What do YOU want to see in a power supply? - Page 23 - Overclock.net - An Overclocking Community
post #221 of 228 (permalink) Old 07-24-2013, 10:58 PM
larymoencurly's Avatar
Rep: 102 (Unique: 84)
Originally Posted by Masta Squidge View Post
Define slow, the afternoon would be the 3-4 hours I have between getting home from work and going to bed. Which are usually occupied with more important things.
Some people work 50-60 hours a week.
And it is no more dangerous than any other watercooling setup, if the fittings are, again, outside of the PSU case.
Back when most TV repairs were done by American techs, shops generally had a 2 hour limit on labor, and that was for both diagnosis and board level part replacement, not something as simple as a capacitor swap.
Unfortunately the There I Fixed It.com style fixes aren't too far removed from some DIY work I've seen, including where zip cord was run inside walls and fastened with regular staples laid down really firmly against the insulation. People like that can't be trusted around water and high voltage. Show me how a retail water cooled PSU can pass UL or CSA testing.
larymoencurly is offline
post #222 of 228 (permalink) Old 07-25-2013, 04:23 AM
JambonJovi's Avatar
Rep: 71 (Unique: 60)
Originally Posted by Bit_reaper View Post
It might also sound weird but I think there would be a market for optional un-traditional cables. Like cables that are single strand instead of multi-strand so you would do 90° bends and have the cables actually hold the form or cables where the insulator is clear showing off the copper wire inside. That would be pretty cool.
Oh and someone should make different angled PCI-E adapters so it would be easier to route the cables.
Something in the style of this-->
That idea would look good with a single (possibly 2 card) setup, but what would you do in a case of a triple or quad sli ? Wouldn't work. You're limited by the space between individual cards,
which in a lot of cases is only a couple mm.. Im all in favour of 90° connectors tho thumb.gif
Jambons for everyone!
Intel Pentium G3258 Owners Thread
NVIDIA GTX 750Ti Owner's club
Raspberry Pi Owner's Club
The Windows 10 Club
+1GHz Overclock Club
QX6700 @ 3.7GHz Validation
G3258 @ 4.6GHz Validation
LOL-worthy Quotes! (Click to show)
"Getting a 4670 non k is like getting half of a pizza." -PontiacGTX
"Ribbed, for your airflow." - Polska
"Cool. A Noctua NH-D14-esk cooler that doesn't look like it is made of questionable bodily fluids." -sciencegey
"I dont know what a 'Gank' is, but replace the 'G' with a 'W' and you've got yourself a winner." -singh_shady
"Let's sacrifice a goat!!!" -Cyclops
"All this talk of butts makes me think of a PC case in the shape of
an arse with I/O ports where the sun don't shine. Now I want one." -Werne
"If i put my gpu in microwave that will fix my gpu bruhs?" -nikos97
"Either you die a noob, or you live long enough to be called a cheater." -blaze2210
JambonJovi is offline
post #223 of 228 (permalink) Old 07-25-2013, 05:03 AM
Bit_reaper's Avatar
Rep: 439 (Unique: 336)
I was mostly thinking they would be adapters. Something you could choice to use or not. Perhaps even have some with different angles
The XFX 4890 post 2 year reference cooler fan bearing service
NZXT Tempest Community
[Worklog] NZXT Tempest eats a 360 rad (hopefully)
you under-estimate the power of e-peen, you'll whither and waiver to it's power, and finally succumb.
Bow to e-peen and buy.
Bit_reaper is offline
post #224 of 228 (permalink) Old 07-25-2013, 05:08 AM
DEW21689's Avatar
Rep: 34 (Unique: 33)
Communication between the PSU and PC would be very nice, specifically being able to see PSU temps and fan speeds, maybe some humidity sensors/alarms as well for users who live in more humid climates.
DEW21689 is offline
post #225 of 228 (permalink) Old 07-25-2013, 05:09 AM
Faithh's Avatar
Rep: 45 (Unique: 32)
0,0000 coil whine.
Faithh is offline
post #226 of 228 (permalink) Old 07-25-2013, 06:40 AM
EniGma1987's Avatar
Rep: 338 (Unique: 248)
very true. I wonder if it would still look good if there were just some extension plugs bundled with the PSU. These could be used if the person wants to change the angle of the PCI-E connectors or not used when someone is running lots of graphics cards and there is no space to do that.
EniGma1987 is offline
post #227 of 228 (permalink) Old 07-25-2013, 08:17 AM
I like it, but in my case it would only server to cover up the evga titan logo on my backplate. Boo.
I wouldn't mind one that does a 90 degree in the horizontal plane though, but it would make for an awfully tall connector and might actually look worse.
Masta Squidge is offline
post #228 of 228 (permalink) Old 07-25-2013, 09:15 AM
Drakenxile's Avatar
Rep: 28 (Unique: 23)
I like popping colors like a Bright Blue to go with my blue rig would be nice, individually sleeved cables kinda like corsair but different like mix and match colors with tones so like on a pcie 8pin 5blue 3black or white something like that. Being able to change a dead fan without voiding warranty would be nice. other then that more affordable 80+gold and that's about it
Ryzen 4.0Ghz
(17 items)
Wife's Computer
My HTPC Comp
(11 items)
Ryzen 7 1700 @4.0ghz
MSI B350 Tomahawk
MSI GTX 1080 Gaming X
Team Nighthawk 2x8gb DDR4 3200
Kingston M2sata 500gb
Corsair RM650x
Custom Liquid Loop from leftovers
Phatneks Enthoo Evolv ATX
Operating System
Windows 10 64bit
27" Crossover 2560x1440
Keyboard
BlackWidow Ultimate
Mouse
Mionix Naos QG
Mouse
Rosewill Extended Mat
Audio
Corsair SP2500
Audio
Sennheiser HD598c
Audio
Audio-Technica 2020 Micorphone
Audio
Onboard ; ;
Intel I5-4670
Gigabyte Z97-UD3H
Powercolor 7950
Patriot 1866MHZ 2x8GB
Corsair Force 3 180GB SSD
750GB Seagate
Cooler Master 450w Gold
U2-UFO Mountain Mods
Operating System
Win 8
Asus VE247h 23.6"
Keyboard
Logitech G105
Mouse
Razer Deathadder
Mouse
Razer Goliath
Intel I3 4130
MSI H97M-G43
Power Color 7950
Crucial Ballistix 2x4GB ddr3 1333mhz
Corsaird Force 3 240gb SSD
Seagate 4TB SSHD
Antec BP 550w
Freezer 7 PRO Rev. 2
BitFenix Phenom MATX
BenQ W770ST
Audio
Crative Sound Blaster Titanium
Drakenxile is offline
