1000-1050 watts comparison thread - Overclock.net - An Overclocking Community
post #1 of 90 (permalink) Old 11-01-2013, 08:15 PM - Thread Starter
Senior OCN Member
shilka's Avatar
Rep: 2707 (Unique: 1609)
Warning obvious thing (Click to show)
If your system only has one video card you're wasting money you dont need a PSU in this wattage range so dont bother to look here for that
First off before i begin no i have not reviewed any of these units nor do i claim any credit for it, Its all done by Techpowerup so all credit goes to them. Since Techpowerup does not have reviews for every single 1000 watts PSU i can only pick the ones they have reviewed which means that some models are not here and a model is not bad because its not here
Fully modular section (Click to show)
So lets be about it and start off with the Be Quiet Power Zone
Pictures of the platform (Click to show)
The fan is a 135 mm Fluid Dynamic Bearing Fan (SilentWings). The high quality cooling fan is provided by be quiet! and belongs to the SilentWings series. Its model number is BQ SIW3-13525-HHF-29 (12 V, 1 A, 2900 RPM max), and we strongly believe it to be too powerful and noisy for the needs of this PSU. The fan controller circuit fortunately restricts its maximum rotational speed to 2500 RPM, and it generally rotates the fan at low enough speeds for a quiet, not whisper quiet, operation.
Fan noise (Click to show)
Efficiency (Click to show)
Next is voltage regulation (Click to show)
12v rail
5v rail
3,3v rail
Last is ripple
Next is the Cooler Master V
The fan is a 135 mm FDB Fan (MGA13512XF-025). The fan is of high quality since it uses a Fluid Dynamic Bearing (FDB). These bearings offer a much longer lifetime even compared to ball-bearing ones and do, on top of that, produce less noise. The fan is made by Protechnic, one of the best fan manufacturers, and its model number is MGA13512XF-025. CM made, in our humble opinion, an excellent choice with this fan, showing the competition that they don't play around with this PSU, but want to jet directly to the top of the corresponding category. It is really sad to see high-performance, ultra-expensive PSUs with, from time to time, cheap fans instead of FDB ones.
12v rail
5v rail
3,3v rail
Last is ripple
Next is the Cooler Master Silent Pro Hybrid
The fan is a 135mm (Silent Hydraulic Bearings) DFS132512H. The fan has Cooler Master's logo on it, but it's made by Young Lin Tech and its model number is DFS132512H (12V, 3W, 1700RPM, 36.28dBA, 91.16CFM). At normal RPMs it is quiet but at full speed it's noisy despite the only 36.28 dBA that its characteristics state.
12v rail
5v rail
3,3v rail
Last is ripple
Next is the EVGA SuperNova G2
The fan is a 140 mm Double Ball-Bearing Fan (HA1425M12B-Z). The cooling fan is equipped with double ball-bearings and is made by Hong Hua. Its model number is HA1425M12B-Z, and it is rated for 0.36A at 12 V. The fan can achieve 1600 RPM with the aformentioned power input, but the fan controller circuit restricts its full speed to around 1485 RPM. Only with a 110% load (1100 W) and at 46°C ambient did we manage to make it spin at 1550 RPM, which is still lower than its maximum-rated speed.
12v rail
5v rail
3,3v rail
Last is ripple
Next is the EVGA SuperNova P2
The fan is a 140 mm Double Ball-Bearing Fan (HA1425M12B-Z). The cooling fan is the same as in the G2-1000. It is equipped with double ball-bearings and is made by Hong Hua. Its model number is HA1425M12B-Z, and it is rated for 0.36A at 12 V. This fan can achieve 1600 RPM at full speed, but it will only engage once things get really hot if you pick ECO Mode (semi-passive operation). Speed is only rarely increased while the unit is operating normally, even under tough conditions.
12v rail
5v rail
3,3v rail
Last is ripple
Next is the NZXT HALE 90 V2
The fan is a 135 mm Dual Ball-Bearing Fan. The cooling fan is provided by Protechnic and its model number is MGA13512YB-025 (12V, 0.5 A, 2100 RPM, 116.81 CFM, 42.0 dBA). It is definitively not the quietest fan out there.
12v rail
5v rail
3,3v rail
Last is ripple
Next is the Seasonic X (XM2)
The fan used is a 120 mm Double Ball-Bearing Fan (9S1212H403) The cooling fan's model number is 9S1212H403, and it is by Sanyo Denki. It uses a pair of ball-bearings, which should have it last a long time (40,000 hours according to its manufacturer, at 40°C and full speed). Unfortunately, it is especially noisy at high speeds. We believe Seasonic should use a quieter FDB fan instead.
12v rail
5v rail
3,3v rail
Last is ripple
Next is the Seasonic Platinum 1000 watts (XP)
[/S
The fan is a 120 mm Double Ball-Bearing Fan with Hybrid Silent Fan Control. The cooling fan, a San Ace 120, is provided by Sanyo Denki and its model number is 9S1212F404. At full speed it's noisy but in this unit most of the times it will work at middle-low RPMs and if you choose Hybrid operation then it won't work at all at low loads. The same fan is used in all X series PSUs (except the two fanless models of course!)
12v rail
5v rail
3,3v rail
Last is ripple
Next is the Seasonic Platinum 1050 watts (XP3)
The fan is a 120 mm Double Ball-Bearing Fan (9S1212H403), The cooling fan with model number 9S1212H403 is by Sanyo Denki. We couldn't dig up any detailed information on this particular fan so we had to ask Seasonic about it and the informed us that it uses a double ball-bearings and its lifetime may look low on papers but the 40,000 hours are for 100% load at 40°C ambient or for 80% load at 50°C. Most of you and us would prefer however an FDB fan with a larger diameter instead. Seasonic will hopefully rethink their fan choice in the near future. These Sanyo Denki fans may be quality products, but they are noisy because they have to rotate at higher speeds to efficiently remove the heat. A 140 mm fan would provide just as much airflow at lower speeds, which reduce noise output significantly.
12v rail
5v rail
3,3v rail
Last is ripple
Next is the Seasonic Snow Silent
The fan is a 120 mm Fluid Dynamic Bearing Fan (HA1225H12F-Z), The second and most important difference between the Snow Silent edition and the SS-1050XP3 is the fan. While the latter uses a plain double ball-bearing fan, the Snow Silent comes equipped with a fluid dynamic bearing fan of good quality. These bearings (FDB) last much longer than other types and are able to offer a quiet operation for longer. You see, as time passes by, ball-bearings inevitably wear off, which will affect noise output significantly. Seasonic says such not to happen with fluid dynamic bearings, and we have absolutely no reason not to believe them.
12v rail
5v rail
3,3v rail
Last is ripple
Next is the Super Flower Leadex Platinum
The fan is a 140 mm Double Ball-Bearing Fan (HA1425M12B-Z). The cooling fan only carries SF's logo, but we are pretty sure that it is the same as in EVGA's unit, so its model number is HA1425M12B-Z, made by Hong Hua. It is equipped with double ball-bearings and is rated for 0.36A at 12 V. This fan can achieve 1600 RPM, but the fan-control circuit keeps it at much lower speeds most of the time. Also, it will rarely operate under normal conditions if you pick the semi-passive option.
12v rail
5v rail
3,3v rail
Last is ripple
Next is the Silverstone Strider Gold Evolution
The fan is a 139mm Air Penetrator fan with fluid dynamic bearing.The high quality cooling fan is provided by Silverstone and belongs to the Air Penetrator series. Its model number is HA1425M12F-Z (12V, 0.36A) and besides Fluid Dynamic Bearings (FDB) which promises prolonged lifespan it utilizes a unique blade and grille design which, according to Silverstone, is able to create enough pressure to push air as far as one meter away with minimal fan speed and noise.
12v rail
5v rail
3,3v rail
Last is ripple
Next is the Antec High Current Pro Platinum
The fan is 135 mm Double Ball Bearing Fan.The cooling fan is provided by Delta itself, since besides PSUs the same company has a long tradition in making fans. The model number of the fan is AFB1312M (12V, 0.38A) and it is manufactured in China. Thanks to the relaxed program of its controller it keeps a low speed at lower loads/ambient and only if you stress the PSU really hard it significantly increases its speed, however, without creating an annoyingly loud noise. Nevertheless most of the time it will work silently.
12v rail
5v rail
3,3v rail
Last is ripple
Next is the Corsair HX1000i
The fan used is a 140 mm Fluid Dynamic Bearing Fan,Corsair has been using this particular silent fan in many of their more recent products. The fan's model number is NR135L (12 V, 0.22 A) and it uses a rifle bearing, which is essentially an improved sleeve bearing.
12v rail
5v rail
3,3v rail
Last is ripple
Next is the Corsair RM
The fan used is a 135 mm Rifle-Bearing Fan (NR135L) The cooling fan is, according to Corsair, designed to operate quietly. This fan's model number is NR135L (12 V, 0.22 A), and it uses a rifle bearing, an improved sleeve bearing.
12v rail
5v rail
3,3v rail
Last is ripple
Next is the Corsair RMi
The fan is a 135 mm Fluid Dynamic Bearing Fan (NR135P),The RM1000i uses the same fan as the HX1000i. It is a very quiet fan at even higher speeds, and its model number is NR135P (12 V, 0.22 A). Under normal ambient temperatures, the fan speed won't exceed 1200 RPM even with a full load, and only a worst-case scenario (>48°C ambient and a full-load for a very long time) will have it operate at around 1550 RPM.
12v rail
5v rail
3,3v rail
Last is ripple
Next is the Corsair RMx
The fan used is a 135 mm Rifle Bearing Fan (NR135L) As has already been stated, the RM1000x uses a rifle-bearing fan with model number NR135L (12 V, 0.22 A), while the RM1000i uses an FDB fan. The fan uses a highly relaxed fan profile, and there is also a semi-passive mode that lasts fairly long under normal operating conditions. It, as such, definitely won't produce a whole lot of noise wile operating under normal conditions.
12v rail
5v rail
3,3v rail
Last is ripple
Next is the Thermaltake Toughpower DPS Gold
The fan used is a 140 mm Double Ball-Bearing Fan (HA1425L12SB-Z) The cooling fan comes with Thermaltake's logo; however, it is a Hong Hua fan. Its model number is HA1425L12SB-Z (12 V, 0.22 A, 1500 RPM), and Thermaltake says it to use ball bearings.
12v rail
5v rail
3,3v rail
Last is ripple
Next is the XFX XTS
The fan used is a 135 mm FDB Fan (HA13525H12F-Z), The cooling fan is by Hong Hua, and its model number is HA13525H12F-Z (135 mm, 12 V, 0.5 A, 2300 RPM max). It is a pretty strong fan for even a unit of this capacity. Thankfully, there is a semi-passive mode, so those who want an inaudible operation can have it; that is, at light loads and under normal operating temperatures.
12v rail
5v rail
3,3v rail
Last is ripple
Next is the Zalman ZM1000-EBT
The fan used is a 135 mm Fluid Dynamic Bearing Fan (RL4Z S1352512H) The fan is by Globe Fan and the sticker on it reads "Fluid Dynamic Bearing" in large letter. According to its model number it should be a plain sleeve-bearing fan but indeed it uses a Fluid Dynamic Bearing. Apparently Globe Fan made some changes internally and they just didn't change the model number on the sticker. From the moment the fan is a true FDB one this isn't of high importance, although it can easily bring confusion to reviewers (including us of course). This is a medium-speed fan that runs a pretty aggressive fan profile.
12v rail
5v rail
3,3v rail
Last is ripple
Non and semi modular section (Click to show)
Next is the Be Quiet Dark Power Pro 10
The fan used is a 135 mm FDB Fan (2800 RPM max) Be Quiet equipped the PSU with a high-quality fan that uses Fluid Dynamic Bearing for silent operation and extended lifespan. Its model number is BQT T13525-XF28 (12V, 0.50A, 2800RPM max, 119.08 CFM, 5.97 mmH2O). It is, at normal ambient, totally inaudible, but makes a lot of noise if you manage to push it to its limit.
12v rail
5v rail
3,3v rail
Last is ripple
Next is the Be Quiet Dark Power Pro 11
The fan is a 135 mm Fluid Dynamic Bearing Fan (SilentWings 3, SIW3-13525-HF) The cooling fan has be quiet!'s logo on it and belongs to the SilentWings 3 family. Its model number is SIW3-13525-HF (135mm, 12V, 0.56A, 84.60 CFM, 1800 RPM), and it is going to last for a very long time because it uses a fluid dynamic bearing. This is a silent fan, and it uses a very relaxed fan profile at ambient temperatures of up to 40 °C.
12v rail
5v rail
3,3v rail
Last is ripple
Next is the Fractal Design Tesla R2
The fan used is a 135 mm Double Ball-Bearing Fan (RL4Z B1352512HH) The cooling fan carries Fractal's logo and is a little stronger than the one that the Newton R3 1000 W unit uses, since the lower efficiency required a stronger fan. It is most likely made by Globe Fan and has model number RL4Z B1352512HH (12 V, 0.45 A, 129.76 CFM, 1800 RPM, 33.9 dBA).
12v rail
5v rail
3,3v rail
Last is ripple
Next is Fractal Design Newton R3
The fan used is 135 mm Double Ball-Bearing Fan.
The cooling fan carries Fractal's logo, but we are pretty sure that it is made by another company, most likely Globe Fan. We also suspect that it is the same fan that the In Win Glacier 900 W uses, so its model number is RL4Z B1352512H (12 V, 0.33 A, 106.86 CFM, 1500 RPM, 29.2 dBA). Finally, a triangular plastic baffle has been attached to the fan to direct airflow towards the front of the PSU.
12v rail
5v rail
3,3v rail
Last is ripple
Next is the Club 3D CSP-X1000CB
The cooling fan is provided by Young Lin Tech. The model number is DFB132512H and it's rated for 3W.
12v rail
5v rail
3,3v rail
Last is ripple
Next is the Corsair HX1050 V1
The fan used is a 140 mm Fan (Yate Loon D14BH-12) The cooling fan is provided by Yate Loon Electronics and its model number is D14BH-12 (12V, 0.7A, 2800RPM, 140CFM, 48.5dBA).
12v rail
5v rail
3,3v rail
Last is ripple
Next is the OCZ OCZ FATAL1TY
The fan used is a140 mm Double-Ball Bearing Fan
The cooling fan is provided by HONG HUA, a company we never heard before. Its model number is HA1425H12B-Z (12V, 0.5A) and it uses double ball bearings. It is quite powerful and easily handles the heat load of this unit but at full speed is quite noisy. Finally it is equipped with red LED lighting for which unfortunately there is no turn off option.
12v rail
5v rail
3,3v rail
Last is ripple
Next is the Cooler Master Silent Pro M2
The fan used is a 135 mm Hysint Bearing Fan (DFS132512M )
The cooling fan has Cooler Master's logo on it and its model number is DFS132512M (12V, 0.2A, 2.4W, 1500RPM, 34.44dBA, 78.13CFM). On the bottom side of the center badge we find its real manufacturer which of course is Young Lin Tech.
According to a spec sheet we found on Young Lin Tech's official site this fan is equipped with a plain sleeve bearing and not with a Hydro Dynamic one. On the contrary CM states that HDB is used, so we had to clear this up by cracking open the fan. In the end we discovered that the fan uses neither sleeve bearing nor HDB. The kind of bearing it uses is called Hysint bearing and is something in between. It provides longer lifespan and lower noise than sleeve bearing but it can't be compared with HDB/FDB. In the photos above notice the vertical V-shaped cutouts on the shaft of the fan. These curves pump the oil up and down on the bearing while the fan spins reducing friction. We contacted CM of course about this issue and they informed us that due to a patent on HDB/FDB each vendor has similar solutions with custom names, however there are also some differences in the design too.
12v rail
5v rail
3,3v rail
Last is ripple
Next is the Kingwin Lazer Platinum
The fan used is a 140 mm Double Ball Bearing Fan
The cooling fan has Kingwin's logo in its center without any other details about its model number and its characteristics. However since it is identical and most likely the same as the fan that the Super Flower Golden King 1000W uses then its model number must be HA1425M12B-Z (12V, 0.36A). Even at high speed the fan is very quiet and at the same time highly efficient. It is also equipped with a plastic baffle to direct the air towards the rear side of the unit.
12v rail
5v rail
3,3v rail
Last is ripple
Next is the Rosewill Tachyon
The fan used is a 140 mm Sleeve Bearing Fan (RL4Z S1402512HH)
The fan control circuit is installed on a small vertical daughter-board in the secondary side. A quality problem we spotted is that this small PCB is only held in place by several weak solder joints on its base. These solder joints completely detached from the PCB once we tried to disconnect the fan header, although we applied minimal force and were extra cautious. This means that strong vibrations (during shipping for instance) may cause these joints to detach as well, which would break the fan circuit, so the fan won't spin at any load/internal temperature. Such a fan's malfunction will, to make things worse, easily pass unnoticed since the fan only spins up at higher loads and increased temperatures, and the PSU isn't equipped with OTP to shut down operation once internal temperature go through the roof. An easy fix to this problem would be to apply some glue around the PCB to secure it in place. Some build-quality points where obviously lost here.
12v rail
5v rail
3,3v rail
Last is ripple
The conclusion
Ripple best to worst
Corsair RMx = 12,2mv
NZXT HALE 90 V2 = 13,4mv
EVGA SuperNova G2 = 14,2mv
EVGA SuperNova P2 = 14,3mv
Super Flower Leadex Platinum = 15,6mv
Corsair RMi = 17,5mv
Antec High Current Pro Platinum = 19,6mv
Seasonic Platinum 1000 (XP) ) = 24mv
Corsair HXi = 25,9mv
Be Quiet Dark Power Pro 10 = 27,2mv
Rosewill Tachyon = 29,1mv
Super Flower Golden King = 29,7mv
Be Quiet Dark Power Pro 11 = 30mv
XFX XTS = 30,5mv
Seasonic X (XM2) = 31,9mv
Be Quiet PowerZone = 31,9mv
Corsair HX1050 V1 = 32,4mv
Cooler Master V = 33,5mv
OCZ FATAL1TY = 36,4mv
Kingwin Lazer Platinum = 37,2mv
Cooler Master Silent Pro Hybrid = 40,,1mv
Seasonic Snow Silent = 40,5mv
Club 3D CSP-X1000CB = 41,4mv
Thermaltake Toughpower DPS Gold = 41,8mv
Seasonic Platinum 1050 (XP3) = 41,8mv
Xigmatek Centauro = 41,9mv
Zalman ZM1000-HP = 42,8mv
Silverstone Strider Gold Evolution = 49,1mv
Fractal Design Newton R3 = 50,8mv
Fractal Design Tesla R2 = 51mv
Cooler Master Silent Pro M2 = 54,8mv
Thortech Thunderbolt Plus = 60,8mv
Zalman ZM1000-EBT = 64,3mv
Corsair RM = 90,9mv (this one is flatout rubbish!)
Voltage regulation from best to worst (12v)
Seasonic Snow Silent = 0,26%
Seasonic X (XM2) = 0,36%
Seasonic Platinum 1050 (XP3) = 0,46%
XFX XTS = 0,46%
Super Flower Leadex Platinum = 0,70%
Fractal Design Newton R3 = 0,80%
EVGA SuperNova P2 = 0,81%
EVGA SuperNova G2 = 0,88%
Be Quiet PowerZone = 0,88%
Be Quiet Dark Power Pro 11 = 0,94%
Cooler Master V = 0,99%
Corsair RMi = 1,05%
Rosewill Tachyon = 1,06%
Thermaltake Toughpower DPS Gold = 1,09%
Fractal Design Tesla R2 = 1,18%
Zalman ZM1000-EBT = 1,21%
NZXT HALE 90 V2 = 1,23%
Corsair RM = 1,28%
Seasonic Platinum 1000 (XP) = 1,41%
Corsair RMx = 1,42%
Antec High Current Pro Platinum = 1,62%
Be Quiet Dark Power Pro 10 = 1,72%
Club 3D CSP-X1000CB = 1,74%
Super Flower Golden King = 1,77%
Kingwin Lazer Platinum = 1,86%
Zalman ZM1000-HP = 1,87%
Corsair HXi = 1,93%
OCZ FATAL1TY = 2,03%
Silverstone Strider Gold Evolution = 2,16%
Xigmatek Centauro = 2,17%
Thortech Thunderbolt Plus = 2,23%
Cooler Master Silent Pro M2 = 2,30%
Cooler Master Silent Pro Hybrid = 2,39%
Corsair HX1050 V1 = 2,54%
What does all this mean?
Now for some of you this is all mumbo jumbo and you dont understand what all that means, So you are probably going to ask well which is the best unit for the money?
The answer to that is the Leadex P2 and G2 takes a another win here, They are priced the lowest in almost every place i have looked, And they have won everything else so thats your best option unless the second or lower best rated is on a crazy sale.
Thats all
Seravee
(32 items)
Intel Core I7 6850K
Gigabyte X99 Ultra Gaming
EVGA GTX 1080 FTW2
Kingston HyperX DDR4 Savage 3000 MHz
Samsung 840 Evo 500 GB
Samsung 860 Evo 1 TB
Seagate Ironwolf Pro 8 TB
Seagate Ironwolf 12 TB
Seagate Ironwolf Pro 10 TB
Seagate Ironwolf Pro 12 TB
WD Ultrastar DC HC530 14 TB
Optical Drive
LG CH12NS30
EVGA SuperNova G2 750 watt
x5 Noctua NF-A14 FLX
Noctua NH-D15S
Phanteks Enthoo Luxe Tempered Glass
Operating System
Windows 7 Ultimate 64 bit
Operating System
Windows 10 Home 64 bit
Asus PG279Q
LG 55C8 OLED TV
Keyboard
Corsair Gaming Strafe RGB
Mouse
Roccat Kone EMP
Mouse
Roccat Sense Metor
Audio
Sennheiser HD 598
Audio
Onkyo TX NR646
Audio
Dali Opticon Vokal
Audio
x2 Dali Opticon 2
Audio
x2 Dali Opticon 1
Audio
Dali E12 F Subwoofer
Audio
Sennheiser HD-599
Other
CableMod E series PSU cable set
Other
CableMod LED Strips
shilka is offline
post #2 of 90 (permalink) Old 12-12-2013, 12:38 PM
OlderBuilder
oldAMDnew2Intel's Avatar
Rep: 4 (Unique: 4)
Thanks shilka,
Initially, my Corsair AX1200i was hot to the touch [RMA'ed and they sent a new one].  This one still runs rather warm for my taste, feels like it's throwing a lot of heat into my case...was thinking of getting a new PSU but had no idea where to turn.  Your post helped a lot, just ordered the P2...hope someone buys my 1200i [it being the holidays and all].
oldAMDnew2Intel is offline
post #3 of 90 (permalink) Old 12-12-2013, 01:01 PM - Thread Starter
Senior OCN Member
shilka's Avatar
Been thinking of adding the NZXT HALE 90 V2 and the Antec High Current Pro Platinum
Anyone want them compare to the others?
Seravee
(32 items)
Intel Core I7 6850K
EVGA GTX 1080 FTW2
Optical Drive
LG CH12NS30
Noctua NH-D15S
Operating System
Operating System
Asus PG279Q
LG 55C8 OLED TV
Keyboard
Mouse
Roccat Kone EMP
Mouse
Roccat Sense Metor
Audio
Sennheiser HD 598
Audio
Onkyo TX NR646
Audio
Dali Opticon Vokal
Audio
x2 Dali Opticon 2
Audio
x2 Dali Opticon 1
Audio
Audio
Sennheiser HD-599
Other
Other
CableMod LED Strips
shilka is offline
post #4 of 90 (permalink) Old 12-13-2013, 03:54 AM
OlderBuilder
Rep: 4 (Unique: 4)
Cancelled order for the P2, think I'll keep my server-grade AX1200i.  I'll fiddle with the software to get the fan going a little sooner to cool this puppy down.
post #5 of 90 (permalink) Old 12-13-2013, 07:03 PM
Linux Lobbyist
ep45-ds3l's Avatar
Rep: 93 (Unique: 83)
+1 for the V1000.. Because I have one.. Lol
Quiet and cool
ep45-ds3l is offline
post #6 of 90 (permalink) Old 12-15-2013, 03:10 PM
Malleus09's Avatar
Rep: 0
with the current prices which would be the best value?
prices:
v100: 209.99$
G2: 169.99$
P2: 219.99$
seasonic platinum: 239.99$
Malleus09 is offline
post #7 of 90 (permalink) Old 12-15-2013, 03:42 PM - Thread Starter
Senior OCN Member
shilka's Avatar
I would have to say the EVGA SuperNova G2 is best value
But the P2 is a little better
Do you need 1000 watts?
Seravee
(32 items)
Intel Core I7 6850K
EVGA GTX 1080 FTW2
Optical Drive
LG CH12NS30
Noctua NH-D15S
Operating System
Operating System
Asus PG279Q
LG 55C8 OLED TV
Keyboard
Mouse
Roccat Kone EMP
Mouse
Roccat Sense Metor
Audio
Sennheiser HD 598
Audio
Onkyo TX NR646
Audio
Dali Opticon Vokal
Audio
x2 Dali Opticon 2
Audio
x2 Dali Opticon 1
Audio
Audio
Sennheiser HD-599
Other
Other
CableMod LED Strips
shilka is offline
post #8 of 90 (permalink) Old 01-04-2014, 10:43 AM
nismo_usaf's Avatar
Rep: 12 (Unique: 12)
Just curious, was reading your post from another thread. You posted a link to JonnyGURU; so I decided to see if my 2008 PSU was in his review. Well it was and with that said how do YOU think the Corsair HX1000 performs with today's line-up? And yes I know It's "overkill" but at the time this PSU was running 2 GTX 280s.
nismo_usaf is offline
post #9 of 90 (permalink) Old 01-04-2014, 10:55 AM - Thread Starter
Senior OCN Member
shilka's Avatar
Its not actually not a true 1000 watts PSU its two 500 watts slapped together
Ripple on the two 12v rails are up to 4,6 times higher on the HX1000 vs the Leadex
Efficiency is 6 to 12% lower on the HX1000 vs the Leadex
Seravee
(32 items)
Intel Core I7 6850K
EVGA GTX 1080 FTW2
Optical Drive
LG CH12NS30
Noctua NH-D15S
Operating System
Operating System
Asus PG279Q
LG 55C8 OLED TV
Keyboard
Mouse
Roccat Kone EMP
Mouse
Roccat Sense Metor
Audio
Sennheiser HD 598
Audio
Onkyo TX NR646
Audio
Dali Opticon Vokal
Audio
x2 Dali Opticon 2
Audio
x2 Dali Opticon 1
Audio
Audio
Sennheiser HD-599
Other
Other
CableMod LED Strips
shilka is offline
post #10 of 90 (permalink) Old 01-04-2014, 11:08 AM
nismo_usaf's Avatar
Yeah I got that from comparing the 2 reviews as well. But what do you think; say running newer cards in SLi with the hx1000.
