Prime95: A Quick & Dirty Guide To The Custom Settings - Overclock.net - An Overclocking Community
post #1 of 42 (permalink) Old 10-04-2010, 05:45 PM - Thread Starter
tmunn's Avatar
Rep: 78 (Unique: 73)
Have you ever heard something like "The NB is stressed the most during 512K FFTs. This happens about 2-3 hours into Blend"? Or, have you ever had Prime95 consistently fail on the same FFT size? Well, that's when the custom test comes in handy.
Pre-set Modes
We all know about the three pre-set modes available for Prime95: Small FFTs, In-Place FFTs, and Blend. Small and In-Place modes test the FPU and caches. Blend mode tests everything, including RAM.
Custom Mode
By selecting Custom, you have total control over which FFT size/s are run. In general, the smaller FFTs stress the CPU, while the larger FFTs stress the memory and chipset - with one exception, the "in place" FFT.
What is an "in-place" FFT?
An "in place" FFT is simply an FFT that is calculated entirely inside its original sample memory. In other words, calculating an "in place" FFT does not require additional buffer memory. - Source(#2.3)
Ok, so between the definition above and the fact that Prime95 labels the "In-place large FFTs" test as max heat, power, and some RAM tested. We know that when the FFTs are "in place", the RAM and chipset aren't being tested all that hard, regardless of the FFT size.
Conclusion
Below are a few screen shots of different custom tests.
CPU Test
RAM & Chipset Test
Note: when not using the "in place" option, be careful not to set the "memory to use" too high. If it's set too high, the system will start to use the paging file which will not stress the RAM.
Oh noes...it's always failing at 512 FFT size and I don't want to wait two hours for blend to reach that test
or you could do something like this
Maybe this is common knowledge to most here? If not, this should give you a general idea of what to do.
tmunn is offline
post #2 of 42 (permalink) Old 10-05-2010, 11:37 PM
Not new to Overclock.net
TwoCables's Avatar
Rep: 6215 (Unique: 3521)
Whoa, very nice. I like it so much that I reported this thread saying, "I feel that this needs to be stickied" in the report.
In other words, I didn't know this stuff, and now I'm extremely glad I do.
Loneliness is a good thing to share with someone.
The virtuous spirit has no need for thankful approval, owning a certain conviction that what has been done is right.
i5-2500K @ 4.5GHz (1.368-1.384V fixed voltage)
ASUS P8P67 EVO B3 (UEFI ver. 1850)
MSI GTX 1070 Ti Gaming Titanium 8G
G.SKILL Ripjaws X 8GB (2 x 4GB) 1866MHz, CL9
250 GB Samsung 840 EVO (OS)
3 TB Toshiba P300 (D: drive)
Optical Drive
Samsung SH-S243N 24x DVD Burner
Optical Drive
Samsung SH-S203N 20X DVD Burner
Corsair RM550x
Thermaltake Frio
CM 690
Operating System
Windows 10 Home
AOC G2460PG (24" 1920 x 1080 144Hz G-SYNC)
Keyboard
Filco Majestouch 104-key Cherry MX Blues w/NKRO
Mouse
Intellimouse Optical (1.1A) 1000Hz polling rate
Mousepad
It's just a mousepad
Audio
X-Fi Titanium HD
Audio
Klipsch ProMedia 2.1 (with 16 AWG Monster Cable speaker wires)
TwoCables is offline
post #3 of 42 (permalink) Old 10-19-2010, 04:38 PM
Rep: 21 (Unique: 20)
Should 3gb be entered in amount of memory to use for 4gb system? Or should i just copy and paste linx amount memory use during all test since it usually leaves like 400-500mb left and memory usage at like 90%.
ITaoI is offline
post #4 of 42 (permalink) Old 10-19-2010, 10:41 PM
TwoCables's Avatar
If you're careful enough, then you can probably get it to use 3300, or maybe even 3350. This would be roughly 95-96%.
Optical Drive
Optical Drive
Corsair RM550x
Thermaltake Frio
CM 690
Operating System
Windows 10 Home
Keyboard
Mouse
Mousepad
Audio
X-Fi Titanium HD
Audio
post #5 of 42 (permalink) Old 10-20-2010, 10:07 AM
Rep: 221 (Unique: 143)
tmunn,very nice thread
radaja is offline
post #6 of 42 (permalink) Old 10-20-2010, 12:02 PM - Thread Starter
tmunn's Avatar
You could use linx or the performance tab in windows task manager to calculate how much memory to use. Whatever you do, be careful not to go over, or the test may be run in vain.
Thank you.
tmunn is offline
post #7 of 42 (permalink) Old 10-20-2010, 12:24 PM
Rep: 45 (Unique: 35)
Great info. I've always just used blend for chipset and memory and small ffts for cpu.
Going by what you've posted I was able to determine that my nb needed more voltage. In turn was able to lower vcore.
Forgot that I had started running my ddr2 800 at 1066.
onnetz is offline
post #8 of 42 (permalink) Old 10-20-2010, 12:26 PM
Shrimpykins's Avatar
Rep: 296 (Unique: 231)
I am totally messing around with my overclock when I get home!
Great post! +rep!
Shrimpykins is offline
post #9 of 42 (permalink) Old 10-20-2010, 12:32 PM
saiyanzzrage's Avatar
Rep: 56 (Unique: 44)
wow, excellent, i always just hit blend and crossed my fingers..but now i can actually see what is not stable and single it out, like either ram/nb or cpu!
thanks so much!
4.1 - 4.2 here i come! (hopefully)
“I am what was, what is, what will be — the black angel, Chaos-Bringer! I AM POWER!” Dark Phoenix, Uncanny X-Men #136
saiyanzzrage is offline
post #10 of 42 (permalink) Old 10-20-2010, 12:39 PM
wait im confused...if nb is stressed the most at 512k FFT then why did you specify 2048 - 4096k fft to test ram/chipset?
if i want to test my nb stability, should i put 512k fft or the 2048 - 4096k??
