£380 Build advice - Page 3 - Overclock.net - An Overclocking Community
£380 Build advice
post #21 of 30 (permalink) Old 08-20-2009, 12:36 PM - Thread Starter
woodpigeon4's Avatar
Rep: 303 (Unique: 228)
Originally Posted by el gappo View Post
might want to look for a plantronics gamecon headset. way better than that one. great build for the price tho. intel does make it harder
OK, I'll change that. Thanks, you've been so much help
woodpigeon4 is offline
post #22 of 30 (permalink) Old 08-20-2009, 12:39 PM
dennyb's Avatar
Rep: 439 (Unique: 193)
Hello woodpigeon, been a while. If you could work a Ga-ep45-UD3L into the budget . It would be a great addition
dennyb is offline
post #23 of 30 (permalink) Old 08-20-2009, 12:40 PM - Thread Starter
Hey man, sure has been - how you doing? TBH I don't know if he'd appreciate that board, as I'll only be OCing on the stock cooler, and those boards are really hard to get over here (I should know, I've been trying to get one for myself)
post #24 of 30 (permalink) Old 08-20-2009, 12:43 PM
dennyb's Avatar
I'm good. Hope the build goes well for you and your friend
dennyb is offline
post #25 of 30 (permalink) Old 08-20-2009, 12:44 PM - Thread Starter
Thanks - his old PC is an athlon XP that idles around 80c and constantly BSODs and loops at startup, so it's a massive upgrade
post #26 of 30 (permalink) Old 08-20-2009, 01:45 PM
Rep: 6 (Unique: 6)
Gigabyte GA-G31M-ES2L iG31 Socket 775 onboard VGA 7.1 channel audio mATX Motherboard £32.69
Crucial 4GB (2X2GB) DDR2 800MHz/PC2-6400 Ballistix Memory CL4 2.0 £36.99
Intel Pentium Dual Core E5200 2.5GHz Socket 775 800FSB 2MB Cache Retail £46.17
Arctic Cooling AC-ALP-7P Alpine 7 Pro Socket 775 CPU Cooler £7.91
550W ATX Silent Neon PSU - £25.01
CIBOX C2201 22'' Widescreen TFT 1680x1050 1000:1 300cd/m2 5ms inc speakers 3 Years Warranty £98.39
Zotac GTS250 512MB DDR3 Dual DVI HDTV Out PhysX and Cuda ready PCI-E Graphics Card Including World Of Warcraft 30 Day Full Game Trial While Stocks Last £82.99
(Ebuyer Prices)
Total - £330.15 Free Shipping
Kluez is offline
post #27 of 30 (permalink) Old 08-20-2009, 01:48 PM - Thread Starter
Thanks man, but I've already planned a similar build, see the OP. Basically, I just want any suggestions on how to make the planned build any better without costing any more
post #28 of 30 (permalink) Old 08-20-2009, 05:32 PM
CravinR1's Avatar
Rep: 990 (Unique: 751)
My brother had the same problem with a old xp 2100+. Ends up his oem amd fan was failing (he had the computer 6 or 7 years ran it 24/7) and I replaced the stock cooler with a aftermarket one and his computer ran 20 degrees cooler (this was a $12.99 cooler, not a good one) so maybe he can get another cpu cooler and use this as a backup of some sorts??
R7 [email protected] XFX rx5700 DD (XT vbios) https://valid.x86.fr/ed8tpx
R5 [email protected] MSI rx5700 Mech OC https://valid.x86.fr/hersi6
R7 [email protected] MSI 980ti https://valid.x86.fr/jxeld9
Backup GPU 1070ti
3700x
MSI X470 Gaming Plus
XFX 5700 DD Ultra (XT Thicc II Vbios)
G.Skill Neo 32gb cas 16 RGB
Adata SX8100 1TB NVME
Samsung 1tb m.2
Toshiba 3tb
Toshiba 3TB
Seasonic 1050x
Gammax 400
Fractal Meshify C
Ryzen 5 3600 4.3ghz 1.2v
MSI B450 Tomahawk
MSI rx5700 Mech OC
Patriot Viper 16gb 3600mhz (2x8gb)
Intel 660P 1TB NVMe
WD 3tB Blue
Toshiba 3TB
Toshiba 3TB
Corsair 750watt semi-modular
Wraith Prism (2700X stock)
Deepcool Matrexx 70
Ryzen 7 2700x
Gigabyte B350 Gaming 3
EVGA 1070ti FTW
G.Skill RGB 16gb 3200mhz
WD SN750 500gb NVMe
Rosewill HIVE 750w semi-modular
Gammax 400 + UpHere RGB Fan
Phanteks P300 White
CravinR1 is offline
post #29 of 30 (permalink) Old 08-20-2009, 11:33 PM
vnv727's Avatar
Rep: 26 (Unique: 22)
I got some ram for £25 off el gappo (thanks mate), so here's my planned build:
Corsair CX 400W PSU
Gigabyte GA-G31M-E2SL
E5300
Creative fata1ity gaming headset
hanns g HG221AP monitor
Asus 4850
A bit under budget I know, but he hasn't got much cash and I thought it would be great for his needs
Your chosen psu seems a bit underpowered to me.....
I personally would get something between 480w-600w
"Last night I actually had a dream my flour sack was abducted and the kidnappers started sending me muffins in the mail." Niles Crane on Frasier
vnv727 is offline
post #30 of 30 (permalink) Old 08-20-2009, 11:42 PM
SharkFin's Avatar
Rep: 66 (Unique: 55)
a Corsair 400w psu will power that lot easily. They are quality units.
HT is kind of dumb...if you had a 12" penis would you cut in half to have two 6" ones?
SharkFin is offline
