Possible PSU Coil Whine Fix - Page 2 - Overclock.net - An Overclocking Community
post #11 of 16 (permalink) Old 01-29-2015, 11:38 AM
Kaltenbrunner's Avatar
Rep: 18 (Unique: 17)
Originally Posted by Faithh View Post
That's for the GPU obviously.
Originally Posted by eXXon View Post
Yeah, thought OP was talking about GPU whine, my bad.
Well in so far as it makes a PSU like mine go crazy, I'll try that too, so far hitman gets 1700-1800fps in menu and makes my PSU do the kettle whine
Kaltenbrunner is offline
post #12 of 16 (permalink) Old 04-28-2015, 06:58 PM
Vizkos's Avatar
Rep: 3 (Unique: 3)
Google brought me here. I'm glad it did.
I noticed my PSU whining today after unplugging my machine to install some SSDs into a 5.25'' bay. I would test the whining by logging into Diablo 3 and playing. Within seconds of warping to an area and fighting, the whining would start.
I have a modular Corsair PSU, so I figured perhaps a fuse with the slot I had my cable plugged into was bad, so I moved the cable to no avail. I unplugged the cable I had added, still whined. I unseated my PSU to verify it was the issue and not my GPU. I installed the program the OP linked, ran it for about 5 mins, the whining stopped, and I just played a little bit of Diablo 3 and no whine smile.gif
Vizkos is offline
post #13 of 16 (permalink) Old 01-25-2016, 01:14 AM
father freedom
eurotrade07's Avatar
Rep: 2 (Unique: 2)
Literally before a few hours I've fixed the terrible demonic loud coil whine sound my brand new Hiper PSU was making.
I started banging my head where that come from.
I guess my presumption that it's from newly installed hardware got me in the right direction.
I've removed my new NZXT Fan controller and the coil noise is completely, 100% gone.
I don't know if that has anything to do with it but my fan controller made my LED fans to flicker non-stop.
eurotrade07 is offline
post #14 of 16 (permalink) Old 11-15-2016, 10:04 PM
Curiosity14's Avatar
Rep: 1 (Unique: 1)
I tried to stress test my system and after about 20 seconds it restarted.
Specs
Processor Intel Core i5 6400 2.7Ghz
Motherboard MSI H110M Pro VH
Graphics Card Sapphire NITRO Radeon + RX480 8Gb
Memory 8GB DDR4]
Power Supply: Thermaltake Litepower 450w
Curiosity14 is offline
post #15 of 16 (permalink) Old 11-15-2016, 10:20 PM
ForNever's Avatar
Rep: 109 (Unique: 99)
Specs
Memory 8GB DDR4]
You have a solid system there, but I would seriously question your power supply if you experience rebooting during stress tests. That is not a good sign, especially if you aren't even overclocking anything.
If it's not hot enough to hurt when you touch it, then it's very cool. - TwoCables
ForNever is offline
post #16 of 16 (permalink) Old 11-16-2016, 12:29 AM
Rep: 1 (Unique: 1)
What do I replace
Should this be a worry for my other components because in a few months I will be upgrading the PSU and Motherboard
