Question about PSU Cable Swapping - Overclock.net - An Overclocking Community
post #1 of 8 (permalink) Old 08-13-2015, 06:20 AM - Thread Starter
HeavyUser's Avatar
Rep: 8 (Unique: 8)
Hey Guys,
I'm upgrading from an EVGA 850watt G2 to an EVGA SuperNOVA 1000 PS 80+ PLATINUM. I wanted to know if I could reuse the cables from the G2 with the SuperNova without running into any issues or is it better I just replace all the cables?
HeavyUser is offline
post #2 of 8 (permalink) Old 08-13-2015, 06:49 AM
Senior OCN Member
shilka's Avatar
Rep: 2748 (Unique: 1629)
No you cant reuse the cables as the G2 is Super Flower made and the PS is Seasonic made.
Seravee
(30 items)
Intel Core I7 6850K
Gigabyte X99 Ultra Gaming
MSI RTX 2070 Super Gaming X Trio
Kingston HyperX DDR4 Savage 3000 MHz
Samsung 840 Evo 500 GB
Corsair Force MP510 1,92 TB
Seagate Ironwolf Pro 14 TB
Seagate Ironwolf 12 TB
WD Ultrastar DC HC530 14 TB
Seagate Ironwolf Pro 12 TB
Seagate Ironwolf Pro 16 TB
Optical Drive
LG CH12NS30
Seasonic Prime Ultra Titanium 750 watt
Noctua NH-D15S
Phanteks Enthoo Luxe Tempered Glass
Operating System
Windows 7 Ultimate 64 bit
Operating System
Windows 10 Home 64 bit
Asus PG279Q
LG 55C8 OLED TV
Keyboard
Corsair Strafe RGB MK.2 with Cherry MX Silent
Mouse
Roccat Kone EMP
Mouse
HyperX Fury S XL
Audio
Sennheiser HD 598
Audio
Onkyo TX NR646
Audio
Dali Opticon Vokal
Audio
x2 Dali Opticon 2
Audio
x2 Dali Opticon 1
Audio
Dali E12 F Subwoofer
Audio
Sennheiser HD-599
Other
CableMod 30 CM Magnetic Red LED strip
shilka is offline
post #3 of 8 (permalink) Old 08-13-2015, 06:59 AM - Thread Starter
HeavyUser's Avatar
Rep: 8 (Unique: 8)
Crappola, thanks for the response.
post #4 of 8 (permalink) Old 08-20-2015, 06:57 PM
Awaiting the REP Rebuild
gftgy's Avatar
Rep: 41 (Unique: 36)
Originally Posted by HeavyUser View Post
Hey Guys,
Actually, I don't see any reason why you wouldn't be able to use the cables from the G2. After checking the PSUs, they both use the same motherboard connectors[SEE EDIT], 6+2-pin PCI connectors, and SATA connectors[SEE DOUBLE EDIT]. Considering they both operate on a single 12V rail, and that they will both be used in the same manner, the cables you already have installed should work just fine. PSU manufacturer has nothing to do with it.
If you don't mind doing me a favor, though. I would really appreciate it if you took a tape measure to the 1000 PS and gave me a physical measurement of its length. It would be a huge help.
EDIT:
Forget what I said. The motherboard pinout is almost certainly different, so you'll need to change those cables. The SATA connectors are the same, however, along with the PCIe connectors (although the labeling is different). For the PCIe labeling, CPU1 on the G2 is equivalent to VGA1 on the PS. VGA1 on the G2 is the equivalent to CPU2 on the PS. There is no G2 equivalent for CPU2 or VGA 6 on the PS, and there is one less SATA connector. Sorry for the mixup.
DOUBLE EDIT:
You're probably fine, but I could've been wrong about the PCIe and SATA cables. The 1000 PS uses the standard pinout for those, like most products, but it just came to my attention that apparently some products don't, and I couldn't confirm whether the 1000 G2 does or not, sorry. If you're feeling dangerous, go for it, but your safest bet is to go with shilka and replace them all.
gftgy is offline
post #5 of 8 (permalink) Old 08-20-2015, 08:48 PM - Thread Starter
HeavyUser's Avatar
Rep: 8 (Unique: 8)
Thanks for the info, I don't have a measuring tape....lol
post #6 of 8 (permalink) Old 08-20-2015, 09:11 PM
gftgy's Avatar
So, I hope you haven't gone and started plugging things in in the last fifteen minutes. You're probably fine, but I could've been wrong about the PCIe and SATA cables. The 1000 PS uses the standard pinout for those, like most products, but it just came to my attention that apparently some products don't, and I couldn't confirm whether the 1000 G2 does or not, sorry. If you're feeling dangerous, go for it, but your safest bet is to go with shilka and replace them all.
Today I got to learn about pinouts!
Also, no tape measure? How about a ruler?
gftgy is offline
post #7 of 8 (permalink) Old 08-21-2015, 10:41 AM - Thread Starter
HeavyUser's Avatar
Rep: 8 (Unique: 8)
I haven't, I already removed everything and installed the new psu with new cables : ). I will search around for a ruler when I get home, I'll pm you later on.
post #8 of 8 (permalink) Old 08-21-2015, 11:48 AM
gftgy's Avatar
Whew. I saw you had still logged on after I updated that so I figured you were okay, but I was a little worried!
Thanks for that. It's a big help!
gftgy is offline
