Why you might not want to buy a Corsair RM PSU - Page 3 - Overclock.net - An Overclocking Community
Closed Thread
post #21 of 653 (permalink) Old 01-15-2014, 12:54 PM
Rep: 577 (Unique: 411)
Let's set aside companies and which products are which and look the problems experienced. They're not all the same.
Problem 1: faulty fan control algorithm causes power supply to shut down by reaching OTP limit when operated constantly around 50% load (but not high enough for the fan to kick in) with high enough ambient intake temperatures and the right conditions. Doesn't seem to affect most users based on usage patterns and not seen by most reviewers even stress testing 40% load in hotbox.
Fallout: hardware revision so new units shipped have the problem fixed. Replacements for old users available and with free shipping.
Problem 2: not enough insulation on a thermal pad causes some samples to shut down or not be able to power on. Wasn't seen by reviewers.
Problem 3: missing wiring causes some +5V pins on ATX connector to be unused. This results in effectively less power being able to be supported for the motherboard on a +5V-based system. Doesn't affect people using systems newer than Pentium 3 or so.
Fallout: ?? I don't know if there's a hardware revision or not, but there's no recall I think.
I don't think problem 3 is worth the hassle of changing out for most users, since it's not an issue for almost everybody. Got that Pentium 3 overclocked? Problem 2 seems the most serious as that affects the operation of potentially every unit no matter how you use it, so it should get the most aggressive response. I'm not sure if the shipping details / RMA / returns process was a little different on 1 and 2.
Warning: Spoiler! (Click to show)
1 was the old Corsair RM750/850 issue, and 3 was on the other RMs (maybe not 1000W? I'm not sure). 2 was EVGA 1000W/1300W Leadex-based power supplies.
mikeaj is offline
post #22 of 653 (permalink) Old 01-15-2014, 02:20 PM
Rep: 24 (Unique: 21)
The problem with the missing +5v connectors is far more serious than the other 2 actually.
Not all motherboards are made the same way. A lot of components work using very low voltages, below 2 volts, with mosfets on the board doing the conversion by using the major lines. One manufacturer might be using the 12v line to provide low voltages, some other might be using the 5v line while some other the 3.3v line.
Now, the thing is. It's certain that some boards use the +5v line to feed some fets with power. When some of the 5v connections are missing then the board either shuts off, (that's bad) or overloads the other 5v connections (that's even worse, this means that your system will be set on fire).
The end result is some boards frying themselves, while most others are not. All because of the PSU being off-specs. But the end user will not know that the PSU is responsible (unless he knows that this specific PSU line has this specific issue) and will en up blaming the motherboard manufacturer.
The worst part is, that because of Corsair's reputation, it'll be impossible to convince the end user that the PSU is to blame.
PsyM4n is offline
post #23 of 653 (permalink) Old 01-15-2014, 02:30 PM
Some FETs maybe but not CPU VRM FETs, unless you know of some examples? You shouldn't be getting enough draw to be a concern from the other components on the board outside of CPU power delivery.
mikeaj is offline
post #24 of 653 (permalink) Old 01-15-2014, 02:40 PM
r/madlads
DaveLT's Avatar
Rep: 273 (Unique: 219)
Memory VRM and alot of 5V stuff on a mobo. If you're ignorant to that then I guess you read up
DaveLT is offline
post #25 of 653 (permalink) Old 01-15-2014, 02:43 PM
If the motherboard maker decided to use the 5v line to power the ram, pci-e, pch/southbridge and the rest "secondary" fets you're pretty much screwed actually.
PsyM4n is offline
post #26 of 653 (permalink) Old 01-15-2014, 02:49 PM - Thread Starter
Senior OCN Member
shilka's Avatar
Rep: 2740 (Unique: 1626)
Any boards out there right now that does?
Seravee
(30 items)
Intel Core I7 6850K
Gigabyte X99 Ultra Gaming
MSI RTX 2070 Super Gaming X Trio
Kingston HyperX DDR4 Savage 3000 MHz
Samsung 840 Evo 500 GB
Corsair Force MP510 1,92 TB
Seagate Ironwolf Pro 14 TB
Seagate Ironwolf 12 TB
WD Ultrastar DC HC530 14 TB
Seagate Ironwolf Pro 12 TB
Seagate Ironwolf Pro 16 TB
Optical Drive
LG CH12NS30
Seasonic Prime Ultra Titanium 750 watt
Noctua NH-D15S
Phanteks Enthoo Luxe Tempered Glass
Operating System
Windows 7 Ultimate 64 bit
Operating System
Windows 10 Home 64 bit
Asus PG279Q
LG 55C8 OLED TV
Keyboard
Corsair Strafe RGB MK.2 with Cherry MX Silent
Mouse
Roccat Kone EMP
Mouse
HyperX Fury S XL
Audio
Sennheiser HD 598
Audio
Onkyo TX NR646
Audio
Dali Opticon Vokal
Audio
x2 Dali Opticon 2
Audio
x2 Dali Opticon 1
Audio
Dali E12 F Subwoofer
Audio
Sennheiser HD-599
Other
CableMod 30 CM Magnetic Red LED strip
shilka is offline
post #27 of 653 (permalink) Old 01-15-2014, 03:01 PM
Sure. It all depends on the fets used and the voltage decided by the maker. Good luck going through the specs of every fet out there and using your multimeter to measure the voltage going to each fet... for the few thousand boards that came out these last 5-10 years or so. All that to make sure that the psu won't fry your board.
A lot of boards do use only the 12v line (unless on standby where only the 5vsb line is used) but the idea to get rid of the additional lines hasn't taken off yet, so many still use the minor ones.
Now, if you want a specific answer, get some hundred boards and some multimeters so you can check yourself. Good luck going through all those boards. tongue.gif
PsyM4n is offline
post #28 of 653 (permalink) Old 01-15-2014, 05:04 PM
r/madlads
DaveLT's Avatar
Some people pull massive current through the USB (*cough* people like me)
DaveLT is offline
post #29 of 653 (permalink) Old 01-15-2014, 05:13 PM
Yeah, sure, but are three +5V wires (and the grounds of course) not going to be able to handle those parts? Going from five wires to three isn't a problem unless you're actually drawing more power than that off those lines.
Okay, if the board only takes the 20-pin ATX, you're down to two from four.
I mean, it's definitely not a good look for CWT or Corsair, but is it seriously going to be problematic in more than a few incidents?
mikeaj is offline
post #30 of 653 (permalink) Old 01-15-2014, 05:20 PM - Thread Starter
Senior OCN Member
shilka's Avatar
Seravee
(30 items)
Intel Core I7 6850K
Optical Drive
LG CH12NS30
Noctua NH-D15S
Operating System
Operating System
Asus PG279Q
LG 55C8 OLED TV
Keyboard
Mouse
Roccat Kone EMP
Mouse
HyperX Fury S XL
Audio
Sennheiser HD 598
Audio
Onkyo TX NR646
Audio
Dali Opticon Vokal
Audio
x2 Dali Opticon 2
Audio
x2 Dali Opticon 1
Audio
Audio
Sennheiser HD-599
Other
shilka is offline
Closed Thread
