Can Corsair HX620w handle sig rig? - Overclock.net - An Overclocking Community
post #1 of 16 (permalink) Old 06-17-2011, 10:30 AM - Thread Starter
txtrkandy's Avatar
Rep: 31 (Unique: 20)
Currently I am running dual PSU's in my sig rig, neither of them are great but the Rosewill is running my Mobo, CPU, Disk drives and HDD's
The HEC is running my GPU's, Fans, LEDs
I have a Corsair HX 620w PSU, would that be enough to run my rig? I would like to take the Dual PSU out (for space reasons) but im not sure...
According to Newegg PSU calculator with (2) 5770's I should be fine by a few watts, but can someone help me out?
Thanks!
txtrkandy is offline
post #2 of 16 (permalink) Old 06-17-2011, 10:33 AM
gorb's Avatar
Rep: 145 (Unique: 114)
sure. runs mine just fine.
gorb is offline
post #3 of 16 (permalink) Old 06-17-2011, 10:33 AM
Yumyums's Avatar
Rep: 215 (Unique: 170)
Yeah you'll be fine, those card's aren't power hungry either
Yumyums is offline
post #4 of 16 (permalink) Old 06-17-2011, 10:34 AM
PureOC Jim's Avatar
He has 2 GPU's
PureOC Jim is offline
post #5 of 16 (permalink) Old 06-17-2011, 10:34 AM
H4rd5tyl3's Avatar
Rep: 61 (Unique: 54)
Yes. My brother uses the same psu for his rig which is like 99% identical to mine and it's perfectly fine.
H4rd5tyl3 is offline
post #6 of 16 (permalink) Old 06-17-2011, 10:34 AM
Rep: 14 (Unique: 14)
620w is:thumb:
tiramoko is offline
post #7 of 16 (permalink) Old 06-17-2011, 10:34 AM
xXSebaSXx's Avatar
Rep: 72 (Unique: 62)
You should be more than OK with the HX620W. I run a very similar setup to yours; the only significant difference is I run a HD6950 instead of dual 5770s and I run my setup on a Corsair VX450 without issues. The HX620 is more than enough for your rig.
xXSebaSXx is offline
post #8 of 16 (permalink) Old 06-17-2011, 10:35 AM
Kasp1js's Avatar
Rep: 71 (Unique: 70)
Definitely enough.
Kasp1js is offline
post #9 of 16 (permalink) Old 06-17-2011, 10:35 AM
PureOC Jim's Avatar
Originally Posted by yumyums;13907576
yeah you'll be fine, those card's aren't power hdungry either
+1
post #10 of 16 (permalink) Old 06-17-2011, 10:35 AM
Rep: 473 (Unique: 380)
Very, very easily. Newegg's calculator is junk, don't use it, but if even that says you're fine, you're more than more than fine.
Shub is offline
