Will Thermal Paste Save Me? - Overclock.net - An Overclocking Community
post #1 of 7 (permalink) Old 08-18-2019, 08:24 AM - Thread Starter
Rep: 0
I just bought some used hardware as a bundle, i5-4690k, 2x 8 GB ram, and be quiet! cooler (Shadow Rock LP i think), to replace my 8 gb ram and i3-4170 with its factory cooler.
The i5 has no thermal paste on it, the i3 had some from the factory (was like 3-4 years old).
After the change I realised that my PC performance was a bit lower than before, especially considering it went from 8gb ram to 16gb.
After reading some threads I updated my BIOS, that gave me like 3-5 more fps. I decided to check my CPU temperature, which I never did before, so I downloaded CoreTemp.The temperature is like 60-68°C when only Steam and Google is running. When I start playing something it goes to 100° and a bit above.
I dont have any air intake/outtake ventilations, I was always doing finde without them... looking forward to getting some though.
So the question is, do I get such temperature numbers and weaker performance because I have no thermal paste?
Mainboard: H81M-A
GPU: GTX 970
Power Supply: 600W noname, was built into the case (does the job)
WuTangDan is offline
post #2 of 7 (permalink) Old 08-18-2019, 08:43 AM
The last VRM burner
Rep: 23 (Unique: 13)
It will improve things but not to this extent.
PC for all
(18 items)
i7 5775c @4.2GHz/3.8GHz
Gigabyte Z97X Gaming 5
Soon to be 2070 Super FE
KHX24C11T3K2/16X 11-12-12-32-1T-250
Corsair MP510
Samsung Evo 860
SeaSonic Focus Plus 750W
Raijintek Tisis lapped+ Thermal Grizzly Kryonaut
LianLi 330X
Operating System
Windows 10 64-bit Pro
Benq GL2250 80Hz
Keyboard
Corsair Strafe Red Silent
Mouse
SteelSeries Rival 310
Mousepad
Artisan FX Raiden
Audio
Audio in Motion SC808 + MUSES8820 + 2x 2xLME49990
Audio
AKG M220
Other
NZXT Hue+
Other
Mayflash F300 Arcade Stick
BroadPwns is offline
post #3 of 7 (permalink) Old 08-21-2019, 02:17 AM
Rep: 57 (Unique: 56)
Yes, clean it good with isoproyl alcohol and use a good paste like Noctua NT-h1/h2 or Kryonaut
DoctorNick is offline
post #4 of 7 (permalink) Old 08-21-2019, 02:42 AM
Graphics Junkie
UltraMega's Avatar
Rep: 30 (Unique: 26)
So you are not using any thermal paste? You cannot do that. You need thermal paste. It's cheap, you can buy it anywhere that sells computer stuff.
https://www.amazon.com/Arctic-Silver...gateway&sr=8-4
i7 7700kK @4.2ghz
16GB DDR4 3200mhz
GeForce 1080 Ti
UltraMega is offline
post #5 of 7 (permalink) Old 08-21-2019, 07:57 PM
- Insanity Beckons -
Elrick's Avatar
Rep: 172 (Unique: 88)
It already comes applied from the factory hence those that purchase these cpu's aren't worried about thermal paste, as their product is covered .
It's us here on OCN that know about what is applied at the factory and will know better to remove it instantly from the heat sink being used and buy a popular paste recommended by those with more experience.
Almost NEVER use any factory heat-sinks when buying Intel (long time ago) or AMD (today). Far better to buy and use Noctua, Thermalright or Cryorig.
Elrick is offline
post #6 of 7 (permalink) Old 08-21-2019, 08:02 PM
Lexi is Dumb's Avatar
Rep: 35 (Unique: 27)
"Used hardware as a bundle"
"and be quiet! cooler (Shadow Rock LP i think), to replace"
"The i5 has no thermal paste on it, the i3 had some from the factory"
"do I get such temperature numbers and weaker performance because I have no thermal paste?"
Yes OP, you always need thermal paste. Holy moly that's bad.
Panthera
(14 items)
Ryzen 7 3700X
Aorus X570 Pro Wifi
MSI Gaming X Trio RTX 2080
G.Skill Trident Z 16GB 3200Mhz CL14
1TB Samsung 860 Evo
Corsair HX750 Platinum
Noctua NH-D15 w/Chromax
NZXT H700
Acer XB271HU [email protected] Gsync
Samsung LU32H850 [email protected] Freesync
Keyboard
Coolermaster Pro S TKL
Mouse
Logitech G703
Audio
M50X & M50Xbt
Audio
Edifier S880DB
Lexi is Dumb is offline
post #7 of 7 (permalink) Old 08-21-2019, 08:39 PM
The last VRM burner
I ran the 5775c unlapped at 4GHz with no thermal paste with this cooler, 80C was the most I could see in Prime95
PC for all
(18 items)
Corsair MP510
Samsung Evo 860
LianLi 330X
Operating System
Benq GL2250 80Hz
Keyboard
Mouse
Mousepad
Artisan FX Raiden
Audio
Audio
AKG M220
Other
NZXT Hue+
Other
