Real World Power Usage (User Submitted Values) - Page 3 - Overclock.net - An Overclocking Community
post #21 of 210 (permalink) Old 09-28-2011, 01:29 PM
MMJA's Avatar
Rep: 34 (Unique: 31)
Here's the data for a previous configuration of my rig at various states of OC, thought it is a good representation of how OCing various components bump up the power requirement. Only component that changed was an i7 920 instead of 930 and 1 GTX 570. I'll fill out a complete form for each state of OC.
Stock (mobo bios reset to factory defaults, all auto voltages and stock frequencies, C1E + Speedstep enabled. GPU set to the factory overclock of 780/1900 @ 0.975v)
i7 920 @ 2.67GHz . Asus Rampage III Formula . (3) 1.65V Memory . (1) GTX 570 @ 780/1560/1900 @ 0.975v . (2) HDD (1 7200rpm + 1 5900rpm), (1) SSD (OCZ Vertex 2) . (1) Optical Drive . (3) 3.36W Fans, (2) 5.4W Fans (1) 1.68W Fan, (1) 2.4W Fan . Enermax Revolution85+ 1050W @ 85%-89%-85% Efficiency @ 20%-50%-100% load (240V AC input)
Idle: 174W -> ~85% efficient -> 147.9W
CPU load (Prime95 small FFT): 258W -> ~85% efficient -> 219.3W
GPU load (3DMark 11 GPU test 1): 338W -> ~86% efficient -> 290.7W
CPU + GPU load (P95 + 3D Mark 11): 424W -> ~87% efficient -> 368.9W
CPU OC (CPU at 3.6GHz @ 1.32500v, 1.30000vTT, C1E + Speedstep disabled)
i7 920 @ 3.6GHz @ 1.32500V, 1.30000vTT . Asus Rampage III Formula . (3) 1.65V Memory . (1) GTX 570 @ 780/1560/1900 @ 0.975v . (2) HDD (1 7200rpm + 1 5900rpm), (1) SSD (OCZ Vertex 2) . (1) Optical Drive . (3) 3.36W Fans, (2) 5.4W Fans (1) 1.68W Fan, (1) 2.4W Fan . Enermax Revolution85+ 1050W @ 85%-89%-85% Efficiency @ 20%-50%-100% load (240V AC input)
Idle: 196W -> ~85% efficient -> 166.6W
CPU load (Prime95 small FFT): 309W -> ~86% efficient -> 265.7W
GPU load (3DMark 11 GPU test 1): 359W -> ~86% efficient -> 308.7W
CPU + GPU load (P95 + 3D Mark 11): 480W -> ~88% efficient -> 422.2W
GPU OC (CPU reset back to stock, GPU set to 800/1600/1950 @ 1.000v)
i7 920 @ 2.67GHz . Asus Rampage III Formula . (3) 1.65V Memory . (1) GTX 570 @ 800/1600/1950 @ 1.000v . (2) HDD (1 7200rpm + 1 5900rpm), (1) SSD (OCZ Vertex 2) . (1) Optical Drive . (3) 3.36W Fans, (2) 5.4W Fans (1) 1.68W Fan, (1) 2.4W Fan . Enermax Revolution85+ 1050W @ 85%-89%-85% Efficiency @ 20%-50%-100% load (240V AC input)
CPU load (Prime95 small FFT): 259W -> ~85% efficient -> 220.1W
GPU load (3DMark 11 GPU test 1): 357W -> ~86% efficient -> 307.0W
CPU + GPU load (P95 + 3D Mark 11): 447W -> ~88% efficient -> 393.4W
CPU + GPU OC (CPU set to previous OC of 3.6GHz, GPU set to 850/1950 OC)
i7 920 @ 3.6GHz @ 1.32500V, 1.30000vTT . Asus Rampage III Formula . (3) 1.65V Memory . (1) GTX 570 @ 800/1600/1950 @ 1.000v . (2) HDD (1 7200rpm + 1 5900rpm), (1) SSD (OCZ Vertex 2) . (1) Optical Drive . (3) 3.36W Fans, (2) 5.4W Fans (1) 1.68W Fan, (1) 2.4W Fan . Enermax Revolution85+ 1050W @ 85%-89%-85% Efficiency @ 20%-50%-100% load (240V AC input)
Idle: 198W -> ~85% efficient -> 168.3W
CPU load (Prime95 small FFT): 311W -> ~86% efficient -> 267.5W
GPU load (3DMark 11 GPU test 1): 378W -> ~86% efficient -> 325.1W
CPU + GPU load (P95 + 3D Mark 11): 496W -> ~88% efficient -> 436.5W
CPU + SLI GPU OC (CPU set to 3.6GHz OC, SLI GTX 570s set to 800/1600/1950 @ 1.025v/1.000v (GPU 1/GPU 2)
i7 920 @ 3.6GHz @ 1.32500V, 1.30000vTT . Asus Rampage III Formula . (3) 1.65V Memory . (2) GTX 570 @ 800/1600/1950 @ 1.025v/1.000v (GPU1/GPU2) . (2) HDD (1 7200rpm + 1 5900rpm), (1) SSD (OCZ Vertex 2) . (1) Optical Drive . (3) 3.36W Fans, (2) 5.4W Fans (1) 1.68W Fan, (1) 2.4W Fan . Enermax Revolution85+ 1050W @ 85%-89%-85% Efficiency @ 20%-50%-100% load (240V AC input)
Idle: 215W -> ~85% efficient -> 182.8W
CPU load (Prime95 small FFT): 333W -> ~86% efficient -> 286.4W
GPU load (3DMark 11 GPU test 1): 592W -> ~89% efficient -> 526.9W
CPU + GPU load (P95 + 3D Mark 11): 715W -> ~87% efficient -> 622.1W
Hope that data helped, there are some overlapping numbers there which I thought showed my testing was consistent throughout.
MMJA is offline
post #22 of 210 (permalink) Old 09-28-2011, 02:09 PM
Retired Staff
Phaedrus2129's Avatar
Rep: 1730 (Unique: 1138)
Tell ya what, if you can get numbers from ten users I'll sticky this.
Burning books is like burning bras; after the adrenaline rush of the symbolic moment wears off all you're left with is a pile of ashes and unsupported boobs.
Phaedrus2129 is offline
post #23 of 210 (permalink) Old 09-28-2011, 08:24 PM - Thread Starter
AMC
AMC's Avatar
Rep: 269 (Unique: 217)
Originally Posted by MMJA;15103173
Here's the data for a previous configurations of my rig at various states of OC, thought it is a good representation of how OCing various components bump up the power requirement. Only component that changed was an i7 920 instead of 930 and 1 GTX 570. I'll fill out a complete form for each state of OC.
Hope that data helped, there's some overlapping numbers there which I thought showed my testing was consistent throughout.
Greatly appreciate your contribution. +rep.
Sounds good. I have a few people that said it has helped. I believe this has potential.
Quotes. (Click to show)Warning: Spoiler! (Click to show)
Response to working with Bulldozer before release.
If you can record your computer's load power in wattage, please click below to help out thumb.gif
AMC is offline
post #24 of 210 (permalink) Old 09-28-2011, 08:43 PM
Vuashke's Avatar
Rep: 59 (Unique: 30)
Vuashke is offline
post #25 of 210 (permalink) Old 09-28-2011, 09:58 PM
MMJA's Avatar
No worries, browsing through the unanswered threads I always see multiple thread pop up about PSU recommendations. Hopefully this thread will be somewhere I can send all those people and they can get their information from real world scenarios rather than the 'recommendations' on the box.
MMJA is offline
post #26 of 210 (permalink) Old 09-28-2011, 11:18 PM - Thread Starter
AMC
AMC's Avatar
Originally Posted by MMJA;15108644
No worries, browsing through the unanswered threads I always see multiple thread pop up about PSU recommendations. Hopefully this thread will be there will be somewhere I can send all those people and they can get their information from real world scenarios rather than the 'recommendations' on the box.
That's the plan. There are so many different parts you could use that it's hard to make an easy recommendation. Values are easier to work with. thumb.gif
AMC is offline
post #27 of 210 (permalink) Old 09-30-2011, 09:51 AM
Hambone07si's Avatar
Rep: 265 (Unique: 168)
Here's a shot I have of my UPS from when I had my old system running.
980x @ 4.65ghz 1.525v,Rampage 3 Extreme, 12gigs Dominator GT @ 1600mhz 7-7-7-20-1t, 256gig Crucial C300, 3 x Gtx 480's flashed bios @ 875/2000 1.175v, Corsair AX-1200, 1 pump, 2 140mm fans, 4 120mm fans, 4 black lights.
This was Furmark running
Hambone07si is offline
post #28 of 210 (permalink) Old 09-30-2011, 10:05 AM - Thread Starter
AMC
AMC's Avatar
Thanks!
AMC is offline
post #30 of 210 (permalink) Old 10-02-2011, 09:46 PM - Thread Starter
AMC
AMC's Avatar
Originally Posted by munaim1;15154148
Thanks. Cmon people, testing takes a few minutes if you have the unit. thumb.gif
AMC is offline
