How to remove the pins from an ATX power supply with staples - Overclock.net - An Overclocking Community
post #1 of 24 (permalink) Old 05-04-2011, 01:36 AM - Thread Starter
Philistine's Avatar
Rep: 206 (Unique: 166)
After doing a search of OCN I couldn't find a tutorial on removing pins from an ATX power supply using staples (there may be one but I couldn't find it). Just a lot of questions on how to do it.
Why spend $25+ on a pin removal tool that may break when you can spend $1.50 on 2000 staples and get the job done just as easy?
Why would you want to remove the pins on your ATX cables? You may want to make custom length cables or maybe you want to sleeve your power supply or maybe you screwed up and accidentally cut a lead to your PSU and need to repair it. Whatever. So here's how I do it.
Tools:
  • Common desk staples (not the "Heavy Duty" staples you'd use to secure roofing paper or wall insulation)
  • Needle nose pliers
  • Your fingers
  • A bit of patience
WORD OF CAUTION: Your PSU can hold a dangerous charge! To discharge your PSU unplug it from the wall outlet and then press the power button on your PC. You can also jump the green wire on your 24-pin motherboard connector to a black wire. Doing either will discharge the PSU. Ignore this step at you're own risk!
First take two sets of two staples and bend them into an "L" shape. Using the needle nosed pliers makes this a bit easier.
Next insert each pair of staples into either side of the pin housing. Be sure the staples are between the pin and the plastic housing.
Now push up on the wire while pushing down on the staples. You should feel a very slight "click" as the staples compress the tabs on the pin. You can also use the needle nose pliers to push in the staples if they don't go in by the force of your finger.
Now, while holding down on the staples, pull on the wire. It may take a bit more force than you expect and you can use the needle nose pliers to pull the wire if needed. The pin will pop free.
Slide the pin out and you're done!
Before you put the pin back in the housing lift the tabs back up a little (I use a razor blade but any small instrument will work).
Philistine is offline
post #2 of 24 (permalink) Old 05-04-2011, 02:14 AM
Rep: 36 (Unique: 33)
()ut[@st is offline
post #3 of 24 (permalink) Old 05-08-2011, 11:57 AM
Churminess's Avatar
Rep: 9 (Unique: 9)
Nice tut, +rep for no handed photography and an excellent tutorial.
Makes me sometimes wish for a simpler world where we all have symbian and everybody is holding hands and singing kumbyah
I mostly hate Apple for their crimes against UI
Churminess is offline
post #4 of 24 (permalink) Old 05-09-2011, 08:35 PM - Thread Starter
Philistine's Avatar
Thanks guys! It was pretty difficult to hold the camera in my mouth to take the pictures but it worked.
post #5 of 24 (permalink) Old 05-12-2011, 05:05 AM
The Red Dojo's Avatar
Rep: 3 (Unique: 2)
The Red Dojo is offline
post #6 of 24 (permalink) Old 05-12-2011, 01:19 PM
Waiting for 7nm EUV
tpi2007's Avatar
Rep: 900 (Unique: 504)
Useful info, thanks! Rep+
tpi2007 is offline
post #7 of 24 (permalink) Old 06-24-2011, 12:15 AM - Thread Starter
Philistine's Avatar
post #8 of 24 (permalink) Old 08-08-2011, 06:28 AM
CTRLurself's Avatar
Rep: 262 (Unique: 224)
Free bump for good info.
A little tip though: you can use a knife or flat blade screwdriver to consistently split off pairs of staples for this trick. And once you get good at it, this is MUCH faster and easier than using an pin removal tool.
Term of Service: If I can google your question and get a correct answer in the first 5 links, on my first try; I reserve the right to link you through Let MeGoogleThatForYou.com with the number for the correct answer.
CTRLurself is offline
post #9 of 24 (permalink) Old 08-12-2011, 11:17 PM
Rep: 98 (Unique: 55)
Never thought of that. Nicely done! +REP
thumb.gif YOU thar... with the expensive hardwarez..... YOU SHOULD BE FOLDING FOR A CURE!!!! |XPD's HFM Stats| thumb.gif
|"Teneo Vestri" ~☼~ "Know Thyself"|I usually try to say something humorous or helpful unless inebriated in some way. Feel free to PM me about anything. wink.gif| I fold now and as long as I can, for SYRILLIAN.|This. (Click to show)
This:
Good taste is subjective, bad taste is universal.
welcome to ocn, your computer will love you, your wallet will hate you, and your family will miss you
XPD541 is offline
post #10 of 24 (permalink) Old 10-13-2011, 08:25 AM
adamski07's Avatar
Rep: 96 (Unique: 82)
adamski07 is offline
