which is more dangerous for PC on 12V rail : 11.5V or 12.5V ?? - Page 3 - Overclock.net - An Overclocking Community
post #21 of 24 (permalink) Old 12-24-2018, 03:34 PM - Thread Starter
Not New to Overclock.net
pulverizor's Avatar
Rep: 0
Quote: Originally Posted by EastCoast View Post
Are we talking a consistent voltage or if it fluctuates between the 2?
suppose consistent
consistent 11.5V vs consistent 12.5V
which is worse for CPU & GPU lifespan?
pulverizor is offline
post #22 of 24 (permalink) Old 12-24-2018, 03:46 PM
Falkentyne's Avatar
Rep: 386 (Unique: 276)
Quote: Originally Posted by pulverizor View Post
suppose consistent
11.5v can possibly cause video card crashes and instability. I had a worn out PCIE connector which was only supplying 11.25-11.13v to my r9 290X and had mulitple 'black screen' hard crashes.
Replacing the cable fixed everything and it then read 11.75-11.63v exactly as it did when everything was new.
12.5v could possibly boost signal strength but would also lead to more stress as well.
keep in mind something:
the VIDEO CARD's voltage itself reported by the sensors was the same. (I looked at the sensors). It was the current that was different, going through the mosfets, since the source voltage was now lower, but the output voltaeg (e.g. 1.13v) needed to be the same. Of course you need professional tools to actually investigate this. You can NOT rely on onboard sensors.
[email protected] ghz, RX Vega 64, 32GB DDR4, Gigabyte Aorus Master, Seasonic Platinum 1000W, Corsair 760T
Alt: MSI GT73VR Throttlebook with 7820HK @ 4.7 ghz, GTX 1070 MXM TDP mod to 230W, 32 GB RAM
Falkentyne is offline
post #23 of 24 (permalink) Old 12-27-2018, 06:53 PM
Rep: 0
Power supplies
Neither is "more dangerous"
A switch mode power supply or buck regulator or equivalent may overload if the voltage drops too far as it tries to compensate. The Ohms law bit does not apply.
You will not have enough technical information about all the components in the system. You rely on the manufacturer and they making decisions which are based on their approach to the completed item.
If crude test instruments show .5v variance then probably the peak and trough voltages are significantly greater and lower and outside the spec, i.e you want to measure the ripple and add that to the result. A high level of ripple will be much more significant and damaging.
Also if the regulation is .5v off on any rail then the power supply is probably out of spec. Good manufacturers will try to ensure the electronics works as close as possible to the optimal output voltages (for the cost) irrespective of the input voltage.
The only guide I make is reputation of the manufacturer and look for < 2.5% including ripple.
HiPot testing certificate should also be present. This may reduce the potential for damage from a surge.
TomMcHenry is offline
post #24 of 24 (permalink) Old 01-07-2019, 02:05 AM
umeng2002's Avatar
Rep: 170 (Unique: 106)
Even the really good PSUs are fairly "lax" with the exact voltage output as long as it's stable throughout the loading (low V droop) and has low noise (by lax, I mean well within spec but not exactly the right voltage). All PC component manufacturers take that variation into account.
So even if the voltage is 12.2 Volts across the entire power usage range, that's much better than a PSU that swings from 12.2 to 11.8 across the power usage range. Neither of them are particularly close to 12 compared to each other, but one is more stable.
AMD Ryzen 2700X
Asus Prime X470-Pro
EVGA GeForce RTX 2070 XC Ultra
TeamGroup T-Force 16 GB (2x8) Pro Dark (B-die TDPGD416G3200HC14ADC01)
Samsung 840 EVO 250 GB
Seasonic Focus Plus Platinum SSR-750PX
Corsair H80i (not V2 or GT)
LG 34UC80-B
Keyboard
Logitech G413
Mouse
Logitech G503 RGB
Audio
Creative SoundBlaster Z (OEM)
umeng2002 is offline
