UPS no longer prevents power loss! Please Help. - Overclock.net - An Overclocking Community
post #1 of 8 (permalink) Old 05-24-2018, 06:19 PM - Thread Starter
Eh, Wha?
Zero4549's Avatar
Rep: 719 (Unique: 531)
Exclamation UPS no longer prevents power loss! Please Help.
Hi. I have a powercom smk2000a UPS that I've been using for several years. It has always worked without any issue, other than needing to replace the batteries once.
That said, recently it has seemingly been rendered useless. Power flickers so briefly that the lights don't even go out, most of my other UPSs even so much as get off a single beep, but my main rig (the only one connected to this UPS) immediately dies.
UPS doesn't even beep or turn off or show any battery drain on its diagnostic display. It DOES spin up its cooling fan (as it is designed to do while charging or discharging the cells), but that's it.
I've tested the batteries with my multimeter, albeit not while under any load, and they seem fine. Testing them under load isn't really possible with the equipment I have at hand.
Anyone have any clue whats going on here? Do I just need new batteries, even though the replace battery diagnostic light isn't on and they are within spec according to my multimeter? Is the UPS somehow damaged?
I really need an answer to this quick, cause I'm now in storm season and I'm getting an outage every single day, forcing constant RAID rebuilds and other issues.
Thanks
Systems: Fukurou | Prodigy | Tempest | ArcaneServers: Minecraft SMP | Logs: Build Log - Arcane | Video Logs: Project Arcane
Quote:Originally Posted by Zen00 https://www.overclock.net/img/forum/go_quote.gifZero, you are a master story teller, I am sleep now. http://files.overclock.net/images/smilies/thumb.gif
Arcane
(33 items)
Sanctum
(9 items)
Fukurou
(14 items)
Core i7 980x
GIGABYTE GA-EX58-UD5
MSI GeForce GTX 1080TI DUKE
MSI GeForce GTX 680 Lightning
Kingston HyperX T1
Samsung 840 EVO
WD Caviar Black FASS
Plextor M5S
WD Velociraptor
WD FALS
Optical Drive
Sony DVD Burner w/ Lightscribe
Optical Drive
LG Bluray + HDDVD
EVGA 1000 P2
Black Ice GTX 360
Black Ice GTX 240
Cooler Master HAF 932
Operating System
Windows 10 Pro (64)
X-Star DP2710
ASUS VK266H Black 25.5" 2ms LCD
Keyboard
X-Armor U9BL (Mech)
Mouse
Razer Deathadder Chroma
Mouse
Cougar Control
Audio
ATH-A900X
Audio
Maudio AV-40
Audio
Polk PSW-10
Audio
Zalman Mic-1 (Clip-on Mic)
Audio
Sound Blaster X7 LE
Other
Logitech G13
Other
Wacom Intuos 3
Other
Modded PS4, PS3, Xbox 360, and Logitech PC Controllers
Other
Thrustmaster T.16000M FCS HOTAS
Other
Rocketfish 720p Webcam
Other
Scythe "3-Foot Switch"
Ryzen 7 1700
MSI B350M Mortar Arctic
RX Vega 64
G.Skill TridentZ
Samsung EVO 960
Consatellation
Corsair HX 1050
Raijintek Aeneas White Window
Operating System
Windows 10 Pro
Core i5-661
GA-H55-USB3
12GB DDR3 1333
WD Caviar Black AALS 640GB
WD Caviar Green EARS 2TB
Vertex Turbo 60GB (SSD)
Optical Drive
Samsung Blu-ray, Samsung DVD Burner
Seasonic X750 Gold
H50 (With push/pull nocturas)
CM690 II
Operating System
Windows 10 Professional 64
LG 47inch LED LCD
Keyboard
Saitek Eclipse Lite-touch Wireless
Audio
Passive bookshelfspeakers + amp.
Zero4549 is offline
post #2 of 8 (permalink) Old 05-24-2018, 06:35 PM
MightEMatt's Avatar
Rep: 64 (Unique: 61)
Is it line interactive? I can't seem to access the powercom website to get any specs. The narrowest range I can set on my UPS for under and overvoltage is 88V to 136V. This means that if the brownout is still within that value, the UPS will not do anything. It wouldn't be unreasonable for a PSU to trip off at 90V for safety. Try pulling the plug completely to see if the computer stays on, this could at least narrow your investigation.
Main Gaming Rig
(25 items)
Intel Ci7-8700k
Gigabyte Z370 Aorus Gaming 5
Nvidia Geforce GTX 1080Ti
G.Skill Ripjaws V Series 32GB (2x16GB) 3200MHz
Samsung 960 Pro 512GB SSD
Samsung 840 Pro 512GB SSD
Crucial M500 960GB SSD
Crucial MX500 2TB SSD
EVGA Supernova 1000 P2
Ek-Supremacy Evo
EK-FC Geforce GTX FE
EK-CoolStream PE 360 x2
Noctua NF-F12 x6
EK-XRES 250 D5 PWM
Fractal Design Define S
Operating System
Microsoft Windows 10 Pro
Asus PG279Q
Keyboard
Maxkeyboard Nighthawk X9
Mouse
Logitech Pro G
Mousepad
Razer Goliathus Control Gravity
Audio
JDS Labs OL DAC
Audio
JDS Labs Objective2
Audio
Sennheiser HD 6xx
Other
Cyberpower CP1500PFCLCD
Other
Wacom Intuos CTH480
MightEMatt is offline
post #3 of 8 (permalink) Old 05-24-2018, 07:17 PM
Eastern Bloc Electronics
Pawelr98's Avatar
Rep: 55 (Unique: 45)
Basing on reviews the battery lifespan is rather short in this UPS.
It uses 4x12V battery set ?
If you want to test them under load then use a car light bulb(standard 55W) or something similar.
Check for voltage dips on each battery.
Theory wise you could also upgrade the PSU to be able to withstand short voltage dips.
Larger primary side capacitors should do the trick providing that there's no protective circuitry which monitors AC mains input voltage.
The only UPS which is 100% sure is an online UPS.
AC mains into DC, battery in the middle and then conversion back to AC.
It's inefficient but provides a stable AC output which doesn't change no matter what happens on grid AC.
You could convert your current UPS into "online" by providing the power to batteries instead of UPS AC input.
The main problem is that an offline UPS in not really rated for continuous usage (transformer and inverter will overheat), if the load is a fraction of rated power(say 50%) then it should be fine.
Even the fastest pc in the world cannot beat imagination.
Spoiler!
i7 [email protected]@1.325V 2.05V input
Asrock X99 Extreme 4
Sapphire R9 290X [Uber Mode]
Nvidia Geforce GT240 GDDR5 512MB [PhysX + analog output]
Crucial Ballistix 2400mhz 4GB 1.3V
Crucial [email protected] 4GB 1.3V
Seagate 4TB
Samsung 840 EVO 120GB[OS]
WD Red 1TB
Samsung 840EVO 120GB[Arma 3]
Cooler Master Real Power 850w
Koolance 380A [modded for LGA2011v3]
MCP655 with Alphacool HF acetal top [5th gear]
Cooltek 120mm rad [antec tri-speed]
Black Water Ultimate 123 [3x Corsair AF120 Performance Edition]
Feser 10/13 UV Tubing
Alphacool CKC clear
Cooltek 120mm Rad [Corsair SP120 High Performance Edition]
Alphacool GPX-A 290 [290X waterblock]
Cooler Master Haf 932 Amd Edition
Operating System
Windows 7 Ulitimate 64 bit
LG 29EA93 [2560x1080]
Samsung SMB2030N [1600x900]
LG L1715S [1280x1024]
DIY display on V59 controller[[email protected]]
Keyboard
4Tech X7 G800
Mouse
Microsoft Mobile Mouse 4000
Audio
Superlux hd681
Audio
FiiO E07K
Audio
SoundMax Superbeam [bundled with P5B DLX]
Other
Scythe Kaze Master Pro 6 chanell
Other
2x Sharkoon 30cm red cold cathodes
Other
2x Revoltec 10cm UV cold cathodes
Athlon II X2 250 @2GHZ @1core
Gigabyte 870A-USB3
Ati X600 128MB
GoodRam 4gb 1333mhz
Hitachi Ultrastar 1TB
6x Hitachi 2TB (RAID 6)
Samsung 40gb[OS]
2x160GB RAID 1
Pentagram Silent Force 460W
Operating System
Debian 8.2.0 x64
Other
Ever Eco Pro 700 CDS [UPS]
Other
Edimax EW-7318USg [Access Point]
Pawelr98 is offline
post #4 of 8 (permalink) Old 05-24-2018, 07:42 PM - Thread Starter
Eh, Wha?
Zero4549's Avatar
Yes, it is line interactive. Powercom site is indeed down (and was extremely outdated even several years ago, so I'm not surprised).
I have no idea what the range is, but in the past, it would catch brownouts with 100% consistency and there was never an issue. I can try pulling it from the wall as you said, but that's a pain, both physically and due to the huge RAID rebuild times.
yes, 4 12v batteries. As stated above it always handled voltage dips just fine in the past. In fact, there was a period when the infrastructure in this area was so bad that it was boosting the voltage for at least half the day, every day, and also occasionally bucking it as well. It has a beefy cooling fan which keeps the unit itself from overheating under those conditions... unfortunately it overheated all the batteries to the point that they swelled up and couldnt be removed from the unit without sawing off a tiny bit of the chassis, but thats another story.
It seems like the best thing I could do is try to test the batteries under load. My system typically draws about 600w. Would I need a similar load to test the batteries, or would a smaller load like a lightbulb as you suggested still show meaningful results?
Arcane
(33 items)
Sanctum
(9 items)
Fukurou
(14 items)
Core i7 980x
Kingston HyperX T1
Samsung 840 EVO
Plextor M5S
WD Velociraptor
WD FALS
Optical Drive
Optical Drive
LG Bluray + HDDVD
EVGA 1000 P2
Black Ice GTX 360
Black Ice GTX 240
Operating System
Windows 10 Pro (64)
X-Star DP2710
Keyboard
X-Armor U9BL (Mech)
Mouse
Mouse
Cougar Control
Audio
ATH-A900X
Audio
Maudio AV-40
Audio
Polk PSW-10
Audio
Audio
Sound Blaster X7 LE
Other
Logitech G13
Other
Wacom Intuos 3
Other
Other
Other
Other
Ryzen 7 1700
RX Vega 64
G.Skill TridentZ
Samsung EVO 960
Consatellation
Corsair HX 1050
Operating System
Windows 10 Pro
Core i5-661
GA-H55-USB3
12GB DDR3 1333
Optical Drive
Seasonic X750 Gold
CM690 II
Operating System
LG 47inch LED LCD
Keyboard
Audio
Zero4549 is offline
post #5 of 8 (permalink) Old 05-25-2018, 02:21 PM
Pawelr98's Avatar
If you want to test the UPS itself then just use any other load.
A hairdryer at half the output (most have such switch) should be somewhere near 600W I guess.
Few powerful light bulbs or a small space heater may also do the trick.
As for voltage dips testing.
For simplicity let's assume 100% conversion efficiency.
600W/48V=12.5A
Two 55W car light bulbs in parallel should pull around 9A together.
It's a "good enough" test to see how much the voltage goes down under load.
As conversion efficiency is lower than 100% I would guess the real load current to be somewhere around 15A or so.
For my NAS I simply use a 420W UPS along with an older car battery.
Still has ~20AH out of 35AH. Enough to power my 150W NAS for over 30min.
Spoiler!
Seagate 4TB
WD Red 1TB
Alphacool CKC clear
Operating System
Keyboard
4Tech X7 G800
Mouse
Audio
Superlux hd681
Audio
FiiO E07K
Audio
Other
Other
Other
Gigabyte 870A-USB3
Ati X600 128MB
GoodRam 4gb 1333mhz
Samsung 40gb[OS]
2x160GB RAID 1
Operating System
Debian 8.2.0 x64
Other
Other
Pawelr98 is offline
post #6 of 8 (permalink) Old 05-26-2018, 12:05 AM - Thread Starter
Eh, Wha?
Zero4549's Avatar
600W/48V=12.5A
You make good points. Thanks. I've got a portable 900w heater I can use as the test load for the ups and I can probably dig up something that will work for batteries.
Arcane
(33 items)
Sanctum
(9 items)
Fukurou
(14 items)
Core i7 980x
Kingston HyperX T1
Samsung 840 EVO
Plextor M5S
WD Velociraptor
WD FALS
Optical Drive
Optical Drive
LG Bluray + HDDVD
EVGA 1000 P2
Black Ice GTX 360
Black Ice GTX 240
Operating System
Windows 10 Pro (64)
X-Star DP2710
Keyboard
X-Armor U9BL (Mech)
Mouse
Mouse
Cougar Control
Audio
ATH-A900X
Audio
Maudio AV-40
Audio
Polk PSW-10
Audio
Audio
Sound Blaster X7 LE
Other
Logitech G13
Other
Wacom Intuos 3
Other
Other
Other
Other
Ryzen 7 1700
RX Vega 64
G.Skill TridentZ
Samsung EVO 960
Consatellation
Corsair HX 1050
Operating System
Windows 10 Pro
Core i5-661
GA-H55-USB3
12GB DDR3 1333
Optical Drive
Seasonic X750 Gold
CM690 II
Operating System
LG 47inch LED LCD
Keyboard
Audio
Zero4549 is offline
post #7 of 8 (permalink) Old 05-31-2018, 07:32 AM
toolmaker03's Avatar
Rep: 84 (Unique: 64)
well I have 3 large UPS units in my house now each one attached to a desktop PC I have been using UPS systems in my home now for about 15 years, my units typically last 10 years before I need to replace them. I have replaced batteries in one unit before, but the unit died before the new battery did. so today I just replace the whole unit if something fails. today I have one cyberpower and two APC units, the cyberpower is a 900 watt unit and the APC units are 1000 watt units. my UPS units are set to keep the PC one for 10 seconds after power loss, before starting the shut down process.
do you live in the US?
if so, having half power to the complex is a wiring issue, I would pay to have a electrician diagnose what is causing the issue, provide you with a estimate for the repair, and submit a copy of that to the management of the complex. it is possible that legal action will be needed to get this fixed. there is also the option of moving.
https://www.overclock.net/forum/rigbu...tle=AMD+AM3%2B
AMD AM3+
TEC Power
(21 items)
FX9590
Asus Sabertooth 990FX
GTX580
Samsung 1600
Intel 520 SSD 120Gigs
Optical Drive
DVD
Enermax 1350
water cooled
Asus 27"
Keyboard
microsoft ergo
Mouse
RAT 9
Mousepad
steel series
Audio
ZX 7
3930K
DX79SR
GTX580
G skill 2133Mhz
Intel 3700
Optical Drive
Asus
OCZ 1250W, TT 600W, PowerMax 4 X 500W
9 X TEC's 250W 15A 24V
Standard Water cooling to cool the TEC's 6 X 360mm radiators
19 X CPU water blocks
2 X GTX580 GPU water blocks
6 X water pumps
3 X CPU air coolers
Coustom PC case inside a vacuum chamber
Operating System
Windows 7
Dell 30" ultra sharp
Keyboard
Blackwidow
Mouse
RAT 9
Mouse
Gaming Pad
Audio
2.1 sound
Audio
G930 head set
Intel i7 3930K
Intel DX79SR
GTX580
G-Skill
Intel 3700
Optical Drive
Asus DVD
1250W
Water Cooled
H2OQPower
Operating System
Win7
Asus
Keyboard
Razer
Mouse
R.A.T.9
toolmaker03 is offline
post #8 of 8 (permalink) Old 06-01-2018, 01:47 PM
Alan G's Avatar
Rep: 49 (Unique: 44)
if so, having half power to the complex is a wiring issue, I would pay to have a electrocution diagnose what is causing the issue, provide you with a estimate for the repair, and submit a copy of that to the management of the complex. it is possible that legal action will be needed to get this fixed. there is also the option of moving.
I couldn't resist responding to this post. You might want to make sure that electrocutions are legal in your state!
Photo Editing PC
(11 items)
HTPC
(10 items)
Intel i7-4790k
ASUS Sabertooth Z97 Mark 2
ASUS GTX 960 2GB STRIX
16GB Crucial Ballistix Tactical DDR3 1600
256 GB Samsung 850 PRO
WD 2TB Caviar Black
SeaSonic G 650
Noctua NH U12S
Fractal Design Define R5
Operating System
Win8.1
NEC MultiSynch P232W
Intel Pentium G4500
Gigabyte H270 N-WiFi
8GB Crucial Ballistix Tactical DDR4
240 GB Samsung EVO 850
1TB WD Black
Seasonic 430W S12 II
Noctua NH-L9i
Fractal Designs Core 500 mITX
Operating System
Win7
Keyboard
Logitech K-400
Alan G is offline
