(SOLVED) Computer shuts down randomly...bad psu?...yes it was - Overclock.net - An Overclocking Community
post #1 of 18 (permalink) Old 04-07-2012, 06:12 AM - Thread Starter
Paranoia's Avatar
Rep: 3 (Unique: 3)
Ive built my computer about 4 years ago it has been running great until yesterday it just started randomly shutting down first after 10-15 mins now only after a couple of minutes. The temps are normal or a little warm at 40°c but nothing seems to be overheating. So I was wondering if it's a power supply problem it too is about four years old as well.
System specs below
(running xp pro service pack 3)
Paranoia is offline
post #2 of 18 (permalink) Old 04-07-2012, 06:19 AM
Rep: 19 (Unique: 19)
Just turning off with no errors or BSOD kind of sounds like a PSU issue. Take your computer to the Microcenter in Twin Cities/St. Louis Park (assuming that is close to where you live, from your location in your profile)...they can check to see if your PSU is good or not with a tool they have, and sometimes they won't even charge you for it.
retrogreq is offline
post #3 of 18 (permalink) Old 04-07-2012, 05:51 PM
sai dee's Avatar
Rep: 5 (Unique: 5)
Symptoms point to PSU. Does loading the system cause it to shut down faster? Like gaming?
sai dee is offline
post #4 of 18 (permalink) Old 04-07-2012, 07:13 PM
XPC
XPC's Avatar
Rep: 12 (Unique: 10)
Sounds like a dying PSU to me.
Try this:
  1. Unplug your computer from the wall
  2. Unplug your PSU from your motherboard and gpu
  3. Look at the 24pin connector, there is a green wire surrounded by black ground wires on both sides. Bridge the green pin with any one of the black pins using a paper clip.
  4. Plug the computer back in.
The power supply should fire up and your hard drives and optical drives should power up too. Let it run like that for a while, if it shuts off again then it's a dead PSU, if it does not then it could be a mother board issue, or it could be that the PSU isn't being stressed enough to duplicate the symptoms.
My money is on the PSU. But you should exhaust all diagnostic options before you buy a PSU that you may not need.
Good Luck!
XPC is offline
post #5 of 18 (permalink) Old 04-08-2012, 07:57 AM - Thread Starter
Paranoia's Avatar
Rep: 3 (Unique: 3)
It doesn't stay on long enough to do anything...when it first started happening it didn't do it for 5-10 minutes now it only lasts a couple of minutes and sometimes a few secs
I did recently move my computer into a new case...could their be something wrong with the power connection on my case?
@XPC Thanks ill give that a try when i get home later tonight if not ill run to Micro Center tomorrow and pick up a new psu....ill keep u guys updated thanks =D
Paranoia is offline
post #6 of 18 (permalink) Old 04-09-2012, 01:50 PM - Thread Starter
Paranoia's Avatar
Rep: 3 (Unique: 3)
I hotwired the psu with the paper clip got some fans running and the psu light is on but it's been running for awhile now. So it's the motherboard now? Or could it still be a psu problem. If not that doesn't leave me much options with 775=(
Paranoia is offline
post #7 of 18 (permalink) Old 04-09-2012, 01:54 PM
It's a me
Jayjr1105's Avatar
Rep: 134 (Unique: 111)
Hotwiring the PSU doesn't put a load on it, just like power supply testers will say bad power supply's are good sometimes. Several times a month our shop power supply tester will say a unit is good when it is in fact bad. The real test is to try a known good power supply.
Official Delidded Crewman
The Ivy STABLE Club
Nvida GTX960 Owners Club
Raspberry Pi Owners Club
I <3 Mechanical KeyboardCPU Journey (Click to show)
Celeron 333MHz > Pentium 4 2.4GHz > Athlon XP 2800+ > Athlon 64 3400+ > Athlon II X2 250 > Athlon II X4 640 > Phenom II X4 840 > i5 2500K > i7 3770K
Jayjr1105 is offline
post #8 of 18 (permalink) Old 04-09-2012, 01:56 PM
OG AMD
Redwoodz's Avatar
Rep: 574 (Unique: 454)
Is the comp starting or no? Double check your cases front panel wires,and power switches. Sounds like a short to me,if it started after the new case.If it's not starting then you need a known good psu,or a multimeter or power supply tester.
https://valid.x86.fr/cache/banner/4d8m5e-6.png
AMD Athlon II 450 @4.74GHz http://valid.canardpc.com/show_oc.php?id=2204588
AMD MaxxMemm Rankings
960T @ 4.6GHz http://valid.canardpc.com/show_oc.php?id=2171450
RedwoodCustomPC
AM4
(4 items)
RCPC#1
(17 items)
Professional
Ryzen 2200G
ASRock X470 Taichi
MSI RX570 Armor MKII 8GB
GSKill Ripjaws PS850G
AMD Phenom II X6 960T
Asus M4A88T-VEVO
Asus Strix R7 370
SuperTalent Perfomance
GSkill Snipers
Monster Daytona
Seagate Barracuda 500GB 7,200 RPM 16Mb cache
Optical Drive
Memorex DVD/RW
Corsair GS500
Corsair H60
In Win H-Frame
Operating System
Windows 8N
IBM 9494 19" LCD
Keyboard
IBM
Mouse
OCZ Behemoth
Mouse
Wolfking
Audio
JBL Creature
Phenom II X6 1100t
MSI 890FX GD65
MSI Radeon HD5670
GSkill RipjawsX DDR3 PC3 12800 2x4GB CL8
WD Black 1TB SATA III
Optical Drive
Samsung BD
Kingwin Lazer Platinum 500w
Zalman 9900MAX
Fractal Design R3
Operating System
Windows 7 64 Professional
AOC 22" LED
Keyboard
Logitech
Other
Samsung 470 SSD 128GB
Redwoodz is offline
post #9 of 18 (permalink) Old 04-09-2012, 01:59 PM
SpaceStationGaming
dmasteR's Avatar
Rep: 459 (Unique: 350)
Is it this PSU?
http://www.newegg.com/Product/Product.aspx?Item=N82E16817341002
If so it's dead. I just had mine die on my recently, exact same symptoms. These are all dying in fact (look at the newegg reviews), great power supply at the time and it lasted for a long time!
dmasteR is offline
post #10 of 18 (permalink) Old 04-09-2012, 02:52 PM - Thread Starter
Paranoia's Avatar
Rep: 3 (Unique: 3)
I unplugged all front panel connections and used the 680i power button, still turns off so next option is the psu. I'll head to micro center tomorrow and pick up a new psu I can always return it if that doesn't work
Thanks to everyone for your help, I'll keep you guys posted
Paranoia is offline
