4-pin power supply on 8-pin motherboard? - Overclock.net - An Overclocking Community
post #1 of 13 (permalink) Old 11-02-2011, 07:21 AM - Thread Starter
eltocliousus's Avatar
Rep: 3 (Unique: 2)
I'm recently upgrading my computer with new motherboard/cpu/ram but unfortunately I can not afford to upgrade my three year old eXtreme coolermaster 650w.
It doesn't seem to be losing it's touch though, does everything just fine and I'm only using a single 6870 so power shouldn't be much of an issue, my main problem is the power supply has only a 4-pin CPU connector and with all the motherboards I'm looking to get, they all need a 6-pin.
I can't afford a new power supply and it would be a shame to lower all my other components just to fit a cheap one in so I was hoping I could use some kind of 4-pin to 8-pin adapter, or a molex to 4-pin and use that in junction with my current 4-pin or other alternatives without spending more money.
Although I'm unsure if this will work properly or not.
All replies are appreciated, I could really use some help on this one, thankyou.
Headphone aficionado
eltocliousus is offline
post #2 of 13 (permalink) Old 11-02-2011, 07:26 AM
Rep: 12 (Unique: 12)
Knika is offline
post #3 of 13 (permalink) Old 11-02-2011, 07:28 AM
DSP1's Avatar
Rep: 90 (Unique: 88)
It would work properly the reason they do that is because the national electrical Association (i think that's what it is called) specifies that you need a particular gauge of wire to carry a given current and since they can't put really big gauge wires they instead use multiple wires. even though one of those wires could realistically carry the necessary current.
DSP1 is offline
post #4 of 13 (permalink) Old 11-02-2011, 07:29 AM - Thread Starter
Rep: 3 (Unique: 2)
Would this work just fine in conjunction with my current 4-pin CPU? As in, if I plugged my 4-pin into half the 8-pin then this into the other half, would they fit correctly?
Please excuse the dumb questions, and thankyou!
post #5 of 13 (permalink) Old 11-02-2011, 07:30 AM
Vagrant Storm's Avatar
Rep: 415 (Unique: 371)
Yep, just plug in the pins you can...done it on countless mother boards without a problem
MINNESOTA OVERCLOCKERS | The Climate Phenomenon
Vagrant Storm is offline
post #6 of 13 (permalink) Old 11-02-2011, 07:30 AM
blackbalt89's Avatar
Rep: 296 (Unique: 243)
You don't NEED to use all 8 pins for the EPS-12v. That's just in case you wan't to feed the CPU more power if it needs it.
If it has a 8-pin you can connect the 4 pins to one side of the connector, depending on where your motherboard manual says to.
blackbalt89 is offline
post #7 of 13 (permalink) Old 11-02-2011, 07:32 AM - Thread Starter
Rep: 3 (Unique: 2)
I'm going to be overclocking quite heavily (well, as heavy as I can on closed water cooling) so the 8-pin would give me piece of mind, I found this here, just wanted to confirm this particular cable would work, would it?
Thanks again, you guys give great peace of mind.
post #8 of 13 (permalink) Old 11-02-2011, 07:37 AM
trueg50's Avatar
Rep: 676 (Unique: 522)
Yes if heavy overclocking then you might want to consider the 8 pin cable. Your E8200 won't be pushing super high powerdraw the way an I7 Nehalem would, but it still will be drawing a bit, and supplying it with good power is always nice.
Also, none of the posted cables are 8 pin, they are only 4 pin and you might run into compatibility and power draw issues. For a proper 8 pin you must use a 4 pin CPU power cable, plus 2x 4 pin molex cables.
trueg50 is offline
post #9 of 13 (permalink) Old 11-02-2011, 07:41 AM - Thread Starter
Rep: 3 (Unique: 2)
I may be asking a little much, but can you find me a 4-pin CPU to molex which will definitely work with my current 4-pin? On ebay.co.uk if possible (based in the UK) and obviously the cheaper the better, thanks again.
And I won't be using this with the E8200, ordered a high end AM3+ board and hopefully an 1100T if I can get one second hand for $160 which I think I can just about do.
post #10 of 13 (permalink) Old 11-02-2011, 07:48 AM
If you want a cable...you will need one like this I don't think that one you linked will plug in next to your existing 4pin, but is made to replace it or give a really old PSU a 4 pin that didn't have one.
Though it will be fine with out. I am running a Q6600 with a mild oc on a old 500w power supply and I only have the 4 pin going. Though I typically don't recomend skimping on the power supply...but it is running on a $30 motherboard in a system that I am not too concerned about. If it was my main rig I would probably want the adapter too.
