatar
Rep: 52 (Unique: 49)
Quote: Originally Posted by ntuason View Post
Desktop experience is very smooth. Absolutely no problems there. As for start up I just timed it (LOL) and 4.3sec from powered off to desktop. It should no be taking more than 10 seconds IMO. But then again I disabled a top of start up software.
Pics or it didnt happen. LOL!
OK I have:
Intel 9900K @5.0
GIGABYTE Z390 Aorus Master.
Nvidia Geforce 2080 Ti @+100 Core +1000 Memory
HP EX920 M.2 256GB PCIe 3.0 Boot drive.
Here is boot time in Task Manager fast boot off
And then other info.
In windows it is never choppy and I only have some stutters in online games and thats due to the game.
Mongo is offline
post #18 of 23 (permalink) Old 06-25-2019, 06:19 PM
9 Cans of Ravioli
The Pook's Avatar
Rep: 1019 (Unique: 614)
Quote: Originally Posted by Mongo View Post
snip
never knew there was a boot timer in task manager, news to me ... but it definitely takes me more than ~9 seconds to go from power off to desktop.
maybe from the Windows log-in to loaded at the desktop, but not BIOS to desktop.
Intel i9 9900K Coffee Lake @ X8 5309mhz (+47.5%)
AMD FX-8320 Vishera @ X4 5022mhz (+43.5%)
Intel i5 4690K Haswell @ X4 5013mhz (+43.2%)
AMD X4 960T Zosma @ X6 4870mhz (+62.3%)
Intel i7 6700 Skylake @ X4 4709mhz (+38.5%)
Intel i5 6400 Skylake @ X4 4588mhz (+69.9%)
2 OP pls nerf
(24 items)
NUC U
(10 items)
i9 9900K
AsRock Z390 Taichi
MSI GTX 1080 Ti
G.Skill DDR4 4133 32GB
Mushkin Pilot NVMe 1TB
HP EX950 NVMe 2TB
Samsung 860 Evo 1TB
Sandisk Ultra II 480GB SSD
Toshiba X300 5TB
Western Digital EZRZ 3TB
Seasonic Focus Plus Gold 750w
Corsair H115i Pro
Fractal Design Meshify S2
Operating System
Windows 10 Education x64
Acer XF270HU
Dell E2311H
Keyboard
CoolerMaster MasterKeys Pro S
Mouse
Logitech G502
Audio
SMSL SA50 + FiiO E10K
Audio
Micca RB42
Audio
Polk Audio PSW111
Audio
Philips Fidelio X2
Audio
Philips SHP9500S
Audio
Audio Technica ATH-M50X
i3 8109U
Intel NUC8i3BEH
Iris Plus 655
Kingston 8GB DDR4 2400
Dierka K1 120GB
ADATA SU800 128GB M.2
Operating System
Windows 10 Professional
Operating System
MX Linux
Keyboard
Rii RKM709 Wireless
Mouse
Logitech M510
i7 860
Advantech AIMB 280 ITX
EVGA GTX 950 2GB
Kingston 2GB DDR3 1333
Seagate Momentus 2.5" 500GB
Western Digital Blue 2.5" 320GB
Silverstone SFX-L Gold 500w
Arctic Alpine 11 GT 2
Silverstone Milo Z ML07B
Operating System
Windows XP x86 SP3
Keyboard
Velocifire TKL01 Outemu Browns
Mouse
Logitech M512
The Pook is offline
post #19 of 23 (permalink) Old 06-25-2019, 06:39 PM
Mongo's Avatar
I think that's just Bios time it doesn't add Windows load time. Could be wrong never timed it out side of Task Manager.
Mongo is offline
post #20 of 23 (permalink) Old 06-25-2019, 07:32 PM
ntuason's Avatar
Rep: 167 (Unique: 151)
A few seconds slower than fresh install.
Intel® Core™ i9-9900K @ 5GHz
Gigabyte Z390 AORUS Master
MSI GeForce RTX 2080 Ti Gaming X TRIO 2120/8300 (406w)
G.Skill Trident Z Royal @ 4133MHz CL18
Samsung 970 EVO Plus NVMe - M.2
Samsung SSD 850 EVO
Samsung SSD 850 EVO
Corsair AX1200
NZXT Kraken X72 360mm Push/Pull
Corsair Obsidian Series 800D
Lian Li PC-011 Dynamic
Operating System
Windows 10 Pro 64bit
Samsung CHG70 32" 1800R QLED, 1ms (GTG) 1440p 144Hz
Keyboard
Filco Majestouch 2 Cherry MX Red
Keyboard
Logitech G513 Romer-G
Mouse
Logitech G703 Wireless
Mousepad
Logitech G840
Audio
Kanto Yu4 + Kanto SUB8 8-Inch
Audio
Audeze LCD-4
ntuason is offline
