So seasonic saved me from a fire, or did it? - Overclock.net - An Overclocking Community
post #1 of 228 (permalink) Old 01-21-2014, 06:19 PM - Thread Starter
INCREDIBLEHULK's Avatar
Rep: 113 (Unique: 85)
Been trying to test this new 290x with mining, random restarts, computer hangs, card isn't OC'd
While troubleshooting all the things that could be wrong I decided to replug the connectors in my PSU
This seasonic x 750 has been good to me for 1.5years
While removing the pci-e for the ONLY 290x in my rig I notice the connector is MELTED.
MELTED. I couldn't even remove it, so when I did, obviously the black pieces on the connector broke off.
I'm going to RMA this thing but, no single rail was completely overloaded, this is a gold rated 750 watt power supply and I'm not even close to reaching that limit.
So RMA or not, did I have a unlucky psu? What could have possibly gone wrong frown.gif I am assuming the short is what kept causing the PC to restart, but to be honest it was more of a screen goes black, everything is still powered on(gpu fans spinning , cpu fan spinning) ? I still don't know if this was the main reason for that or not, still have to test bunch of different things
Here's some bad quality pics for you to see
INCREDIBLEHULK is offline
post #2 of 228 (permalink) Old 01-21-2014, 06:36 PM
seross69's Avatar
Rep: 224 (Unique: 145)
Here's some bad quality pics for you to see Warning: Spoiler! (Click to show)
this is the 2nd Seasonic PSU that I have seen do this in less than a week. See this thread.
What it looks like to me is that seasonic has a +12 and a negative crossed. because the PSU should not cause this it should be a short on the other end. and you see it here because this is where the heat would start first, or maybe the ribbon cables they are using is allowing a short.
Good luck Hulk.. interesting to see what happens because I know seasonic is going to blame it on what ever you had it hooked to. Unless they know they might be a problem then they will replace asap to keep you quiet....
No trees were harmed in the sending of this message. However, a large number of electrons were terribly inconvenienced
Just playing with cooling and Computers
seross69 is offline
post #3 of 228 (permalink) Old 01-21-2014, 06:39 PM
Rep: 365 (Unique: 250)
loose connection high resistance creates heat and melts the connection.
how much slack was on the cable?
Master__Shake is offline
post #4 of 228 (permalink) Old 01-21-2014, 07:03 PM
seross69's Avatar
that is also a possibility but it looked like the connector was tight to me in the pictures but might be bad pins not making good contact causing this also... I have removed the factory pins from psu connectors and found some that was not stripped out and had been crimped to insulation....
seross69 is offline
post #5 of 228 (permalink) Old 01-21-2014, 08:01 PM - Thread Starter
Thanks man, I really hope not.
I would be quite aggravated with seasonic. Everything on my PC is fine except this destroyed cable that was melted into the PSU.
Really sucks that happened to RAFFY, much coincidence happened on a 290x eh. Guess tomorrow will be one of those fun days.
Slack on the cable?
There is no loose connection I plugged the connector into where it goes making sure that it clicks in place.
I used this power supply for 1.5 years and after putting in a 290x this happens? Sucks for me frown.gif
post #6 of 228 (permalink) Old 01-21-2014, 08:19 PM
seross69's Avatar
Slack on the cable?
problem might be with the 290'x also pins hooked up wrong or something like this. If you guys have problems need to get together so you can prove it not just one time happening. let us know how it turns out!!
Customer service is a big thing to me. I will pay more for good service and have in the past and will continue to...
seross69 is offline
post #7 of 228 (permalink) Old 01-22-2014, 06:43 AM
RAFFY's Avatar
Rep: 282 (Unique: 257)
It has to be a problem with these power supplies and the 290x. Mine was hooked undervolted, and the psu was running at 80% capacity at most. So far Seasonic has been great. They paid for return shipping and are willing to reimburse for damage to my computer case once I send them pictures. So far they have been great.
RAFFY is offline
post #8 of 228 (permalink) Old 01-22-2014, 12:28 PM - Thread Starter
I just hope they are the same with me, thank you for sharing me the experience.
I'm honestly afraid to get the Seasonic X 1250 now and am considering a Corsair 1200i with the single 12v rail.
I've never been more glad to not finish the sleeving job. I'm sure all the paracord bunched up might of had a different effect if 10 wires burnt up at once. A sleeved pci-e cable could of ended up costing me my home rolleyes.gif
post #9 of 228 (permalink) Old 01-22-2014, 12:34 PM
Senior OCN Member
shilka's Avatar
Rep: 2748 (Unique: 1629)
Get a EVGA SuperNova G2 Instead
Seravee
(30 items)
Intel Core I7 6850K
Gigabyte X99 Ultra Gaming
MSI RTX 2070 Super Gaming X Trio
Kingston HyperX DDR4 Savage 3000 MHz
Samsung 840 Evo 500 GB
Corsair Force MP510 1,92 TB
Seagate Ironwolf Pro 14 TB
Seagate Ironwolf 12 TB
WD Ultrastar DC HC530 14 TB
Seagate Ironwolf Pro 12 TB
Seagate Ironwolf Pro 16 TB
Optical Drive
LG CH12NS30
Seasonic Prime Ultra Titanium 750 watt
Noctua NH-D15S
Phanteks Enthoo Luxe Tempered Glass
Operating System
Windows 7 Ultimate 64 bit
Operating System
Windows 10 Home 64 bit
Asus PG279Q
LG 55C8 OLED TV
Keyboard
Corsair Strafe RGB MK.2 with Cherry MX Silent
Mouse
Roccat Kone EMP
Mouse
HyperX Fury S XL
Audio
Sennheiser HD 598
Audio
Onkyo TX NR646
Audio
Dali Opticon Vokal
Audio
x2 Dali Opticon 2
Audio
x2 Dali Opticon 1
Audio
Dali E12 F Subwoofer
Audio
Sennheiser HD-599
Other
CableMod 30 CM Magnetic Red LED strip
shilka is offline
post #10 of 228 (permalink) Old 01-22-2014, 12:43 PM
241pizza's Avatar
Rep: 10 (Unique: 8)
I am also running a 290X with the seasonic x 750, I will def re-check connectors and keep an anything melting.
241pizza is offline
