The "Uninterrupting" Uninterruptible Power Supply (UPS) Guide - Page 20 - Overclock.net - An Overclocking Community
post #191 of 212 (permalink) Old 01-13-2017, 12:30 PM
Panzerjäger Tiger Ausf. B
jagdtigger's Avatar
Rep: 47 (Unique: 29)
Originally Posted by Lady Fitzgerald View Post
headscratch.gif Could you rephrase that in English?
I think he is trying to say that ipure64 worries too much biggrin.gif . He has a double conversion UPS but he still uses "protected" outlets which is totally unnecessary because the stuff he connected to the UPS isn't mains earth reference.
Dark Repulser
(21 items)
Intel I5 4670K
MSI Z87-G55 (MS-7821)
Sapphire R9 290X
2xCORSAIR 8GB Vengeance DDR3 1600MHz CL9 CML8GX3M1A1600C9
Samsung SSD 850 Pro
XFX Pro 650W Modular Edition
2x Laing DDC-Pumpe 12V DDC-1Plus with aquacover dual ddc top
Aquacomputer aquaero 6 XT
2x alphacool nexxxos xt45 360
Koolance VID-AR290X Water Block
Aquacomputer cuplex kryos PRO
Phobya reservoir
Fractal Design Define S
Operating System
Windows 7 HP
Operating System
Kubuntu
LG IPS277L
LG W2486L
LG 27MU67-B
Keyboard
SpeedLink DarkSky black
Mouse
Logitech M705
Audio
Integrated devices
jagdtigger is offline
post #192 of 212 (permalink) Old 01-13-2017, 12:44 PM
Senioritis Member
Lady Fitzgerald's Avatar
Rep: 521 (Unique: 328)
I kinda sorta got that. My response was a politer version of what I was actually thinking of his response. His response came across as unnecessarily sarcastic but I couldn't be sure if the obscure way he wrote it was due to not being a native English speaker, being half asleep, being drunk or stoned, or something else?
Jeannie
i7-3930k
ASUS P9X79 WS
MSI R7850 Twin Frozr 2GD5/OC Radeon HD 7850 2GB 256-bit GDDR5 PCI Express 3.0 x16 HDCP Ready CrossFireX Support Video Card
Monoprice 1x2 powered HDMI Splitter
Kingston HyperX 32GB (8 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model KHX1600C9D3K8/32GX
128GB Samsung 840 Pro SSD
4TB Samsung 850 EVO SSD
Optical Drive
LG 12X BD-ROM 16X DVD-ROM 48X CD-ROM SATA Internal Blu-ray Drive CH12LS28
Corsair HX750W
COOLER MASTER GeminII S524 120mm Long Life Sleeve CPU Cooler
Antec Two Hundred v2
Operating System
Windows 7 Ultimate
3 x Asus VG248QE
Vizio VO320E 32" TV
Keyboard
Logitech G510s
Mouse
Logitech M525 with Unifying Receiving
Audio
Corsair SP2500 2.1 Speakers
Audio
ASUS Xonar Essence STX Virtual 7.1 Channels 24-bit 192KHz PCI Express x1 Interface 124 dB SNR / Headphone AMP Card
Other
LSI 9211-8i HBA card
Other
HooToo® HT-CR001 3.5" PCI-E to USB 3.0 Multi-in-One Front Panel Internal Card Reader (6 Memory Slots, Genesys GL3220 Chipset) & SuperSpeed USB 3.0 3-Port Hub (VIA VL800 Chipset), can read & write: M2/MS Micro, High-Speed CF(UDMA), UHS-I, SD, SDHC,...
Other
StarTech HSB220SAT25B 2 Drive 2.5in Trayless Hot Swap SATA Mobile Rack Backplane
i7-5930K Haswell-e
Asus X99-E WS/USB 3.1
Visiontek Radeon 7870 2GB with 6 miniDisplayports
G-Skill Ripjaws 64GB (8x8GB) DDR4 2133
Samsung 850 EVO 4TB SSDs
Samsung 950 Pro 512GB m.2 SSD boot drive
Corsair AX760
Noctua NH-D15S Cpu cooler
Scratch built. Currently under construction at https://www.overclock.net/t/1602023/preparing-for-a-scratch-built-case
Operating System
Win 7 Ultimate
Mouse
Logitech M525
Mouse
El Cheapo Allsop hard plastic
Lady Fitzgerald is offline
post #193 of 212 (permalink) Old 01-13-2017, 02:02 PM
ACleverName's Avatar
Rep: 13 (Unique: 11)
The CP1500PFCLCD is a excellent Unit. I run 3 machines one my main rig, 5820k OC'ed to 4.5 with a 1080 Hybrid. It has 2 SSD's and 3 x spinner disks. My 1st main server is a 2500k sandy bridge OC'ed to 4.5 with a lil 750 TI with 1 ssd and 6 x spinner disks, the 3rd is a old 1055 T with one drive running a ton of rust servers. The most see for the watts being Pulled is 810 Watts if anyone is wondering how much it takes to get up near this limit. Video cards will really want to suck down power like a margarita.
the only thing i wish was extra on this unit was native plugin for a extra battery supply like the one APC unit, but i wont give up pure sine wave for that, i'll rig up a large sealed deep cycle before that.
Just Roll With It
ACleverName is offline
post #194 of 212 (permalink) Old 01-14-2017, 12:00 AM
Linux Lobbyist
iepure64's Avatar
Rep: 0
Hi ! I guess i like the idea "protection over protection" the 1x6 socket type that i mentioned, works only if the socket is polarised or how to say in phase with the circuit, has a ground fault indicator led that checks ground orientation in respect to Neutral wiring.Because of that in my country schuko outlets don't get phase polarisation like those in America.I had to check and oriented the plug with a Voltage screwdriver.To not let the Live inductance escape trough the wrong way in asymetrical wiring.I do understand the "nothingless" in using those outlets along with the UPS. I had to do it that way. Reassuring and assuring protection.thumb.gif
ONLiNE UPS 2KVA currently running @ 230Vac 50.0Hz Double Protected in series EMI\RFI outlets; phase oriented service PSU SPiRE Jewel Black 550watt Motherboard ASRock P5B-DE CPU Intel e6800 @ 3.33GHz RAM A-DATA Vitesta Extreme 800+ x4-2GB non-ECC 4-4-4-12-2T 1.9v-2.1v VGA ATi Radeon Sapphire Vapor-X HD5770 1024MB GDDR5 128-bit PciExpress 3.0 x16 Display BENQ G950A 1366x768 native resolution HDD Toshiba 2TB Capacity; S-ATA II 64MB cache 1xPCI WiFi 2.4GHz TP-LINK Adapter b.g.n network 1xDVD-RW unit LG 1xExternal USB HDD rack; Seagate Barracuda 250GB standard PS\2 keyboard & optical mouse 1xGenius joystick 1xMicrosoft HD LifeCAM 1xGenius Headset Vibration Feature Operating System Windows Vista ULTIMATE SP2.0 64-bit; directX11 updated Home audio:Stereo Amplifier NAD 316bee; high quality stereo 24K gold plated audio jack\RCA cable 2xHeco Victa Prime 502 floor loudspeakers Bi-AMP; remote...
iepure64 is offline
post #195 of 212 (permalink) Old 01-14-2017, 01:35 PM
Linux Lobbyist
iepure64's Avatar
Rep: 0
UPS close look: https://www.youtube.com/watch?v=aXNxQnF602g smile.gif
EMI\RFI phase oriented outlet DSCI8561.JPG 6086k .JPG file
iepure64 is offline
post #196 of 212 (permalink) Old 01-15-2017, 06:14 AM
JRS017's Avatar
What you guys are still thinking isn't enough...ESR is still too high...I promise you...You really want to make regulator wattatron from hell and all that etc.
JRS017 is offline
post #197 of 212 (permalink) Old 02-10-2017, 02:23 PM
NitrousX1's Avatar
Rep: 0
Thank you for the thread I'm in the process of building a new Rig on the X99 build i used power calculator and with a overclock of 4.5Ghz around 1.4v on the core voltage my rig would consume around 658W. I will be equipping it with a HX1050 PSU. I'm thinking of purchasing the CP1500PFCLCD would this be enough to power my whole rig or is my PSU wattage too big or would the UPS only take into account the actual load that's being used at the time. Hope you can help thanks
NitrousX1 is offline
post #198 of 212 (permalink) Old 02-10-2017, 07:49 PM
EhmayWuntee
mrtbahgs's Avatar
Rep: 54 (Unique: 44)
I'm no expert on PSU sizing, but I think you are going a bit big if you don't plan to add in anything later on and I also have seen it mentioned a few times that those calculators are usually pretty wrong and I believe overshoot the requirements.
If you dont get much of a response here you may want to do a separate thread to look over your build plans and likely someone with PSU experience will give good suggestions.
In regards to the UPS, it will only use the actual load that the PC is consuming plus anything else plugged into the surge side so maybe a monitor and modem which isn't much extra.
In the event of a power outage, as long as the true used power is under the rated wattage of the UPS, then you will be good to go.
Run times will vary depending on power used, but the 1500 should give you a good chunk of time while under load to close out and save anything.
On idle it will likely be good for 20 minutes or so.
I like the CP units and think you have a good one chosen, but yes I would get feedback and reconsider the PSU size.
mrtbahgs is offline
post #199 of 212 (permalink) Old 02-10-2017, 08:32 PM
Getting used to 'new'
AcEsSalvation's Avatar
Rep: 220 (Unique: 163)
Absolutely this. If only one GPU is going in that system and you aren't using BIOS mods or specialized cooling, save the trouble and money and get a quality 550W PSU. As for the PFC1500LED, I have that exact model. My rig can get about 4 minutes at full load (maybe less since different GPU now), but that is plenty of time to save your game, close it down, and extend the battery to 45+ minutes.
Sig's kind of broke a little. It's okay, I needed to update it anyway XD
AcEsSalvation is offline
post #200 of 212 (permalink) Old 02-11-2017, 08:03 AM
NitrousX1's Avatar
Rep: 0
Thanks for the reply, I have posted my build on PSU thread. I think I may consider downsizing seeing now that most components are becoming more power efficient
