9900k / 2080 TI seems a bit choppy - Page 3 - Overclock.net - An Overclocking Community
post #21 of 23 (permalink) Old 06-26-2019, 04:23 PM
wirefox's Avatar
Rep: 30 (Unique: 28)
Quote: Originally Posted by Mongo View Post
Pics or it didnt happen. LOL!
OK I have:
Intel 9900K @5.0
GIGABYTE Z390 Aorus Master.
Nvidia Geforce 2080 Ti @+100 Core +1000 Memory
HP EX920 M.2 256GB PCIe 3.0 Boot drive.
Here is boot time in Task Manager fast boot off
And then other info.
In windows it is never choppy and I only have some stutters in online games and thats due to the game.
Okay I think I see why you are still choppy.
Look at the Bus Interface on your image on GPUID while it records you as PCie x16 3.0 x16 1.1
This means your gpu is running at a 1.1 bandwidth hence why its stutter. see mine attached (practially the same rig but xtreme mobo)
you may try to change this in your pcie in bios to 3.0
you may want try to check which slot your gpu is in to ensure the slot is a 3.0
you maybe using too many pcie lanes with 2x m.2 and gpu == so your m.2 could be holding back your gpu lanes...
wirefox.
Aorus Xtreme z390 |Intel i9900 5.1 | GSkill ram 3600 16 cas | Aorus waterforce 2080ti | x34 predator 120hz monitor | NXTZ x63 AIO| custom GPU loop EK x360 | enermax Neochanger Pump
wirefox is offline
post #22 of 23 (permalink) Old 06-26-2019, 07:34 PM - Thread Starter
overvolted's Avatar
Rep: 33 (Unique: 32)
Quote: Originally Posted by wirefox View Post
wierd, what sort of monitor do you have e/g 4k or like a 1080p? maybe try another cable and check that they are secure. I have a 34" 120hz curved ips predator and play on med-low and get 240-300 on overwatch...
Also I'd really suggest again updating your gpu driver in safemode...
lastly, you might want to re-install windows.. I know it's a pain.
wirefox
It's a PG279Q but that's a good idea too with trying a new DP cable. I had issues with the first few DP cables I tried including the one that came with the monitor.
overvolted is offline
post #23 of 23 (permalink) Old 06-26-2019, 07:37 PM
Mongo's Avatar
Rep: 52 (Unique: 49)
wirefox.
First off I'm not the OP.
And I don't have a problem with choppy. Also in GPUZ it show the bus @ 1.1 until there is a load then it goes to 3.0.
Mongo is offline
