"Coil" Whine from Power Supply Suddenly - Overclock.net - An Overclocking Community
post #1 of 7 (permalink) Old 05-14-2016, 05:05 PM - Thread Starter
acidreign's Avatar
Rep: 0
Hey all!
Thermaltake TR2 600W, almost 3 years old.
About 2 weeks ago I started getting a nasty whine when under load, tbought it might be my fairly new gtx 970 but I swear its the psu when I stick my head down there. Been getting a bit worse lately, now it will happen with some light browsing only while moving the mouse or scrolling. Tried running a stress test with OCCT and after about 2 minutes the squeeling stops but comes back on the way back to idle.
Some posts have suggested if you do a fulll hour burn it will sometimes solve the problem goig forward but I'm skeptical as i dont have any extra PSUs around right now if I kill it.
I believe I can rma it but I'm wanting to make absolutely sure its not the gpu. Any way to do that thats more reliable than counting on my ears? Thought about taking the gpu out and trying a stress test using the on board gfx, would that be a bad idea?
Thanks!
acidreign is offline
post #2 of 7 (permalink) Old 05-14-2016, 05:12 PM
Programmer
BradleyW's Avatar
Rep: 1561 (Unique: 1019)
After reading your post, I am certain the PSU is to blame as you've ran OCCT, which stopped the whine. That rules out a whine coming from the 970. The whine stops with OCCT because more power and voltage is being used, which forces the coils to vibrate far quicker than normal which will produce sounds so high they are inaudible.
Adding the 970 has changed the amount of power draw on idle to a level whereby the coils will be at their loudest (vibrating at such a speed that you can hear them). Either over/undervolt the 970 or replace either the PSU or GPU.
Edit: Or pour some hot glue onto the PSU coils, but that's usually a bad idea.
Intel Core i9 9900K HT 5GHz
GIGABYTE Z390 Ultra
Nvidia MSI Trio-X RTX 2080 Super
G-Skill Trident 2x8GB DDR4 4000MHz
Samsung EVO PLUS NVM.e 500GB
SeaSonic 1250W Gold
Tt Core-X71 + Custom Loop.
BradleyW is offline
post #3 of 7 (permalink) Old 05-14-2016, 08:50 PM - Thread Starter
acidreign's Avatar
Rep: 0
Thanks for the quick reply! Glad to hear some confidence about it being the PSU, I am fairly certain as well.
To be clear I've had the 970 for about 3 months and it hadn't been an issue, so maybe the noise is a sign of the PSU starting to fail?
I think it's too extreme to fix by over or undervolting the gpu as it seems like only 10% on the bottom or 10% on the top seem to not whine and the 80% in the middle is noisy.
post #4 of 7 (permalink) Old 05-15-2016, 02:40 AM
Senior OCN Member
shilka's Avatar
Rep: 2808 (Unique: 1658)
Which TR-2 model there are 3 of them? if you have the one called W0388RU you need a new PSU as its terrible.
Dreissen
(27 items)
Seravee
(18 items)
Ryzen 3700x
Asrock x570 Taichi
MSI RTX 2070 Super Gaming X Trio
G Skill TridentZ
Corsair Force MP510 1,92 TB
Seagate IronWolf Pro ST14000NE0008
Seagate Ironwolf ST12000VN0007
Seagate IronWolf Pro ST12000NE0007
WD Ultrastar DC HC530 14 TB
Seagate IronWolf Pro ST16000NE000
Seasonic Prime Ultra Titanium 750 watt
Noctua NH-U12S Chromax
Phanteks Luxe 2
Operating System
Windows 10 Home 64 bit
Asus PG279Q
LG 55C8
Keyboard
Corsair Strafe RGB MK.2 with Cherry MX Silent
Mouse
Roccat Kone EMP
Mousepad
HyperX Fury S XL
Audio
Onkyo TX NR646
Audio
RHA L1 Dacamp
Audio
Sennheiser HD 599
Audio
Dali E 12 F
Audio
2x Dali Opticon 1
Audio
2x Dali Opticon 2
Audio
Dali Opticon Vokal
Other
Vegas MBA 60cm LED Strip
Intel Core I7 6850K
Gigabyte X99 Ultra Gaming
GTX 1060 3 GB wth blower style cooler
Kingston HyperX DDR4 Savage 3000 MHz
Samsung 840 Evo 500 GB
Samsung 860 Evo 1 TB
Optical Drive
LG CH12NS30
Seasonic Focus GX 650 watt
Noctua NH-D15S
Phanteks Enthoo Luxe Tempered Glass
Operating System
Windows 7 Ultimate 64 bit
Operating System
AOC 24G2U
Keyboard
Corsair Gaming STRAFE RGB Mechanical
Mouse
Roccat Kone EMP
Mousepad
Roccat Sense Metor
Audio
Sennheiser HD 598
Other
CableMod 30 CM Magnetic Red LED strip
LG 24MP59G-P
Mouse
Logitech MX518 Hero
Other
Delock PCI-E to M.2 NVME Adaptor Card
shilka is offline
post #5 of 7 (permalink) Old 05-19-2016, 11:52 AM
ssateneth's Avatar
Rep: 44 (Unique: 39)
Coil whine is an aesthetic issue. Some part (transformer, inductor, magnetic choke) is vibrating a microscopic amount because it's resonating with the electric currents and fields running through the power supply. I don't believe the power supply is going bad. It's just merely making sounds as it gets older, like an old house floorboards creaking, or strange sounds coming from your grandpa.
Though if you have odors coming from the power supply, -thats- when I'd start looking for a new one. I've had a few whiny PSU's (and GPU's) but none of them were lemons.
Intel Core i9-9900k (Silicon Lottery 5.1GHz @ 5.3GHz 1.36 VCore)
ASUS ROG MAXIMUS XI APEX
G.SKILL F4-4000C19D-32GTZSW (2x16GiB 4000MHz 19-19-19-39 2T, tuned to 4133MHz 14-17-17-31 2T)
EVGA NVIDIA GeForce GTX 1080 Ti FTW3
Seasonic PRIME 1300W 80+ Platinum
ssateneth is offline
post #6 of 7 (permalink) Old 06-11-2016, 06:28 PM - Thread Starter
acidreign's Avatar
Rep: 0
Hey all,
Just thought I'd provide an update.
Tried to live with the whine for a bit but soon after my Asus mobo did an emergency shutdown due to a "surge" despite my power source being stable and using a suppressor/battery backup so I IMMEDIATELY rma'd this PSU and got ThermalTake to cross ship me a replacement.
New PSU is in and all is good. I'm glad the issues were psu snd not gpu related. NOW we wait and see whst happens when the defective unit gets back to them. There didnt appear to be an excess of debris or dust inside but i wasnt about to tamper with it to get a better peek.
Thanks again for all the replies.
post #7 of 7 (permalink) Old 06-11-2016, 06:31 PM
ssateneth's Avatar
asus oversurge protection is garbage. i wouldnt rely on it.
