What do YOU want to see in a power supply? - Page 21 - Overclock.net - An Overclocking Community
post #201 of 228 (permalink) Old 07-24-2013, 06:02 AM
Carniflex's Avatar
Rep: 237 (Unique: 187)
Hmmm ... there is some things I would like to see, however, I suspect these would be somewhat niche and / or make it too expensive so I could not afford one with these properties wink.gif
(1) Software readable sensors, including to obvious things like temperature, fan speed and voltage also more obscure things like ripple amounts, component degrading amounts and general PSU heath assessment in the sensor software. What I would also quite like sensors wise is ability to log the quality of the incoming power quality from the wall (spikes, brownouts, etc)
(2) Optional water cooling (Hybrid cooling?) - I mean stuff like having the conventional fan in the PSU and Heatsink(s) - just that the heatsinks are hollow and there is G1/4 threads on the PSU so you can just put it under water and make it run cooler/more quiet.
(3) Obviously fully modular and ideally with good mix of wiring which is more than the minimal needed for the PSU. I mean stuff like, for example, having two different length 24 pin cables in the box so that you can pick the more fitting (with top mounted PSU you usually end up with excess ~20 ..30 cm of 24 pin cabling which is usually pretty stiff), different length SATA cabling, preferably two versions with one having the usual 15 cm between connectors and another with the shorter 10 cm between connectors. Good number of PCI-e connectors even on PSU's under 1+ kW (many mid range cards don't use 8 pin so it should be an option to get 2x 6 pin instead of single 8 pin)
Carniflex is offline
post #202 of 228 (permalink) Old 07-24-2013, 06:15 AM
MrDucktape's Avatar
Rep: 10 (Unique: 9)
Nice desing, cool colours that go well with new motherboards, modularity, good sleeving and inteligent modular cables, like 3 sata, not 5 sata, 2 molex and a 6pin altogether.
MrDucktape is offline
post #203 of 228 (permalink) Old 07-24-2013, 06:28 AM
edalbkrad's Avatar
Rep: 220 (Unique: 198)
1. Add a couple more inches to the length of your 24pin and 4+4pin motherboard cables.
My nephew has this psu:
http://www.coolermaster.com/product/Detail/powersupply/office-home-extreme/extreme-power-plus-500w.html
Its pretty good for its low price, the only thing I didnt like is the short 24pin cable.
He has the same Elite 430 case like mine and the 24pin cable was too short to reach the motherboard
so I had to lay it on top of his HD6770 instead of having it go around the side.
Rabasu i7-3770K
Rabasu FX6100
i7 3770K
ECS H77H2-M3
MSI RX 580 Armor 8GB OC
2x8GB Kingston HyperX Blu
Seagate 1TB
Seagate 1TB
Optical Drive
Sony DVDRW
Seasonic M12II Evo 620W
stock
Coolermaster Elite 430
Operating System
Windows 7 x64
BenQ E2220 1080p
Mouse
A4tech X7 710BH
A8 7410 2.5Ghz
Radeon R5 M335 2GB
4GB DDR3L
1 TB HDD
Dell Inspiron 5455
Operating System
Windows 8.1
AMD FX 6100 4.0 Ghz 6-core
Asus M5A78L-MLX3 AM3+
Powercolor HD7730 1GB DDR5
16GB (2x8GB) Corsair Vengeance LP 1600
Seagate 1TB
Seagate 1TB
Optical Drive
Sony DVDRW
Aerocool Strike-X 500watts
CoolerMaster Hyper212+ with 2x140mm Deepcool UF140
CoolerMaster Elite 430
Operating System
Windows 7 x64 / Mint x64
BenQ E2220 1080p
Mouse
A4tech X7 710BH
edalbkrad is offline
post #204 of 228 (permalink) Old 07-24-2013, 07:31 AM
adridu59's Avatar
Rep: 313 (Unique: 230)
Originally Posted by $ilent View Post
Performance when pushed to its output limit (i.e capable of delivering more watts if needed)
It's already the case with most quality PSUs (Peak output current) yet everyone keeps buying oversized PSUs lol.
OCN's Recommended: Power SuppliesAudio Products
~ Sig now ToS compliant
adridu59 is offline
post #205 of 228 (permalink) Old 07-24-2013, 08:05 AM
JambonJovi's Avatar
Rep: 71 (Unique: 60)
Most things have been said already, but anyway:
Fully modular design (500W and up)
Sleeved Cables (Different Colors)
SFF friendly
LED Fan
What I would REALLY like to see on all PSU's (not just CM) is an L shaped 24-pin connector. thumb.gif
Possibly a few USB ports. I'm sure they would come in handy in some way.
Jambons for everyone!
Intel Pentium G3258 Owners Thread
NVIDIA GTX 750Ti Owner's club
Raspberry Pi Owner's Club
The Windows 10 Club
+1GHz Overclock Club
QX6700 @ 3.7GHz Validation
G3258 @ 4.6GHz Validation
LOL-worthy Quotes! (Click to show)
"Getting a 4670 non k is like getting half of a pizza." -PontiacGTX
"Ribbed, for your airflow." - Polska
"Cool. A Noctua NH-D14-esk cooler that doesn't look like it is made of questionable bodily fluids." -sciencegey
"I dont know what a 'Gank' is, but replace the 'G' with a 'W' and you've got yourself a winner." -singh_shady
"Let's sacrifice a goat!!!" -Cyclops
"All this talk of butts makes me think of a PC case in the shape of
an arse with I/O ports where the sun don't shine. Now I want one." -Werne
"If i put my gpu in microwave that will fix my gpu bruhs?" -nikos97
"Either you die a noob, or you live long enough to be called a cheater." -blaze2210
JambonJovi is offline
post #206 of 228 (permalink) Old 07-24-2013, 08:08 AM
Syan48306's Avatar
Rep: 149 (Unique: 115)
Power supplies get way too loud at when you draw power close their rated max. The PSU fan is the loudest thing in my computer when its under load. redface.gif
Syan48306 is offline
post #207 of 228 (permalink) Old 07-24-2013, 08:11 AM
Senior OCN Member
shilka's Avatar
Rep: 2748 (Unique: 1629)
What a silly idea most high end units are so efficient they make next to no heat
You can even buy fanless 450-650 watts units
Or buy a bigger PSU so you have more headroom which puts less load on the unit which makes less heat which makes less noise
Seravee
(30 items)
Intel Core I7 6850K
Gigabyte X99 Ultra Gaming
MSI RTX 2070 Super Gaming X Trio
Kingston HyperX DDR4 Savage 3000 MHz
Samsung 840 Evo 500 GB
Corsair Force MP510 1,92 TB
Seagate Ironwolf Pro 14 TB
Seagate Ironwolf 12 TB
WD Ultrastar DC HC530 14 TB
Seagate Ironwolf Pro 12 TB
Seagate Ironwolf Pro 16 TB
Optical Drive
LG CH12NS30
Seasonic Prime Ultra Titanium 750 watt
Noctua NH-D15S
Phanteks Enthoo Luxe Tempered Glass
Operating System
Windows 7 Ultimate 64 bit
Operating System
Windows 10 Home 64 bit
Asus PG279Q
LG 55C8 OLED TV
Keyboard
Corsair Strafe RGB MK.2 with Cherry MX Silent
Mouse
Roccat Kone EMP
Mouse
HyperX Fury S XL
Audio
Sennheiser HD 598
Audio
Onkyo TX NR646
Audio
Dali Opticon Vokal
Audio
x2 Dali Opticon 2
Audio
x2 Dali Opticon 1
Audio
Dali E12 F Subwoofer
Audio
Sennheiser HD-599
Other
CableMod 30 CM Magnetic Red LED strip
shilka is offline
post #208 of 228 (permalink) Old 07-24-2013, 09:38 AM
That isn't much of an option for people running 3-4 heavily overclocked GPUs.
Liquid cooling would be more for reduced size than anything else however.
Masta Squidge is offline
post #209 of 228 (permalink) Old 07-24-2013, 10:57 AM
Not new to Overclock.net
TwoCables's Avatar
Rep: 6214 (Unique: 3521)
Originally Posted by ladcrooks View Post
Phaedrus explained to me that the metal case acts as a Faraday cage to keep its switching noise from leaking to other devices and outside noise from affecting the PSU.
Loneliness is a good thing to share with someone.
The virtuous spirit has no need for thankful approval, owning a certain conviction that what has been done is right.
i5-2500K @ 4.5GHz (1.368-1.384V fixed voltage)
ASUS P8P67 EVO B3 (UEFI ver. 1850)
MSI GTX 1070 Ti Gaming Titanium 8G
G.SKILL Ripjaws X 8GB (2 x 4GB) 1866MHz, CL9
250 GB Samsung 840 EVO (OS)
3 TB Toshiba P300 (D: drive)
Optical Drive
Samsung SH-S243N 24x DVD Burner
Optical Drive
Samsung SH-S203N 20X DVD Burner
Corsair RM550x
Thermaltake Frio
CM 690
Operating System
Windows 10 Home
AOC G2460PG (24" 1920 x 1080 144Hz G-SYNC)
Keyboard
Filco Majestouch 104-key Cherry MX Blues w/NKRO
Mouse
Intellimouse Optical (1.1A) 1000Hz polling rate
Mousepad
It's just a mousepad
Audio
X-Fi Titanium HD
Audio
Klipsch ProMedia 2.1 (with 16 AWG Monster Cable speaker wires)
TwoCables is offline
post #210 of 228 (permalink) Old 07-24-2013, 10:59 AM - Thread Starter
Rep: 31 (Unique: 23)
Mhm. It's hard enough meeting FCC limits on radiative EMI *with* a metal case. Most acrylic case PSUs either have no FCC certification, or a fake one. And are thus actually illegal to sell (if anyone cares).
"More quotes have been misattributed to Albert Einstein than to any other famous person."
- Albert Einstein
CM Phaedrus is offline
